Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
70 registered members (330indy, alphadog, AP9, Ag76, anndel, andyd, 6 invisible), 1,346 guests, and 38 spiders.
Topics295,007
Posts4,925,839
Members66,664
Most Online2,553
Oct 27th, 2018
Thinning Down Grease #4690002
03/09/18 08:35 PM
03/09/18 08:35 PM
San Antonio, TX
das_peikko Offline OP
San Antonio, TX
The most common grease has an NLGI viscosity of 2. I haven't been able to find any NLGI 00 grease, so this afternoon I was trying to thin down some NLGI 2 grease with Walmart SAE 30 oil. I was absolutely amazed by how much oil it takes to thin down grease. You almost have to mix it 50/50 to get it freed up. I'm trying to make NLGI 00 grease when I actually have never seen NLGI 00 grease. All I've heard is that it's closer to an apple sauce consistency.
Re: Thinning Down Grease [Re: das_peikko] #4690011
03/09/18 08:46 PM
03/09/18 08:46 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I'm no professor in this topic, but wouldn't an EP gear lube be more appropriate for this endeavor.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 103K Napa 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 35k PP MIX, NG7047
Re: Thinning Down Grease [Re: Dyusik] #4690017
03/09/18 08:56 PM
03/09/18 08:56 PM
San Antonio, TX
San Antonio, TX
Good question. The application is the bevel gears inside a 4.5 inch right angle grinder. Gear oil would be ideal, but the gear case is not completely sealed like a gearbox is in a car. Spinning at 11,000 RPM, the gears are going to throw the gear oil out.
Re: Thinning Down Grease [Re: das_peikko] #4690050
03/09/18 09:40 PM
03/09/18 09:40 PM
NJ, USA
MotoTribologist Offline
NJ, USA
I believe Dyusik was referring to using EP gear oil as the diluent instead of SAE 30 engine oil. An engine oil like that will offer little to no extreme pressure protection. Bevel gears usually take some high loads, though I'm not familiar with the forces on the parts of an angle grinder, so maybe I'm mistaken.
Re: Thinning Down Grease [Re: das_peikko] #4690228
03/10/18 06:44 AM
03/10/18 06:44 AM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
Think twice, speak once.
Re: Thinning Down Grease [Re: das_peikko] #4690366
03/10/18 09:45 AM
03/10/18 09:45 AM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
If you have a Snapper OPE dealer near you, they all have "00" grease for the Snapper equipment. They may sell you a small amount if you bring your own container. I always stocked it in quart bottles.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Thinning Down Grease [Re: das_peikko] #4690502
03/10/18 12:36 PM
03/10/18 12:36 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have always just added a tablespoon of STP.
yes, it weeps at the seam a little.... but nothing to really complain about.
It will NOT "Fly off" the gears!!
Re: Thinning Down Grease [Re: MotoTribologist] #4690522
03/10/18 12:58 PM
03/10/18 12:58 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
There's never more than just a minuscule dab of grease from the factory.
They need a good tacky lube, Like the STP I put in there.
Re: Thinning Down Grease [Re: Linctex] #4690882
03/10/18 08:29 PM
03/10/18 08:29 PM
San Antonio, TX
San Antonio, TX
I've tried all kinds of different greases inside the grinder. Every time I flip the switch to ON the gear housing would immediately get super hot. So last night just for giggles, I removed all the grease from the gear case. Now it runs cool as a cucumber. smile
Re: Thinning Down Grease [Re: das_peikko] #4690952
03/10/18 09:50 PM
03/10/18 09:50 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
No thermal transfer happening?
I always add a little extra lube to the angle grinder gear case,
I have never had one "get hot" as a result.
Re: Thinning Down Grease [Re: das_peikko] #4691146
03/11/18 07:04 AM
03/11/18 07:04 AM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
NLGI #00 grease is available from most of the oil and grease suppliers. Check with dealers that sell in farm and industrial equipment as I know that many gear cases in farm equipment use a 00 grease. Trying to thin a #2 grease with engine oil most likely won't work out well. I would think that WW Grainger would have a #00 grease as they do sell Mobil lubricants.
Re: Thinning Down Grease [Re: das_peikko] #4702376
03/21/18 06:23 PM
03/21/18 06:23 PM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
I thinned out some moly paste with synthetic ATF and it worked well. Just used too much ATF in the mixture.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
