Originally Posted By: das_peikko
From Amsoil:
2005 SUBARU LEGACY 2.5L 4 -cyl Engine EJ255 Turbo
Subaru has published Service Bulletin # 02-103-07 that identifies a factory design related problem with premature clogging of the oil mesh screen located inside the oiling system that supplies the turbo charger on all model turbo charged cars. A clogged screen will result in oil starvation and turbo charger failure. Subaru has since published Service Bulletin #02-110-10R indicating that 2010 MY and prior turbocharged engines continue to require oil and filter change intervals of 3,750 miles (6,000 km) or 3 3/4 months, while all 2011 MY turbocharged engines have returned to the original requirement of 7,500 miles (12,000 km) or 7 1/2 months, and they are required to use synthetic oil. Due to the issues outlined in this document, AMSOIL recommends following Subaru drain interval recommendations.
VISCOSITIES:
All TEMPS....5W-30 SAE 5W-30 is preferred.
Above -4 F .10W-30, 10W-40
CAPACITIES: With filter 4.4 quarts After refill check oil level.
TORQUES: Oil Drain Plug...33 ft/lbs
Interesting TSB, so instead of addressing the part in question, they shorten the OCI.
OT-33 ft/lbs torque on a drain plug seems high.........
