Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
78 registered members (4WD, 53' Stude, 1.8Tango, 14Accent, Ablebody, 69Torino, 5 invisible), 1,245 guests, and 43 spiders.
Topics290,857
Posts4,851,513
Members66,044
Most Online3,590
Jan 24th, 2017
DEXOS synthetic vs Conventional oil #4686269
03/06/18 01:45 PM
03/06/18 01:45 PM
NS Canada
Squashtowner Offline OP
NS Canada
My 2012 Sierra 5.3 is past warranty. I've used DEXOS oil for every oil change. I now have 113000 km on the truck. I changed the oil when the dash reminder told me to on the driver information center. This has tun 14000 km on a couple instances, and that alarms me.
My new job gives me access to free mobil conventional oil. I've been using purolator filters for the past 2 years, wix prior to that.
Can I switch over to non synthetic and make my oil change interval 5000 km? It'd simplify things a lot for me.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686272
03/06/18 01:47 PM
03/06/18 01:47 PM
Balearic Islands , Spain
FordCapriDriver Offline
I would, free oil is very hard to say no to.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686279
03/06/18 01:55 PM
03/06/18 01:55 PM
NS Canada
NS Canada
In my original post I said the truck went 14000 km between oil changes. It was still showing 24% oil life at 14000 km, and I started having oil pressure issues. A fresh oil and filter change fixed it up and I haven't had any issues since. I put a sticker on my windshield to change it at 7500 km since that happened.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686294
03/06/18 02:03 PM
03/06/18 02:03 PM
Danh Offline
Danh  Offline
To meet GM’s dexos spec requires at least a synthetic blend and one supposes GM did this for a reason. And the oil life monitor is calibrated for at least a syn blend. Maybe there wouldn’t be short term damage from using a conventional oil but if you do so you may want to shorten the OCI a bit. Personally, I’d stick with the dexos spec.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686298
03/06/18 02:14 PM
03/06/18 02:14 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
I think most dealerships use conventional oil in many instances and many Silveradoes still are out there going strong. I wouldn't worry but I would not go over 6,000 kilometers with the oil
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: DEXOS synthetic vs Conventional oil [Re: FermeLaPorte] #4686306
03/06/18 02:21 PM
03/06/18 02:21 PM
NS Canada
NS Canada
I was also thinking that. Plus, the 5w30 here is GF-5 and SN rated. Same as the dexos 5w30 I was using all along. I don't think it would be an issue.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686308
03/06/18 02:27 PM
03/06/18 02:27 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Dexos spec ain't all that. You just want a good oil. The last oil I ran was Dexos spec full synthetic and it was NG. (Magnatec Full Syn 5w30) Funny, the Magnatec SS ran well.
Got QSUD non DEXOS 10w30 iN THERE last night AND IT IS ALL GOOD AGAIN.
Id run a decent faux or real synthetic you trust. That 5.3 has pretty high power density. It would have been a z28 enhgine in the earl;y 70s if it appeard back then brought by Aliens (who don't exist around HERE at LEAST)
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686366
03/06/18 03:15 PM
03/06/18 03:15 PM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
No turbo, no GDI, no problem.
2014 Passat Wolfsburg, 1995 Miata.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686390
03/06/18 03:39 PM
03/06/18 03:39 PM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
Free would make that decision fairly easy. Tens of thousands of trucks and other vehicles on the road with 300K plus on the odometer running nothing but straight dino and still going strong
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686406
03/06/18 03:52 PM
03/06/18 03:52 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Don’t forget the 2012, 5.3 had AFM. Chat with some of the AFM victims before you decide on non Dexos oil.
If you want the job done right......do it yourself.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686487
03/06/18 05:14 PM
03/06/18 05:14 PM
St. Charles County, Missouri
csandste Offline
csandste  Offline
I kept using Valvoline Max Life blend after my Encore was out of warranty. Like a previous post said. Turbo and GDI, I'd go with gen II. Turbo only (mine), gen I will do. Neither one, they're just calling for the Dexos because they don't want to stock multiple oils at the dealership.
2017 Kia Soul Plus-- Valvoline MaxLife Blend 5-20, 48,000 miles.
Re: DEXOS synthetic vs Conventional oil [Re: ARCOgraphite] #4686491
03/06/18 05:20 PM
03/06/18 05:20 PM
Soviet State of Washington
PimTac Online content
PimTac  Online Content
Have you ever found a oil you really liked?
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: DEXOS synthetic vs Conventional oil [Re: ARCOgraphite] #4686504
03/06/18 05:31 PM
03/06/18 05:31 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
What reason(s) do you give for saying dexos spec 'ain't all that?'
OP,
If your vehicle is out of warranty and isn't DI, i don't think think using the conventional oil would pose a problem.
'18 KIA Sportage LX AWD 2.4L: MSS 10w30
Next: PP 5w20
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Next: Magnatec 5w30
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686575
03/06/18 06:58 PM
03/06/18 06:58 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Yes you can but as others have stated, the AFM system requires a clean oil.
If switching I would recommend OCI's based on the Severe Service Schedule.
Reading is fundamental; understanding is not a given ability.
Re: DEXOS synthetic vs Conventional oil [Re: Squashtowner] #4686645
03/06/18 07:48 PM
03/06/18 07:48 PM
pa
benjy Offline
benjy  Offline
pa
another reason is every label aka spec is $$$$ so GM gets $$$ on every dexos spec oil sold!! as noted change more often, even every 3,000 if its free, cant hurt anything!! my aunts 99 jeep gets 6 month changes with Mobil I HM usually about 2,xxx miles, almost all short trips!!!
