stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
101 registered members (Alfred_B, AZjeff, BeerCan, 2015_PSD, anndel, 15 invisible), 1,806 guests, and 65 spiders.
Topics286,431
Posts4,908,117
Members67,622
Most Online2,967
Mar 10th, 2019
PGL in dexcool application? #4689043
03/08/18 08:10 PM
03/08/18 08:10 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Has anybody run into troubles running Peak Global Lifetime in any application its rated for? Specifically, I suppose, I will be doing a rad drain and refill this spring in my F150 which takes the orange Ford dexclone. Any reason to avoid using this coolant?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: PGL in dexcool application? [Re: buck91] #4689053
03/08/18 08:16 PM
03/08/18 08:16 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
As long as you get all the old fluid out the peak will work great. I didn't know there was any reason to avoid Dexcool in the newer systems I thought they were designed properly?
I would also consider G05/Motorcraft Gold if you're open to other stuff, I run G05 in my Buick.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: PGL in dexcool application? [Re: buck91] #4689300
03/09/18 04:36 AM
03/09/18 04:36 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I have read that Dex-Cool has long since been changed. It's not the same Death-Cool that is was when it was developed, from the early 90's-whenever!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: PGL in dexcool application? [Re: buck91] #4689354
03/09/18 08:03 AM
03/09/18 08:03 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
I can't think of any. Like Ford orange Dexcool, it's a Long Life OAT AF. Difference is, it contains no 2eha inhibitor used in DexCool. I've been running it for several years now in an older Tacoma originally specing Toyota red. Original radiator and working great.
That said, unless you just prefer PGL, it's significantly less expensive or you just happen to have it on hand, DexCool will work equally well in the Ford vehicles that now spec it.
Re: PGL in dexcool application? [Re: buck91] #4689593
03/09/18 01:31 PM
03/09/18 01:31 PM
California
nthach Offline
nthach  Offline
California
We don't know the organic acid Peak/CCI uses in Peak Global Lifetime. It's also well-regarded here and CCI is one of the main coolant players in North America and Japan.
In theory all the OATs should play nice with each other. Ford does have an aversion to AMAM coolants but I don't see why not if the car came with orange coolant from the factory - and Prestone's formulation is more or less yellow-dyed Dex-Cool.
Re: PGL in dexcool application? [Re: buck91] #4689653
03/09/18 03:08 PM
03/09/18 03:08 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
'Fwiw' PGL uses Sodium Benzoate as it's organic acid. I have a partial jug here showing that. Wouldn't change my original post recommendation here, and was known to me before that post.
If I was going to use a Prestone AF in the OP's vehicle, it would their Dexcool labeled product, not the 'universal dexclone'. The latter now called Prestone with Core Guard.
Re: PGL in dexcool application? [Re: buck91] #4689842
03/09/18 06:40 PM
03/09/18 06:40 PM
California
nthach Offline
nthach  Offline
California
Prestone does make an officially GM sanctioned Dex-Cool, it's in the silver bottle. Prestone in itself is a Dex-clone.
Re: PGL in dexcool application? [Re: buck91] #4694001
03/13/18 09:24 PM
03/13/18 09:24 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
OK, owners manual lists Motorcraft Specialty Orange, spec number WSS-M97B44-D. PGL lists ESE-M97B44-A (as well as WSS-M97B51-A1) explicitly on their specifications pdf. I'm assuming ESE-M97B44-A is the equivalent to my WSS-M97B44-D?
2011 F150 4x4 5.0L
Re: PGL in dexcool application? [Re: buck91] #4694503
03/14/18 11:40 AM
03/14/18 11:40 AM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Motorcraft Specialty Orange = Dex-Cool = most "AMAM" type coolants.
M97B44-A is not, however, the same as M97B44D.
* Yellow-colored Motorcraft Premium Gold Engine Coolant, meeting Ford specification WSS-M97B51-A1
* Green-colored Motorcraft Premium Engine Coolant, meeting Ford specification ESE-M97B44-A
* Orange-colored Motorcraft Specialty Orange Engine Coolant, meeting Ford specification WSS-M97B44-D
Don't mix and match, you're gonna have a bad time.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
