Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
27 registered members (BlakeB, 53' Stude, Ablebody, Duke, Drosselmier, 4 invisible), 762 guests, and 39 spiders.
Topics290,746
Posts4,849,464
Members66,033
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
European HDEO users in Gasoline engines? #4689607
03/09/18 02:03 PM
03/09/18 02:03 PM
Balearic Islands , Spain
FordCapriDriver Offline OP
So in the US it's quite common for people to use HDEO's in older cars, but that does not seem so common on this side of the pond.
I'm probably going to swith over to Shell Rimula R4X 15W-40 HDEO ( SL, CI-4 ) for both my Fords ( the Escort already is )
Anybody else using other HDEO's in Petrol engines on the old continent?
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4689628
03/09/18 02:37 PM
03/09/18 02:37 PM
Greece
Panos Offline
Panos  Offline
Greece
What is that you hope gaining with the switch?
Ford fiesta 1.6 mk6 Motul specific 913D/Motul Gear 300
Kawasaki ninja 250r Motul 5100 10w40
Honda cbr600f Pc41 Motul 7100 10w30
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4689712
03/09/18 04:16 PM
03/09/18 04:16 PM
Well, it's cheap first of all, just 23 for a 5L Bottle.
Also since they both have traditional flat tappet cams, Rimula R4X contains 1250ppm of Zddp, which is quite good.
On the Capri the oil pressure it has when cold is a little too high with 20W-50, while when hot i believe a 15W-40 HDEO should give similar oil pressure, with the Capri specially now in winter i've done a few cold starts on it at 0C or near, and i have to drive it pretty slowly until it warms up, just because i don't want to strain the oil pump shaft that drives the oil pump in the old Ford V6.
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4689760
03/09/18 05:21 PM
03/09/18 05:21 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Meh.....I will spare Rimula R6M 10w40 for next OCI for Toyota....it is essentially almost a truck (not by Yenkee standards though) smile
And will leave SHU 5w40 and Elf nf900 5w40 for my car.....acea A3/B4 is more then stout enough for that job
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4689846
03/09/18 06:49 PM
03/09/18 06:49 PM
Bristol, Tennessee
Jett Rink Offline
Jett Rink  Offline
Bristol, Tennessee
I can tell you that it is fairly common for drivers of older Mercedes gas engine cars here in the USA to use an HDEO 15w-40. By older, I mean ones manufactured in around 1995, or earlier. It is typically either Rotella, Delo or Delvac 15w-40. But some prefer 20w-50 conventional or a 5w-40 or 0w-40 synthetic.
1987 Mercedes 300E 87,000 miles 15w-40
2012 Honda Odyssey 120,000 miles 0w-20
2000 Mercedes CLK320 170,000 miles 0w-40
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4689856
03/09/18 06:59 PM
03/09/18 06:59 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I use Delvac 15W40 in a 1 litre Daihatsu.
I'm not European any longer but as far as I can tell that isn't why.
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4689998
03/09/18 09:32 PM
03/09/18 09:32 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I run 15W-40 HDEO in almost every engine on my ranch.
Re: European HDEO users in Gasoline engines? [Re: Linctex] #4690170
03/10/18 04:54 AM
03/10/18 04:54 AM
Hmm, the last time i checked a map Waco, Texas was not in Europe lol
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4690195
03/10/18 06:37 AM
03/10/18 06:37 AM
Frogland / Brittany
Popsy Offline
Popsy  Offline
Frogland / Brittany
Well, I used Rimula R6M in my diesel, but gave up for availability reason. Most of HDEO I can find easily now are on the energy conserving side, and that's not really what my cars need!
But if you can find R4X 15W-40 for cheap, it'll be better than other 15W40 like Total Quartz 3000/5000 or equivalent. Maybe not in the 106, because of the cat though ?
96 Barchetta, Motul 300V 5W40 | 98 Barchetta, Quartz 9000 energy 5W40
05 Forfour 95, SHU 0W40 (gf's car) | 10 Colt Ralliart, 300V 0W40
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4690242
03/10/18 08:00 AM
03/10/18 08:00 AM
That's exactly what i was thinking.
Nope not gonna use it in the 106, it's i believe a medium or full SAPS oil with 1250ppm of Zddp and i don't want to clog up the cat on it since it does burn some oil.
Re: European HDEO users in Gasoline engines? [Re: Jett Rink] #4690323
03/10/18 09:57 AM
03/10/18 09:57 AM
maple ridge, bc
2004tdigls Offline
2004tdigls  Offline
maple ridge, bc
I use an HDEO in my 2001 ML 320 (what ever is on sale at the time of purchase), my OCI is 6 months or every 5000 miles
its still running........... LOL
Re: European HDEO users in Gasoline engines? [Re: Popsy] #4690567
03/10/18 02:50 PM
03/10/18 02:50 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
https://m.autodoc.co.uk/shell/12754630
banana
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4690679
03/10/18 05:19 PM
03/10/18 05:19 PM
Frogland / Brittany
Popsy Offline
Popsy  Offline
Frogland / Brittany
Thanks! But the price...for the price of the 5L jug I have almost 4L of 300V^^
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4690866
03/10/18 09:10 PM
03/10/18 09:10 PM
OH
fdcg27 Online content
fdcg27  Online Content
OH
Not sure what that poster's geographic location has to do with whether or not a 15W-40 HDEO is suitable for an old Euro car.
Many Euro and Brit oldies speced a 20W-50 for warm weather conditions and many drivers of the older machines find a 15W-40 HDEO to be very suitable, particularly since these oils offer well over the 3.5 HTHS required by most more modern manufacturer's certs and they also feature low volatility, much lower than the Grp III 5W-40 HDEOs that some use instead.
I've used Delvac 1300 in my old BMW with good results, for example.
What I have to chuckle about is how you guys get hosed on motor oil.
Over here, Shell Rotella T4 would be the equivalent oil and it can be bought for $12/gal, which translates to around E11.40, or around E2.85/liter.
There are also current MIRs on Rotella, Delvac and Delo HDEOs ATM that make them even cheaper.
In any car that called for a PCMO 20W-50 or an A3/B3 forty grade, a 15W-40 HDEO would make a great deal of sense in terms of both performance and cost.
A straight SAE 30 or 40 might be a good alternative as well for warm weather use, since these grades offer both plenty high HTHS as well as very low volatility, although I don't know how available those grades are in Europe.
You can buy Shell Rotella SAE 30 all day every day at Walmarts here, and you'd also be able to get the MIR.
17 Forester 12K MSS 0W-20
12 Accord LX 92K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: European HDEO users in Gasoline engines? [Re: FordCapriDriver] #4691052
03/11/18 02:15 AM
03/11/18 02:15 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
1) since we (over the pond) dont own the middle east smile our oil stash comes a little pricier here...
HDEOs: https://www.mimovrste.com/iskanje?s=Rimula
PCMOs:https://www.mimovrste.com/motorna-olja
2) Yes we know/have monogrades...a.k.a lawnmover oils smile Can be had from 5-8euros/L...but thats not a common practice here to put lawnmover oil into a car engine smile
Page 1 of 4 1 2 3 4
