My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned - I let someone else change my oil
by 901Memphis. 12/15/18 01:57 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
45 registered members (Anduril, 2004tdigls, anndel, Aero540T, Artem, 4 invisible), 1,384 guests, and 37 spiders.
Topics295,133
Posts4,928,313
Members66,691
Most Online2,553
Oct 27th, 2018
What Blades for 48 inch John Deere Deck? #4689626
03/09/18 01:36 PM
03/09/18 01:36 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
We are using what I believe to be a pieced together John Deere LX178 at church. I don't think this 48 inch deck came with this LX178 originally. Now, I want to get new blades but I want to get the correct blades. Stopped by the local JD dealer and he said I needed to get the numbers off the blades on the mower to get replacements. I asked him how can I find out what the correct blades for that deck would be. He said he didn't know if the deck did not come with the mower to begin with.
I'm having a problem with his answer. Can anybody steer me in the right direction?
If it helps the mower is a LX178 water cooled Kawasaki. The deck has a logo that says "48 mulcher compatible"?
Maybe I should try another dealer????
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: What Blades for 48 inch John Deere Deck? [Re: Gebo] #4689644
03/09/18 01:53 PM
03/09/18 01:53 PM
Madison, Wisconsin
TWG1572 Offline
TWG1572  Offline
Madison, Wisconsin
The LX178's did come with a 48" deck. The standard blade for that deck is M115495. There are also discharge and high lift options. JDPartsis a good resource if you want to look for all the parts for a specific model.
All my JD blades also have the part number stamped in them. Which is probably why he sent you that way when you indicated you didn't know if the deck was original to the tractor or not.
Some decks do have a serial and model number tag. Might be something to check too.
Re: What Blades for 48 inch John Deere Deck? [Re: Gebo] #4689655
03/09/18 02:10 PM
03/09/18 02:10 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I use greenpartstore.com, which is a great place to find what blades your mower will need. For what it's worth, I've found the Oregon Gator blades have provided a better cut and lasted much longer than the OEM blades on my G110 Deere.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: What Blades for 48 inch John Deere Deck? [Re: Gebo] #4689659
03/09/18 02:14 PM
03/09/18 02:14 PM
Madison, Wisconsin
TWG1572 Offline
TWG1572  Offline
Madison, Wisconsin
I've found the Gator blades to be pretty dependent on deck design. I run the G5's now, but had the same model on a different deck and they were horrible.
GreenPartsStore is where I shop too. Good prices, and since I live close I often get parts mailed through them faster than I can get from my local dealer.
Re: What Blades for 48 inch John Deere Deck? [Re: Gebo] #4689661
03/09/18 02:17 PM
03/09/18 02:17 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Well, my "guy" just texted me. I'm going to have to replace a spindle at over $100. The JD hood is broken all to pieces. I'm gonna start another thread. Thanks to all of your input.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: What Blades for 48 inch John Deere Deck? [Re: Gebo] #4689681
03/09/18 02:38 PM
03/09/18 02:38 PM
Virginia
mattwithcats Offline
Virginia
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: What Blades for 48 inch John Deere Deck? [Re: Gebo] #4689940
03/09/18 07:19 PM
03/09/18 07:19 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I don't need anymore responses as I am getting rid of this mower. Thanks to ALL!
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
