How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
108 registered members (aquariuscsm, AandPDan, advocate, aircooled, 2003f7, 53' Stude, 13 invisible), 2,309 guests, and 55 spiders.
Topics286,017
Posts4,900,829
Members67,548
Most Online2,967
Mar 10th, 2019
Need an oil recomendation 2.3 Mazda #4688466
03/08/18 09:53 AM
03/08/18 09:53 AM
PA
Chester11 Offline OP
PA
Hi folks:
I have an 09 2.3 Mazda that sits a lot. (Under 7K year mostly around town). It takes 5w 20 (mostly bulk oil from my local shop), and has about 90k miles. It does not burn oil. Quaker State green bottle is in there now. The internal is usually a year rather than miles.
Synthetic is so cheap, I'm going to upgrade to that. I have some Napa synthetic from the last sale that I'm going to run next. Pennzoil platinum is cheap with the rebate - but seems like overkill.
I had the value cover off and everything looks really clean.
Anyone care to weigh in with a rec?
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688483
03/08/18 10:07 AM
03/08/18 10:07 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Any synthetic meeting Dexos1 Gen2 ratings will be fine.
NAPA, Pennzoil, whatever is cheapest ....
If it were my car, I would consider running a 5W-30
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688487
03/08/18 10:10 AM
03/08/18 10:10 AM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
Use API certified oil and change it on time. Your engine will out live the car.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688505
03/08/18 10:17 AM
03/08/18 10:17 AM
Winnipeg MB CA
Number_35 Offline
Number_35  Offline
Winnipeg MB CA
We have an '09 Mazda 5 with the same Duratec 2.3. We've had the vehicle since 4 years old/52K km, and it's always used oil - up to a litre every 4000 km (approximately a quart in 2500 miles).
I started out using 5W-20 (the factory specification) while the vehicle still had powertrain warranty, and had it changed twice @ the dealer. They used QS once, and Mazda-branded (PetroCan?) the 2nd time, both full synthetics.
After the warranty expired I moved to Mobil 1 0W-30, which didn't seem to slow consumption much, and then Mobil 1 0W-40. The 0W-40 seems to have worked, with consumption much lower now. I should change the PCV valve (which involves pulling the intake manifold); I realize that using a thicker oil is just treating the symptom.
Because your engine doesn't use oil, you'd likely be fine with a synthetic 5W-20, 0W-30, or 5W-30. (Per the owner's manual, 5W-30 is acceptable, I think for Mexico.) A 0W-20 might be good too, but the parts man at my dealership said that Mazda had not back-spec'd that engine to 0W-20 and advised against it.
Anyway, that's my experience. Basically it comes down to what brand you're comfortable with. Mobil 1 comes on sale regularly here, and is always available, so I settled on it.
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688510
03/08/18 10:19 AM
03/08/18 10:19 AM
GA
miden851 Offline
miden851  Offline
GA
@Chester; 09 Mazda6 with 2.3 does not exist, and you should know better! LoL
I'm running dino on mine I am perfectly fine with it because I'm change it often and the car is on the move constantly.
If I'd switch, I'd use Valvoline 5W-20HM
2008 Mazda6i GT; @214K miles
2016 Honda CR-V EX-L; @40K miles
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688513
03/08/18 10:25 AM
03/08/18 10:25 AM
New York
pbm Offline
pbm  Offline
New York
I agree with running synthetic in order to avoid having to change the PCV valve often...(in other words dino would protect fine but synthetic will probably keep things a bit cleaner at a 7K OCI)....since the PCV valve is a PITA to change (same as the Duratec in my 2014 Focus) I'm using synthetic....
PS: I don't think a dexos G2 is needed since it's not a turbo....I plan on using all the dexos non-G2 5w20 that I got on CLEARANCE...
'Journalism is Dead'
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688534
03/08/18 10:50 AM
03/08/18 10:50 AM
PA
PA
sorry for the typos - 07 2.3.
coffee finally kicked in....
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688641
03/08/18 12:35 PM
03/08/18 12:35 PM
GA
miden851 Offline
miden851  Offline
GA
just kidding!
those Duratechs 2.0L, 2.3L and 2.5L are some of the best engines in the industry; I think like someone has said before, anything you chose you cannot go wrong with; mine does not burn nor leak oil after all these miles
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688688
03/08/18 01:20 PM
03/08/18 01:20 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Cheapest Dexos approved 5W-20 oil you can find. If it ever starts to use oil, go to 5W-30. When the seals start leaking go to HM 5W-30 Let us know in 10 years how it went.
If you want the job done right......do it yourself.
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688695
03/08/18 01:31 PM
03/08/18 01:31 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I'd just switch to Maxlife semi-syn in whatever grade you want. Oil is good enough smile
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688703
03/08/18 01:39 PM
03/08/18 01:39 PM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
I had a 2004 focus ZTS with the 2.3. I assume pretty similar if not the same engine. It always had Mobil 1 since new, and was sold at 150k miles. 3rd gear was giving out smirk
I ran that thing pretty hard, and the motor never had a problem. That engine was a trooper for the abuse it got.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688784
03/08/18 03:26 PM
03/08/18 03:26 PM
PA
PA
yes I pretty much lucked into this car - only engine complaint is that it vibrates slightly at stop lights when the engine fan is on. it has not had it easy (rental car, driven around Baltimore / DC beltway, street parking).
thanks for the recommendations folks. I have a feeling the motor will outlast the frame and trans.
Re: Need an oil recomendation 2.3 Mazda [Re: Chester11] #4688855
03/08/18 04:38 PM
03/08/18 04:38 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Any oil with the proper ratings from the major oil companies will work.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Need an oil recomendation 2.3 Mazda [Re: miden851] #4688868
03/08/18 04:55 PM
03/08/18 04:55 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
just kidding!
They really are. I owned a 2007 Focus with 175K(totaled last June), My present 2007 Fusion 2.3, and my 2017 Fusion 2.5 Duratech engines. All have performed great with very few problems. Oil used was M1 0-20 of course with my normal 10K OCI.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 65K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Need an oil recomendation 2.3 Mazda [Re: tig1] #4688872
03/08/18 05:04 PM
03/08/18 05:04 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Right on Tig1.
Those Ford duratec motors are very, very good. And the Mobil 1 0w20 will be a great oil for that car.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
