Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
95 registered members (addyguy, andyd, Bailes1992, ARCOgraphite, BamaE92, 12 invisible), 1,795 guests, and 71 spiders.
Topics286,446
Posts4,908,468
Members67,626
Most Online2,967
Mar 10th, 2019
How to clean an antique shotgun stock? #4689356
03/09/18 08:10 AM
03/09/18 08:10 AM
California
Ed_Flecko Online content OP
Ed_Flecko  Online Content OP
California
I have a Winchester Model 12 manufactured in 1923 that I inherited.
I'd like to clean the stock to reveal the beauty of the wood without ruining the value of the gun.
Suggestions on how to properly/safely clean the stock?
Thank you!
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4689363
03/09/18 08:34 AM
03/09/18 08:34 AM
Clinton Twp. MI
bradepb Offline
bradepb  Offline
Clinton Twp. MI
I have a couple almost 100 year old guns that I inherited. They were stored poorly in a humid basement. I only wiped them down with WD-40 and called it good. A lot of the surface rust came off the barrels and gunk off the stocks anything more and I fear I would ruin the patina and history.
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4689382
03/09/18 09:11 AM
03/09/18 09:11 AM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
I used Guardsman Lemon Oil on my 1930 LC Smith double barrel shotgun. Rub a few drops into the wood with your finger tips and buff with a soft cloth. Repeat several times. It will clean the finish without harming it. I got mine off Amazon for about $10 shipped.
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4689389
03/09/18 09:22 AM
03/09/18 09:22 AM
Ontario, Canada
newbe46 Offline
newbe46  Offline
Ontario, Canada
I second lemon oil although I've only used it to clean the fretboard of a guitar, I don't see the stock being anything different, they are still wood.
2003 E46 M3 Convertible
2004 Odyssey EX-L
2004 Impreza TS Wagon
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4689438
03/09/18 10:22 AM
03/09/18 10:22 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
The Model 12 is a jewel in the shot gun world . I have one and it is a keeper.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4689450
03/09/18 10:35 AM
03/09/18 10:35 AM
Ohio
jjjxlr8 Offline
jjjxlr8  Offline
Ohio
Have you tried just a *barely damp* cloth? I'd start with that. Pictures of what it looks like now might be helpful.
1993 Toyota MR2 Turbo
2008 Mazdaspeed3
2014 Toyota Highlander XLE
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4689458
03/09/18 10:47 AM
03/09/18 10:47 AM
PimTac Offline
PimTac  Offline
I would check out some old gun forums or find someone in your area that is knowledgeable. Doing the wrong thing could detract from the value of the gun.
Cannot see signatures any longer so it doesn’t matter.
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4689468
03/09/18 11:02 AM
03/09/18 11:02 AM
Glendale, Arizona
billt460 Online content
billt460  Online Content
Glendale, Arizona
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4689843
03/09/18 06:44 PM
03/09/18 06:44 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
Renaissance Wax
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4690036
03/09/18 10:17 PM
03/09/18 10:17 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I think old rifle stocks use linseed oil or tung oil. Definitely look on the forums before doing anything for advice.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4690093
03/09/18 11:52 PM
03/09/18 11:52 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Ren Wax. It's what is used on museum pieces.
Re: How to clean an antique shotgun stock? [Re: Ed_Flecko] #4690107
03/10/18 12:12 AM
03/10/18 12:12 AM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
The wood finish should be gently cleaned before any wax is applied.
Re: How to clean an antique shotgun stock? [Re: gman2304] #4690133
03/10/18 01:09 AM
03/10/18 01:09 AM
Georgia
AVB Offline
AVB  Offline
Georgia
That is correct, George (noremf) on rimfire central has some excellent post about this type of work. He suggests using bottled water with a couple drops of dish soap and a cloth, rinse with bottled water, let dry and repeat. Then use 100% mineral spirits. This process is supposed to be safe for any type of top coat.
Re: How to clean an antique shotgun stock? [Re: billt460] #4690141
03/10/18 01:46 AM
03/10/18 01:46 AM
Ohio
jjjxlr8 Offline
jjjxlr8  Offline
Ohio
Originally Posted By: billt460
Holy [censored]! Don't do that to a collectible rifle! He severely reduced the value of that firearm to most purist collectors.
I bet he sold more products, though!
2008 Mazdaspeed3
Re: How to clean an antique shotgun stock? [Re: jjjxlr8] #4690164
03/10/18 03:27 AM
03/10/18 03:27 AM
Glendale, Arizona
Glendale, Arizona
Originally Posted By: Ed_Flecko
I'd like to clean the stock to reveal the beauty of the wood without ruining the value of the gun. Suggestions on how to properly/safely clean the stock? Thank you! Ed
You're either going to clean the thing, or you're not. The OP has stated in his first post that he wants to, "clean the stock to reveal the beauty of the wood". This thing isn't an original Walker Colt. Old Model 12's are a dime a dozen, just like Remington Rolling Blocks. There were over 2 million of them produced.
