B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
112 registered members (53' Stude, 02z, 77GrandPrix, 240_Ed, 14 invisible), 2,416 guests, and 36 spiders.
Topics296,878
Posts4,960,726
Members66,987
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
Charge New Battery? #4689639
03/09/18 01:46 PM
03/09/18 01:46 PM
Rockwall, Texas
Old Mustang Guy Online content OP
Old Mustang Guy  Online Content OP
Rockwall, Texas
My wife bought a new Highlander just two weeks ago. I have read here that charging a battery can make it last longer. Last night I put my charger on her battery. I was shocked that it only showed 50 percent charge. Could sitting on a lot cause this? She had taken one trip of about 50 miles. It showed full charge after about 4 hours on 4 amps.
Re: Charge New Battery? [Re: Old Mustang Guy] #4689642
03/09/18 01:49 PM
03/09/18 01:49 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Depending on your particular charger, the reported "only 50%" charge state may be misleading. But it is possible that the battery got depleted quite a bit during extended sitting if the dealer did not keep it topped off. Modern car electronics do eat up batteries faster.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Charge New Battery? [Re: Old Mustang Guy] #4689643
03/09/18 01:51 PM
03/09/18 01:51 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
A battery will slowly discharge if a vehicle isn't driven. How much depends on the slight draw going on while sitting. When I park my car for winter it gets the battery tender put on every 2~3 weeks to keep the battery fully charged.
Re: Charge New Battery? [Re: Old Mustang Guy] #4689648
03/09/18 01:59 PM
03/09/18 01:59 PM
New England
gathermewool Offline
New England
What was the actual resting voltage. I've got a smart charger and I don't trust its initial reading. For instance, it will indicate somewhere around 90% charged after I just charged it, after turning the headlights on for a minute. As soon as it charges, it goes very quickly to high 90's and then 100%.
I believe I was told before that specific gravity is a better way of determining state of charge. Is that right?
Finally, yes, a battery can deplete while on the lot, both due to parasitic drain, starting and stopping the engine quickly while moving it around the lot, or while people hop in to check it out, but not test-drive it.
I've seen new cars with the plastic still on them need to be jumped after possibly being subjected to the above.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Charge New Battery? [Re: Old Mustang Guy] #4689660
03/09/18 02:17 PM
03/09/18 02:17 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
I charge every new battery I buy. I trickle charge 2 amps for up to two days.
Re: Charge New Battery? [Re: Old Mustang Guy] #4689668
03/09/18 02:23 PM
03/09/18 02:23 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I charge every new batter with a battery minder or trickle charger. Ed
CX5 Touring 2.5L :-)
Re: Charge New Battery? [Re: Old Mustang Guy] #4689675
03/09/18 02:33 PM
03/09/18 02:33 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
If you charge it up you'll be in the less than 1% crowd that does such a thing.
Re: Charge New Battery? [Re: Old Mustang Guy] #4689677
03/09/18 02:34 PM
03/09/18 02:34 PM
california
wrcsixeight Offline
wrcsixeight  Offline
california
The state of charge reading on so called 'smart' chargers, is based solely on the voltage it sees from the battery when first hooked up and plugged in.
This number can be wildly inaccurate depending if the battery was just charged or discharged and the battery itself. I have an AGM which fully charged rests at 13.06v. I have a flooded battery which rests fully charged at 12.67v
All lead acid batteries want to be kept cool and fully charged, always.
A temperature compensated hydrometer sampling the specific gravity of a 12v battery's 6 cells is quite accurate as to state of charge, an batteries whose electrolye can be accessed, but Specific gravity can vary from battery to battery from 1.260 to 1.310, so a baseline for comparison is needed.
Most smart chargers actually stop charging the battery at about 92 to 95% charged, and drop to a float/ maintenance voltage. Charging does still occur at these lesser electrical pressures but it is much much slower and aged batteries might never reach 100% charged at these lesser voltages, no matter how long the float voltage is applied.
92 to 95% charged can be 'just fine' for most, but a true 100% achieved regularly would have the battery last significantly longer.
LA 318 Roller Cam
Pennzoil Platinum 10w-30 SN Plus
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
Re: Charge New Battery? [Re: Old Mustang Guy] #4689779
03/09/18 04:33 PM
03/09/18 04:33 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I think it probably needed charging, but reading from charger is suspect.
2015 Ford F250 w/Powerstroke
Re: Charge New Battery? [Re: Old Mustang Guy] #4689780
03/09/18 04:33 PM
03/09/18 04:33 PM
Rockwall, Texas
Rockwall, Texas
Thanks. I suspect the 50 percent was an error but it did take a significant charge. I've learned a lot about batteries here.
Re: Charge New Battery? [Re: Old Mustang Guy] #4689787
03/09/18 04:38 PM
03/09/18 04:38 PM
New England
New England
Is the charger putting out 4A the whole time? Even if it did, I wouldn't consider 16A-Hrs to be significant. That may be only 25% or less depleted.
Re: Charge New Battery? [Re: Old Mustang Guy] #4689797
03/09/18 04:53 PM
03/09/18 04:53 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I always charge a new one. I have some for sale at work. I put them on a charger once a month or so.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Charge New Battery? [Re: Quattro Pete] #4689807
03/09/18 05:00 PM
03/09/18 05:00 PM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
It's somewhat useful having a reading like that, but for the most part it's only a rough estimate. When you start it up all that it really has is a voltage reading that it's correlating with expected charge percentage. I've got one myself (a Schumacher SC-1200A-CA) and I take those readings with a grain of salt. You get a surface charge that will go away overnight. I mean - I can try to top it off in the morning after fully charging it the night before, and it's reading 80-85%.
Now I do believe that the voltage reading when it's not charging should be accurate. I'm not sure it's terribly practical to charge batteries on the lot. Now I suppose a good thing to do would be to charge up the battery while it's being prepped for the customer with something like a wheeled shop charger.
Re: Charge New Battery? [Re: Chris142] #4689810
03/09/18 05:06 PM
03/09/18 05:06 PM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
How do you do it? I've just placed the clamps straight on the terminals, but then I checked my charger's manual for the recommended procedure. It recommended using a ground cable as an extension to avoid making the connection (and possibly sparking) right at the battery. When I connect it to the ground (my usual point is at a grounding wire on my wife's Civic) for normal in-vehicle charging I can see it spark.
Re: Charge New Battery? [Re: Old Mustang Guy] #4689813
03/09/18 05:06 PM
03/09/18 05:06 PM
CA
raytseng Offline
raytseng  Offline
CA
standard toyota delivery checklist. Heres a link.
https://www.donvalleynorthtoyota.com/faq/pdi.htm
It includes checking state of charge of the battery.
New cars sitting on the lot sgoulf have batteries disconnected so the parasitic drain shouldnt be an issue
Page 1 of 3 1 2 3
