2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
06/23/18 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
06/23/18 09:34 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
90 registered (1JZ_E46, 14Accent, 928, 2015_PSD, Aero540T, 10 invisible), 1629 Guests and 42 Spiders online.
65303 Members
67 Forums
285861 Topics
#4690301 - 03/10/18 08:31 AM Grease recommendations for RC car differentials
TAP Offline
Loc: Ohio
I've got several 1/8 scale RCs that need their metal gear differentials cleaned and relubricated. Unfortunately the grease I would like to use is over $10 for less than an ounce of it. Many RC lubricants are relabeled products from the bike and automobile space so hoping I can find something comparable at a lower price. Each differential consists of (2) sun gears and (4) satellite gears in a cross formation.
Some basic requirements for the grease:
Needs to be sticky to resist fling off. Mobil-1 grease flings right off so need something much stickier.
Needs to be thicker than Mobil 1. A thicker/more vicious grease will reduce the differential action which is desirable in my application.
O-ring safe. There are rubber o-rings sealing the diff cases so the grease has to be o-ring safe.
Any suggestions on a grease that might fit this application would be greatly appreciated.
Todd
#4690315 - 03/10/18 08:49 AM Re: Grease recommendations for RC car differentials [Re: TAP]
rooflessVW Online   content
Loc: North Carolina
Valvoline SynPower grease in the black tube is what I'd use. Moly-fortified and my 5 year old tube hasn't separated at all. It's plenty thick to boot. Unless you get it pretty hot I don't think you'll have issues with it.
"Zed's dead baby, Zed's dead."
#4690336 - 03/10/18 09:11 AM Re: Grease recommendations for RC car differentials [Re: rooflessVW]
TAP Offline
Loc: Ohio
I have that grease and I like it alot but it's not thick enough for the center differential on my truck. I need something that is a bit more vicious to reduce the diff action and keep the power from unloading to the front wheels. Admittedly I haven't tested it in a diff, but doing the finger test it doesn't appear to be heavy enough. The finger test could be a poor way to determine if its the correct oil.
#4690359 - 03/10/18 09:39 AM Re: Grease recommendations for RC car differentials [Re: TAP]
danez_yoda Online   content
Loc: texas
Lucas red and tacky.
Sticks really good but seperates in the gun. Put it in a tub or just buy a tub if it.
#4690368 - 03/10/18 09:45 AM Re: Grease recommendations for RC car differentials [Re: danez_yoda]
TAP Offline
Loc: Ohio
I've heard others recommend that grease in the rc forums. Any idea if it's o-ring safe?
#4690372 - 03/10/18 09:52 AM Re: Grease recommendations for RC car differentials [Re: TAP]
Danno Offline
Loc: Northern Ontario, Canada
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
#4690380 - 03/10/18 10:08 AM Re: Grease recommendations for RC car differentials [Re: TAP]
Planb Offline
Loc: Ontario, Canada
When I raced, we would fill the diff with a heavy silicone fluid, this was done to prevent the unloading of the inside wheels when going around a turn, think of it as a easily adjustable torson differential.
Team Junk
#4690388 - 03/10/18 10:17 AM Re: Grease recommendations for RC car differentials [Re: Planb]
TAP Offline
Loc: Ohio
Yep I use diff fluid in my other vehicle. This particular vehicle doesn't have a sealed diff which is why it requires a grease.
#4690404 - 03/10/18 10:32 AM Re: Grease recommendations for RC car differentials [Re: Danno]
TAP Offline
Loc: Ohio
Originally Posted By: Danno
I have some of this and It's a good grease. I love the fact that it doesn't give off an odor. It's not very sticky which is why I haven't considered it.
#4690436 - 03/10/18 11:05 AM Re: Grease recommendations for RC car differentials [Re: TAP]
Lolvoguy Offline
Loc: Canada
Sure there's many lubricants you can choose from, but I'd be more concerned with it's compatibility with the materials in your RC vehicles.
When I had an RC car, it was the electric type that had vinyl gears. IIRC, the lubricant it used was a water-based grease. shrug
06 Lexus IS350- Wife
88 BMW 325is- Mistress
03 Suzuki SV650S- One night stand
#4690485 - 03/10/18 12:15 PM Re: Grease recommendations for RC car differentials [Re: TAP]
Fsharp Offline
Loc: Kentucky
You might try an open gear grease like Pyroshield syn, but Id also go for the Lucas Red and Tacky. Im not sure any grease will provide meaningful limited slip action for very long. Maybe switch to a ball diff if available?
#4690491 - 03/10/18 12:24 PM Re: Grease recommendations for RC car differentials [Re: TAP]
TAP Offline
Loc: Ohio
The open gear grease is something I just learned about today. Going to look into that brand you mentioned.
Ball diff isn't an option with this truck.
#4690662 - 03/10/18 03:51 PM Re: Grease recommendations for RC car differentials [Re: TAP]
TAP Offline
Loc: Ohio
Going to give this grease a try.
[url=https://www.amazon.com/dp/B000R8EI08/?coliid=I1R389CAX3Z2M2&colid=H3ULXYEUCOAH&psc=0&ref_=lv_ov_lig_dp_it][/url]
Edited by TAP (03/10/18 03:59 PM)
#4690675 - 03/10/18 04:13 PM Re: Grease recommendations for RC car differentials [Re: TAP]
AVB Offline
Loc: Georgia
I might would try some John Deere corn head grease. I would worry about a grease not acting like a fluid, and the gears just spinning freely while the grease stayed put. I can't remember if any of my 1/8 scales have a center diff, I know I have one for a buggy in a box somewhere.
Cavitation would be what I was trying to describe above.
Edited by AVB (03/10/18 04:27 PM)
