Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
TCam, OzFrog, Kursk, DMB, bcrossen
66060 Registered Users
87 registered members (1JCB, 92saturnsl2, A310, Aero540T, 69GTX, 4WD, 15 invisible), 1,590 guests, and 30 spiders.
Topics290,932
Posts4,852,686
Members66,060
Most Online3,590
Jan 24th, 2017
Page 1 of 5 1 2 5
Thinking of weaning off the Amsoil teat #4690009
03/09/18 09:44 PM
03/09/18 09:44 PM
Maryland
malibuguy79 Offline OP
Maryland
Been running Amsoil SS 0-20 and filter on my Yaris since 1500miles. First OC at 1500, next at 7500, then at 15k and ever since then 15k intervals. I am almost at my 140k for my next OC and thinking of switching to stuff I can get at a Walmart.
I am thinking of Pennzoil UP (not because of the banner up top) and the Fram UG. I figure maybe at 10k due a UOA just to see how things look and then extend from there. I did 15k on the Yaris because it was easy to add up. Blackstone had recomended going to 18k on my Amsoil but its a weird number to remember my intervals.
I used to drive 110 miles day 6 days a week. Now I do alot more local driving now (typically 20-30miles) with occasional 100 mile jaunts to my side job.
Greg...the exhaust guy
I have a 10 Yaris, 97 Tercel 1nzfe swap coming, 82 Malibu 1uzfe swap in progress, 84 Bonneville street/strip car
She has 18 Fit and 01 Forester
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690018
03/09/18 09:57 PM
03/09/18 09:57 PM
New England
gathermewool Offline
New England
Alternatively, you could get a UOA of the Amsoil SS at 15k and extend IT from there.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690034
03/09/18 10:15 PM
03/09/18 10:15 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
It sounds like he did.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690038
03/09/18 10:22 PM
03/09/18 10:22 PM
Maryland
Maryland
Im not opposed to either. I will take that into consideration. Id prefer to buy USA when availible
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690057
03/09/18 10:48 PM
03/09/18 10:48 PM
Kansan,1911 45ACP fan
Marco620 Offline
Marco620  Offline
So._.Use Redline oil
15' Civic 179k.0w20 Redline/Archoil9100,Eibach,Yokohama/Borla Exhaust/Tein Suspension/Fu7317/Redline Si-1
Right to work state proud. Non union household
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690058
03/09/18 10:48 PM
03/09/18 10:48 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
I would bet PUP and a FU filter would be down for 15k easy on a Yaris.
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690069
03/09/18 11:11 PM
03/09/18 11:11 PM
Marco620 Offline
Marco620  Offline
Probably if driving conditions were right. A good air cleaner is first priority. I use a injen nano filter wrapped in 2 layer pantyhose and a AEM prefilter
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690071
03/09/18 11:13 PM
03/09/18 11:13 PM
Marco620 Offline
Marco620  Offline
Pennzoil is American. Based in Houston Texas and hires American workers. Same as Toyota. So even if its truly not"American" it still gives employment for Americans.
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690082
03/09/18 11:33 PM
03/09/18 11:33 PM
pa
benjy Offline
benjy  Offline
pa
lots of miles but longer trips are easy on any oil. with many fake synthetics @ about $5 a qt that should work for you. i like mobil I extended performance said to have some PAO in it.
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690090
03/09/18 11:48 PM
03/09/18 11:48 PM
Cincinnati
donnyj08 Offline
donnyj08  Offline
Cincinnati
Mobil 1 0w20EP with an FU filter. The only difference you will notice over Amsoil is a lighter wallet.
2008 Silverado Z71 LT 90k Maxlife FS 5w30
2010 Ford Escape 172k QSUD 5w20
2016 Yamaha XSR900 12k, Rotella 15w40 Yamaha Filter.
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690115
03/10/18 12:18 AM
03/10/18 12:18 AM
The land of USA-made Subies!
SubieRubyRoo Offline
I drive about 21 miles each way to work about 22 days a month and a 200-mile round trip twice a month. My last UOA on PUP [email protected] showed just a little thickening ([email protected]) but TBN was still 2.9, with zero makeup oil. Iíd go 15k and not even UOA it. Iím so happy with PUP in my application, Iíve got another 150k worth of it sitting on the shelf smile
Add: I have run FU, MicroGreen, Amsoil, and Napa Platinum filters. No statistically significant change in UOAs over the past 100k, all on Pennzoil synthetics. Iron is at 1ppm/1k miles over the past 100k. Thats pretty solid in my book!
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690174
03/10/18 05:14 AM
03/10/18 05:14 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
As an old time user of Amsoil products I feel their advantage is long gone now. There was a time when they had a clear edge over the regular oils you could buy. Now they do not.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690189
03/10/18 06:16 AM
03/10/18 06:16 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
There are other oils as good as Amsoil at Walmart. Forget the Blackstone comments on your UOA. NAPA UOA kits are better and less $$. (I still buy Amsoil ATF and gear oils, so not a Amsoil basher).
2015 Ford F250 w/Powerstroke
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690223
03/10/18 07:38 AM
03/10/18 07:38 AM
Minnesota
leje0306 Offline
leje0306  Offline
Minnesota
I recently did this. Itís not that I donít think Amsoil isnít a great, if not the ďbestĒ oil, itís just that the edge isnít what it used to be and certainly no longer justifies the price premium.
Re: Thinking of weaning off the Amsoil teat [Re: malibuguy79] #4690226
03/10/18 07:41 AM
03/10/18 07:41 AM
Finland
Bjornviken Offline
Bjornviken  Offline
Finland
Depends how you use the car and where you live. For me Amsoil is better then anyting i have used in the past but i live near artic cirkle. Before when i used other brand i did have problems with the crank case ventilation but with Amsoil noting! So i did stay with Amsoil.
And amsoil is cheap for a pao oil.
Amsoil Motul and Redline are outstanding oils.
Page 1 of 5 1 2 5
