Omnia - the band
by Shannow
Today at 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
Today at 12:54 AM
Battery stuck in flashlight.
by Chris142
Yesterday at 11:53 PM
Must read for everyone watching their diet
by JLTD
Yesterday at 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
Yesterday at 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
Yesterday at 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
Yesterday at 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
Yesterday at 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
Yesterday at 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
Yesterday at 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
Yesterday at 09:32 PM
Another thick/thin article to discuss
by JLTD
Yesterday at 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
Yesterday at 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
Yesterday at 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
Yesterday at 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
Yesterday at 08:32 PM
VWs at Pick n Pull
by Eric Smith
Yesterday at 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
Yesterday at 08:12 PM
Breaking in new short block
by Bub
Yesterday at 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
Yesterday at 06:32 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
24 registered (dishdude, billt460, Bjornviken, dlundblad, cven, 2 invisible), 846 Guests and 55 Spiders online.
65299 Members
67 Forums
285816 Topics
#4687713 - 03/07/18 03:41 PM Is 5w-20 has better adhesive to metal than 0w-20?
flash_os Offline
Loc: Canada
Is 5w-20 has better adhesive to metal than 0w-20 in cold weather?
Since 0w-20 has lower thickness on cold weather thus less adhesive when you left your car for a night more oil will be in oil pan.
Somebody tried to test it on any car scrap metal in your garage environment?
#4687724 - 03/07/18 03:47 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
MolaKule Offline
Loc: Iowegia - USA
Originally Posted By: flash_os
Is 5w-20 has [have] better adhesive to metal than 0w-20 in cold weather?
No.
There are additives added to motor oils to prevent metal contact on startup, and those additives are deposited on the metals even after drain-off.
Edited by MolaKule (03/07/18 03:50 PM)
#4687766 - 03/07/18 04:21 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
T4RF Offline
Loc: PNW
Man there is so much distrust of 0W oil on this forum! I remember when synthetics really started breaking into the mainstream, and I heard much of the same ďcanít protect as well as REAL oil, hurts all your seals and makes your engine leak!Ē
#4687784 - 03/07/18 04:39 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
mightymousetech Offline
Loc: Ontario, Canada
+1!
There is no such thing as too thin when cold.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4687804 - 03/07/18 05:00 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
PeterPolyol Offline
Loc: toronto
It's a matter of the 'polarity' of the molecules; how much they stick to parts, so the chemical formulation of the oil makes the difference rather than the viscosity rating. Like Molakule said, they pay attention to polarity and solubility and tailor the products accordingly, regardless of viscosity.
#4687826 - 03/07/18 05:18 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
PandaBear Offline
Loc: Silicon Valley
Look at it this way, eventually oil cling to metal (cylinder wall and bearing) will all drain down to the sump over night. So it is better to have a thinner oil that can pump to where you want, than thicker oil that will eventually drip down no matter what.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4687910 - 03/07/18 06:22 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: PandaBear]
Linctex Offline
Loc: Waco, TX
You should disassemble an engine that hasn't run for several years...
it will surprise you how much oil DID NOT run down..... over the course of years.
#4688139 - 03/07/18 09:54 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: PandaBear]
Bryanccfshr Offline
Loc: Durango, Co
Thatís not how it works, thatís not how any of this works!
2018 Trd Pro 4Runner M1 0w40
2018 Tacoma off-road Castrol 5w30 Magnatec
#4688287 - 03/08/18 03:44 AM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
jtfmdyk Offline
Loc: Littleton, CO
When you shut down the oil is warm and 5w-20 should equal 0w-20. By the time things would have cooled enough to cause a difference in viscosity any oil that would drain from internals has long since done so.
2003 S2000
2002 CR-V
2006 Accord EX
#4688305 - 03/08/18 04:50 AM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
FordCapriDriver Offline
Loc: Balearic Islands , Spain
Oil never fully drains down, not even the thinnest synthethic 0W-20 or 0W-16, there is always a film of oil left, that is enough to lubricate the engine for the first few seconds of running until the oil has flowed everywhere.
The one and only time in an engine's life that there is a true "dry" start would be the first time the engine is ever run after being put together, or after a rebuild, although every engine rebuilder i know uses plenty of oil and grease on bearings and such when putting together an engine, and they prime it up first before starting it.
Some oils have greater polarity, meaning they wll "cling" a little more to metal than others after shut off.
Conventional oils, specially something thick like a Group I 20W-50 loaded with sticky VII's "sticks" more to metal than say a Group IV PAO synthetic, they drain off faster.
1975 Ford Capri II Ghia 3000 V6, - Valvoline VR1 20W-50
1988 Ford Escort MkIV 1.6 Xr3i Cabrio, - Shell Rimula R4X 15W-40 HDEO.
#4688412 - 03/08/18 07:44 AM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
SR5 Offline
Loc: Down Under
Castrol Magnatec
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4689798 - 03/09/18 04:53 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
flash_os Offline
Loc: Canada
Let check the facts...
Somebody tried to make experiment on scrap metal?
#4689876 - 03/09/18 06:13 PM Re: Is 5w-20 has better adhesive to metal than 0w-20? [Re: flash_os]
Shannow Online   content
Loc: 'Stralia
Plenty of us have checked the facts...pulled apart engines, and the pistons and bearings are full of oil. Held there by capillary action, regardless of viscosity.
