Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Orion62, Revd, blinky1041, mostdecent, T1TN
65261 Registered Users
75 registered (2009Edge, Artem, andyd, badtlc, AandPDan, 2K2AcuraTL, 6 invisible), 1413 Guests and 39 Spiders online.
65261 Members
67 Forums
285507 Topics
#4686616 - 03/06/18 06:33 PM Help: Tying two logs together with metal cables
henni Offline
Loc: key largo,fl
What am I looking for?
I have two giant (think upright street light pole, but twice the thickness) logs and I want to tie these in at least two(2) locations with a heavy wire that can be adjusted/ratchet wrenched gradually to allow for small gaps or uniform contact along the surface. It would have to be exposed to weather so likely coated or stainless steel material.
Who/Where/What is this called and is this something carried by Lowes, Home Depot, Amazon etc ?
Link ?
2014 Ridgeline RTL with Navi
#4686629 - 03/06/18 06:41 PM Re: Help: Tying two logs together with metal cables [Re: henni]
krismoriah72 Online   content
Loc: wv
no clue what you are trying to do...
But sounds like you need trucking ratchet straps.
#4686641 - 03/06/18 06:46 PM Re: Help: Tying two logs together with metal cables [Re: henni]
henni Offline
Loc: key largo,fl
I googled the term and looking at images, they appear to be some type of wide mesh fabric straps. That would be killed with ocean water and rain pelting the giant logs. That is on the right track but they must be metal, not fabric.
Link ?
#4686648 - 03/06/18 06:52 PM Re: Help: Tying two logs together with metal cables [Re: henni]
doitmyself Offline
Loc: MI
Could you use high tensile fence wire / ratchets: these products last for many years exposed to the elements.
https://www.google.com/search?q=high+ten...h=923&dpr=1
http://www.kencove.com/fence/Wire+Tighteners_product.php
Or, guy wire tighteners?: https://www.google.com/search?q=Guy+Wire...920&bih=923
#4686655 - 03/06/18 06:54 PM Re: Help: Tying two logs together with metal cables [Re: henni]
PimTac Offline
Loc: Soviet State of Washington
It sounds like you need some stainless steel cable and turnbuckles. Attaching the cable to the turnbuckle is relatively easy. I am familiar with splaying the cable at the turnbuckle end and pounding a metal insert to anchor it.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4686657 - 03/06/18 06:54 PM Re: Help: Tying two logs together with metal cables [Re: henni]
IndyIan Offline
Loc: Ontario, Canada
I suppose if you get the right kind of UV proof rope and learn some knots, that might be the simplest option. I can't imagine anything metal at a HD stands up to salt water very long. A local dock hardware specialist will probably tell you what's possible atleast.
07 Focus ZXW, 5spd manual, 206km M1 5W30
18 Outback 2.5 CVT 5km FF
#4686782 - 03/06/18 08:20 PM Re: Help: Tying two logs together with metal cables [Re: IndyIan]
Ducked Offline
Loc: Taiwan
Check. The straps on a ratchet strap would probably hold up OK (old oones get used as rails on mountain tracks here and I've seen trees that were originaally supports for them hanging over the abyss) but the mechanism would probably rust-up.
One of the Wharram production catamarans uses them for deck-hull connection so you must be able to get marine spec. ones, but I bet they aren't cheap.
Use a Spanish Windlass arrangement to give rope adjustability.
#4686915 - 03/06/18 10:01 PM Re: Help: Tying two logs together with metal cables [Re: henni]
Linctex Offline
Loc: Waco, TX
What are you trying to do or build?
#4687126 - 03/07/18 07:30 AM Re: Help: Tying two logs together with metal cables [Re: henni]
henni Offline
Loc: key largo,fl
Am literally trying to tie two giant logs together with metal cable and have the ability to control tension.
#4687396 - 03/07/18 11:04 AM Re: Help: Tying two logs together with metal cables [Re: henni]
raytseng Offline
Loc: CA
dont logs taper or get skinnier as they go up.
If you tie them together the logs are not going to be straight but form a bigger angle? Id think you would need to woodwork and flatten the side vertical first.
as far as the tension, yea just cable with shackles and turnbuckles. Its good enough to do other tree support work. But I think you also need to use some intermediate blocks of a hard lumbar or other material to transfer the tension into pressure. Otherwise the cable will just dig into the logs.
example:
https://www.homedepot.com/p/Everbilt-5-16-in-Galvanized-Vinyl-Coated-Wire-Rope-809896/204765292
They have a skinnier amd other gauges and uncoated ones too
if you need something stronger to provide more tension then I think you need a professional advise, cause that's a lot of stored energy and probably a signal to stop and brainstorm if there is a flaw with the plan and if there is a better way
Edited by raytseng (03/07/18 11:16 AM)
#4687469 - 03/07/18 12:17 PM Re: Help: Tying two logs together with metal cables [Re: henni]
IndyIan Offline
Drill a few holes and use 1"+ threaded rod?
#4688078 - 03/07/18 08:41 PM Re: Help: Tying two logs together with metal cables [Re: henni]
Rand Offline
Loc: NE,Ohio
When I picture Giant logs.. I have a 4-5ft diameter tree in the backyard..
what is the diameter and length of the logs.. what are you trying to do.
PS pole here vary from 6" to about 12" measured near the bottom.. there is some taper.
2017 Jeep Cherokee Trailhawk V6
#4688150 - 03/07/18 10:09 PM Re: Help: Tying two logs together with metal cables [Re: henni]
henni Offline
Loc: key largo,fl
No taper. Diameter is about 150 cm.
#4688234 - 03/07/18 11:57 PM Re: Help: Tying two logs together with metal cables [Re: henni]
Ducked Offline
Loc: Taiwan
DP. See below.
Edited by Ducked (03/08/18 12:06 AM)
#4688238 - 03/08/18 12:03 AM Re: Help: Tying two logs together with metal cables [Re: henni]
Ducked Offline
Loc: Taiwan
Taper won't matter. Curve might make for some instability while tightening and/or after since there will be a tendancy for the logs to rotate against each other, and there will be gaps.
If, for example, this pair of logs is floating while you are doing this and you have to board them to apply the tension via a Spanish Windlass as I suggest above, that involves some danger of trapping and injuring limbs.
Could be made safer (but not completely safe) with some temporary decking, say a pallet, laid across the two logs, from which you can apply the tension.
