Originally Posted By: 901Memphis
Originally Posted By: 01rangerxl
You can try, just be prepared to replace both. A lot of times the nipple on the hose breaks off inside of the fitting that is part of the outlet. You may or may not be able to dig it out.
That housing looks like it's got a lot to it,do you know if it's a big job?
I'd drive it down to Campbellsville, KY and see if Alex will do some work on it for you. Two and half hours to get it dialed in will be worth it. Esp if that helps keep it be trouble-free for years to come.
