Patman
Staff member
Here are the first oil analysis results for my 2018 Corvette, analysis done by Wearcheck Canada:
Mobil 1 5w30 (factory fill)
AC Delco PF64 oil filter
1,111 miles on oil
Nov, 2017 to Mar 3, 2018 (4 months)
1,111 miles total
7 quart oil capacity
No make up oil
Iron 48
Lead 3
Aluminum 4
Copper 36
Chromium 1
Nickel 0
Tin 1
Silver 0
Vanadium 0
Silicon 124
Potassium 6
Sodium 5
Moly 151
Boron 82
Calcium 1217
Magnesium 446
Manganese 2
Titanium 0
Phosphorus 623
Zinc 771
Soot 0
Glycol 0
Water 0
Fuel 2%
Viscosity at 100c 9.3
Viscosity at 40c 51.3
Viscosity Index 165
I put in Mobil 1 5w30 again and an AC Delco PF64 filter. Hopefully on the next oil change I will be able to find the new Mobil 1 0w40 ESP that is now the factory fill on the 2019 Corvettes (which went into production the last week of January) I will probably do the second oil change as soon as I can get that new oil, it's slated to hit retail outlets the end of this summer (GM dealers were supposed to start getting it Feb 1st, but very few of them have it so far)
GM calls for a 500 mile oil change on the dry sump Corvettes but mine is the wet sump and they don't call for that early change but I'm glad I decided to do mine early, with the high amount of silicon (from new gaskets and assembly lube) and the little bit of fuel (I'm sure the engine got started and shut off cold a few times before it arrived at the dealer, and probably had a lot of idling too)
Iron is high, copper is high, but both of those will settle down once the engine breaks in.
1,111 miles on oil
1,111 miles total
No make up oil
Iron 48
Lead 3
Aluminum 4
Copper 36
Chromium 1
Nickel 0
Tin 1
Silver 0
Vanadium 0
Silicon 124
Potassium 6
Sodium 5
Moly 151
Boron 82
Calcium 1217
Magnesium 446
Manganese 2
Titanium 0
Phosphorus 623
Zinc 771
Soot 0
Glycol 0
Water 0
Fuel 2%
Viscosity Index 165
