1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
30 registered members (billt460, citationxeleven, anndel, c502cid, Ag76, 3 invisible), 952 guests, and 31 spiders.
Topics296,903
Posts4,961,304
Members66,997
Most Online2,688
Jan 19th, 2019
Mobil1 EP High Mileage 0w-20 #4688577
03/08/18 10:28 AM
03/08/18 10:28 AM
North Carolina
Mazdazoomzoom Offline OP
North Carolina
i just got an email from Mobil 1 announcing their new Mobil 1 EP High Mileage. When I looked at the "product specs" sheet for the 0w-20, I see the phosphorus is 800 and the zinc is 900. In the past, I used the Mobil 1 AFE 0w-20, which has phosphorus 650 and zinc 750. Some years back,when they came out with the Mobil 1 EP in 0w-20, I saw it had phosphorus 800 zinc 900,so I switched to it. Now, when I look at the "product specs" for all the Mobil 1 0w-20 oils, I see the only one with phosphorus 800 zinc 900 is the new EP High Mileage 0w-20. The 0w-20 Mobil 1 EP is no longer phosphorus 800 zinc 900, it is now phosphorus 650 zinc 750.
My question is does this really make a difference, and should I switch to the new Mobil 1 EP High Mileage 0w-20?
Re: Mobil1 EP High Mileage 0w-20 [Re: Mazdazoomzoom] #4688594
03/08/18 10:47 AM
03/08/18 10:47 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Is your vehicle "high mileage"? Usually folks switch to a HM oil due to its stronger seal conditioner additives.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Mobil1 EP High Mileage 0w-20 [Re: Mazdazoomzoom] #4688603
03/08/18 10:57 AM
03/08/18 10:57 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Thanks for organizing those numbers. I donít think anyone can prove a difference either way. How many miles is on your vehicle?
If you want the job done right......do it yourself.
Re: Mobil1 EP High Mileage 0w-20 [Re: Mazdazoomzoom] #4688610
03/08/18 11:06 AM
03/08/18 11:06 AM
Chicago
Jooksing Offline
Jooksing  Offline
Chicago
Excuse my newbieness to the forums. What is the goals of phosphorus and zinc. What does it actually do it stick to walls or contamination? TIA
Re: Mobil1 EP High Mileage 0w-20 [Re: 1JZ_E46] #4688612
03/08/18 11:08 AM
03/08/18 11:08 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
In this case I switch because its on sale and won't hurt your engine. I've been using HM off and on for over four years and my Toyota Corolla hasn't exploded or bust into flames yet.
2004 Corolla 128318
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Mobil1 EP High Mileage 0w-20 [Re: Jooksing] #4688615
03/08/18 11:09 AM
03/08/18 11:09 AM
Oakville, Ontario
Patman Offline
Patman  Offline
Oakville, Ontario
Phosphorus and zinc are for anti wear, but a lot of people get too hung up on their values, as there are better ways to reduce engine wear these days, such as titanium and boron.
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 148k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,111k, GC 0w40 & Fram Ultra
Re: Mobil1 EP High Mileage 0w-20 [Re: JohnnyJohnson] #4688722
03/08/18 01:01 PM
03/08/18 01:01 PM
MA USA
andrewp1998 Offline
andrewp1998  Offline
MA USA
I heard from mech that the hm oils can destroy the seals in the newer japanese engines. any info on this?
2001 Honda civic HX vtecE- 5 spd,232k+
Re: Mobil1 EP High Mileage 0w-20 [Re: andrewp1998] #4688738
03/08/18 01:24 PM
03/08/18 01:24 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Sounds like the mechanics that warn against 0W oils because they are too thin and will ruin your engine.
Same one who did this?
bad waterpump was determined .. keyhole was not lined up with cam and some type of housing was broken. Last mech screwed up and screwed up many times.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Mobil1 EP High Mileage 0w-20 [Re: Mazdazoomzoom] #4688814
03/08/18 02:57 PM
03/08/18 02:57 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Doesn't make a difference.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Mobil1 EP High Mileage 0w-20 [Re: Snagglefoot] #4688820
03/08/18 03:02 PM
03/08/18 03:02 PM
North Carolina
North Carolina
I have 62,000 on my Mazda 6, so I was thinking of switching to the new 0w-20 EP HM at 75,000 like the Mobil 1 info talks about. After I saw where my current 0w-20 EP has lowered the phosphorus and zinc compared to the new 0w-20 EP HM, I was wondering if the difference in phosphorus and zinc would make it worth switching now.
Re: Mobil1 EP High Mileage 0w-20 [Re: Mazdazoomzoom] #4689315
03/09/18 05:18 AM
03/09/18 05:18 AM
Snagglefoot Offline
Snagglefoot  Offline
Maybe itís just me but Iím thinking that high mileage oil is used to slightly swell the elastomer seals in engines to reduce oil leaks. I donít like the idea of introducing the oil to engines that donít have leaks, I think Mobilís choice of 75,000 miles was more of a marketing thing than a technical reccomendation.
Maybe someone else knows more about this but I would not use HM until I saw drips. If 75,000 miles is ďhigh mileageĒ what is 200,000 miles?
Re: Mobil1 EP High Mileage 0w-20 [Re: Mazdazoomzoom] #4689490
03/09/18 10:26 AM
03/09/18 10:26 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
My Colorado 3.5 with 115K never had any leaks and never used hardly any oil .... UNTIL ...I recently changed to Valvoline High Mileage Synthetic. Consumption has now tripled from a half-quart in 6K to 1-1/2qts.
The sad part is I bought enough Valvoline HM Synthetic for two OCIs. I just might give away those six quarts I have remaining.
Back to SOPUS I come, but not their High Mileage oils .....initially anyways. I'll first wait and see if the consumption lessens.
So the end result says don't use high mileage unless needed. Don't try to fix something that ain't broke. If you do, then you may make things worse. Leave well-enough alone.
2019 Hyundai Santa Fe 2.4 factory fill and OEM filter
2004 Chevrolet Colorado 3.5 QS / Valvo syn 5w30/20 blend K&N filter
2003 Chevrolet Malibu 3.1 QS / Valvo Syn 5w30/20 blend Fram EG filter
Re: Mobil1 EP High Mileage 0w-20 [Re: Mazdazoomzoom] #4689906
03/09/18 06:44 PM
03/09/18 06:44 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
The valvoline max life are RC oils. Theyíre on the thin end of 30 grade
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Mobil1 EP High Mileage 0w-20 [Re: Triple_Se7en] #4690505
03/10/18 12:40 PM
03/10/18 12:40 PM
North Carolina
North Carolina
After reading this, I think I will just keep using my Mobil 1 EP 0w-20, and not worry about the difference in phosphorus and zinc. I do wonder why Mobil lowered the phosphorus and zinc in the Mobil 1 EP 0w-20 from what is was when the EP 0w-20 first came out.
If Walmart carries the Valvoline HM synthetic you bought, you can take it there, with no receipt, and get a store credit.
Re: Mobil1 EP High Mileage 0w-20 [Re: Mazdazoomzoom] #4690572
03/10/18 01:54 PM
03/10/18 01:54 PM
Pennsylvania
Astro_Guy Offline
Astro_Guy  Offline
Pennsylvania
I noticed that my local Walmart had this new flavor of Mobil 1. What was more interesting is that it didn't earn any more shelf space for the brand, they simply reduced the shelf space for AP by half and put the new oil where it used to be.
'01 Volvo V70XC, 233k, 0W-40 M1
'16 Accord, 25k, 0W-20 M1 EP
