Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
93 registered members (2009Edge, addyguy, ArrestMeRedZ, anndel, 53' Stude, 240_Ed, 16 invisible), 2,069 guests, and 63 spiders.
Topics286,203
Posts4,904,148
Members67,576
Most Online2,967
Mar 10th, 2019
RLI 10w40 Homebrew Bio-SynXtra HD Low Ash VOA #4688436
03/08/18 09:09 AM
03/08/18 09:09 AM
California
CleverUserName Offline OP
California
The 10w30 RLI I got was kinda low on the cSt @ 100 so I decided to mix it with the 15w40 to make it a 10w40. I also wanted to see how two multigrade oils of the same formulation would blend together. Kinda like an experiment.
50/50 Homebrew Blend of RLI Bio-SynXtra HD Low Ash 10w30 and 15w40.
Recipe:
60 mL of RLI 10w30
60 mL of RLI 15w40
3 mL of RLI Bio-Syn Booster Pack (2.5% by volume)
I have a small lab at work. We have beakers, pipettes, and magnetic stirrers. I think my measurements were pretty accurate. I mixed it for about 2-3 minutes with the biggest magnetic stirrer we had. I was careful to mix slowly as I did not want to aerate the combined sample.
According to the Widman calculator a 50/50 blend is:
77.51 cSt @ 40
12.96 cSt @ 100
VI = 169
As Tested:
78.8 cSt @ 40
13.3 cSt @ 100
VI = 172
It's pretty close. Honestly, closer than I thought it would be. I can see the booster pack raised the Sb to over 500 ppm.
Can you guys see any problems using this stuff ? Thoughts, observations, concerns, etc...
Re: RLI 10w40 Homebrew Bio-SynXtra HD Low Ash VOA [Re: CleverUserName] #4688544
03/08/18 10:59 AM
03/08/18 10:59 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
https://youtu.be/bKyiXjyVsfw
Cool. Reminds me of this.
If you want the job done right......do it yourself.
Re: RLI 10w40 Homebrew Bio-SynXtra HD Low Ash VOA [Re: CleverUserName] #4696359
03/16/18 07:08 AM
03/16/18 07:08 AM
California
California
Does anybody think the NOACK % will be predictable for this homebrew?
Like if the 10w30 is listed @ 11% and the 15w40 is @ 6% then 11+6=17/2 = 8.5%
8.5% sound reasonable ?
Re: RLI 10w40 Homebrew Bio-SynXtra HD Low Ash VOA [Re: CleverUserName] #4742981
04/30/18 05:20 AM
04/30/18 05:20 AM
California
California
I put this Homebrew in my 2.8 Duramax today and drove it around for a couple hours.
Observations so far:
Hot idle oil pressure is the same as Delvac ESP 5w40 CJ-4. 18-20 PSI
Cold start oil pressure is lower than ESP. Pressure also falls faster during warmup. (Because of higher VI??)
Oil Pressure cruising @ 65 mph (1650 RPM) is about 5 PSI greater than ESP. 48 PSI
CJ-4 ESP has a value of 14.7 cSt @ 100c, yet this blend with a 13.3 cSt has higher oil pressure. I guess due to higher HTHS of Biosyin??? Wasn't expecting that to happen.
Engine runs smooth otherwise. Seems like a quality oil. Hopefully it lives up to the hype.
