What new make/model is easiest to work on?
by AshleyQuick
8 minutes 20 seconds ago
Compact Spare Tire Air Pressure
by das_peikko
21 minutes 25 seconds ago
[Cut Open] Denso 150-2006 - Virgin
by DuckRyder
26 minutes 35 seconds ago
What additives in oil are bad for wet clutches?
by ZZman
Today at 05:48 PM
Tire wear - is this usual?
by mjk
Today at 05:38 PM
GM 3800 Traction Control Reduced power
by clarkflower
Today at 04:40 PM
Uncharted territory for oils in odd weights
by Marco620
Today at 04:39 PM
I got the leak on my cruze 1.4T fixed for free
by 901Memphis
Today at 04:36 PM
Longer spring hangers for landscape trailer
by motor_oil_madman
Today at 04:30 PM
My ATF never gets Hot?
by Gebo
Today at 03:59 PM
**FREE** Case of DENSO 150-2006 oil filter
by Hootbro
Today at 03:56 PM
Draining water heater - tips?
by HawkeyeScott
Today at 03:38 PM
Harley oil in Kawasaki?
by mvent
Today at 03:28 PM
Anyone used Meguiars DA Power System?
by Stewie
Today at 02:18 PM
Cars CR Thinks Will Last 200K Miles
by knerml
Today at 02:04 PM
How to get unavailable original recordings
by grampi
Today at 01:37 PM
How much snow you got?
by car51
Today at 01:36 PM
Update: Internet Plans - The Good, Bad, Ugly !?!?
by GemStater
Today at 01:11 PM
2012 Porsche Cayenne 3.6 V6 Oil Choices
by csufl
Today at 01:05 PM
Properly ventilating a Pole Barn
by SOHCman
Today at 12:54 PM
john19718, junp, hbsprite, tomcor, csufl
64521 Registered Users
101 registered (4WD, 1JZ_E46, 901Memphis, 2K2AcuraTL, 14Accent, 14 invisible), 1671 Guests and 95 Spiders online.
64521 Members
68 Forums
280200 Topics
#4689524 - 03/09/18 11:09 AM Penrite 10tenths and some white butter
frost1978 Offline
Loc: Poland
also at the bottom of the original bottle.I tested several oils (-20 degrees) and I met such a thing only in valvoline.
#4689545 - 03/09/18 11:28 AM Re: Penrite 10tenths and some white butter [Re: frost1978]
edwardh1 Offline
Loc: Coastal South Carolina
-20 is cold
Prius? In line water heater? Solar?
All save energy, but may not save money (complicated, no DIY, parts hard to get, , parts expensive, etc).
#4689557 - 03/09/18 11:48 AM Re: Penrite 10tenths and some white butter [Re: edwardh1]
supton Offline
Loc: NH
Originally Posted By: edwardh1
-20 is cold
-20C is -4F, so yeah, getting a bit nippy.
2011 Toyota Camry, base, 2.5L/6MT, 156k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 141k, ours
1999 Toyota Camry LE, 2.2L/4AT, 174k, his
#4689608 - 03/09/18 01:06 PM Re: Penrite 10tenths and some white butter [Re: supton]
aquariuscsm Offline
Loc: South Texas,USA
-20 is cold
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
QSUD 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 0W20
#4689809 - 03/09/18 05:05 PM Re: Penrite 10tenths and some white butter [Re: frost1978]
SR5 Offline
Loc: Down Under
You get Penrite in Poland ?
Given Penrite 10-Tenths is mostly PAO and some ester, it's definitely the add pack, not the base oil IMO. These threads come along regularly with all brands, sometimes its low storage temperature, sometimes it's a bit of moisture in the oil attaching to a particular add. Sometimes it's white and fluffy, sometimes it's black and small.
Me ? I would just pour it in the engine and use it, milky bits and all. The engine will quickly heat and remix the oil, driving off any moisture (if present). I've heard of people warming and shaking oil, but I just let the engine do the work for me.
Most add packs have a treatment rate such that they can last a long oil change interval, this means they start out generous, so that the oil is still OK 10k miles later after some of the add packed is depleted or used. So it's not like all the add pack needs to be instantly available, it has a reserve, so letting the engine mix some of it back in isn't a problem to me.
BTW -20C is very cold for Australia, that oil would never see those low temps here. Which viscosity grade is it ?
And Welcome !!
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4693237 - 03/13/18 09:36 AM Re: Penrite 10tenths and some white butter [Re: frost1978]
frost1978 Offline
Loc: Poland
Yes, is available in Poland.
This is 5w50 10tenths. Maybe it's a fake oil but bottle is 100% original.
