F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
97 registered members (Ablebody, andyd, aquariuscsm, Aero540T, AnthonyF, 2015_PSD, 8 invisible), 1,495 guests, and 38 spiders.
Topics290,750
Posts4,849,617
Members66,034
Most Online3,590
Jan 24th, 2017
A/C leak repair tools/supplies list #4686092
03/06/18 11:10 AM
03/06/18 11:10 AM
Georgia !
topsy Offline OP
topsy  Offline OP
Georgia !
Working on a 2005 F-150, 50,000 miles, it has a slow A/C leak. Putting together a list of tools and supplies to do the job.
Manifold gauge set
Vacuum pump
dye
planning to add about an ounce of oil, PAG 46
Can or 2 of R134a
Does this look complete?
Re: A/C leak repair tools/supplies list [Re: topsy] #4686093
03/06/18 11:13 AM
03/06/18 11:13 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
Do you know what's leaking?
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: A/C leak repair tools/supplies list [Re: topsy] #4686094
03/06/18 11:17 AM
03/06/18 11:17 AM
MN
14Accent Offline
14Accent  Offline
MN
Is the system empty? How do you plan on recovering it? If you know it's empty, just replace the part that's leaking and take it to a pro to have them evac and recharge it. It's like $120 at most places, sometimes $99. You'll spend more than that in tools just to do the job at home.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: A/C leak repair tools/supplies list [Re: topsy] #4686118
03/06/18 11:45 AM
03/06/18 11:45 AM
Georgia !
topsy Offline OP
topsy  Offline OP
Georgia !
No, I don't know what's leaking, that's the purpose of the dye.
I don't know if it's empty or not, will find out when I get the gauges.
Re: A/C leak repair tools/supplies list [Re: topsy] #4686121
03/06/18 11:46 AM
03/06/18 11:46 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
It is probably cheaper to get a leak checker? Check all the joint and also the valve?
  • 2017 Toyota Sienna
Re: A/C leak repair tools/supplies list [Re: JMJNet] #4686130
03/06/18 11:51 AM
03/06/18 11:51 AM
Georgia !
topsy Offline OP
topsy  Offline OP
Georgia !
From investigating dye vs detector, the cheap detecters are hit/miss, hate to rely on cheap tools. The dye isn't very expensive, I decided to go that route.
Re: A/C leak repair tools/supplies list [Re: topsy] #4686141
03/06/18 12:00 PM
03/06/18 12:00 PM
Upper Midwest
Upper Midwest
Originally Posted By: topsy
From investigating dye vs detector, the cheap detectors are hit/miss, hate to rely on cheap tools. The dye isn't very expensive, I decided to go that route.
I have a detector (two of them actually) and yes they are not as easy to use as it seems. Generally for leaks I just look for an oil stain on some part, if it is the condenser then dirt will stick to the area that is leaking. On hoses it is usually at the crimped connection and you can see it there, same for the compressor (look around the shaft seal).
If it is the evaporator that is one place that a detector can come in handy, you check near the condensate drain outlet. But typically if you don't see any obvious leaks anywhere visible then the most likely suspect is the evaporator. Those sometimes get clogged with leaves and dirt which when mixed with the condensate it can corrode the aluminum pretty bad.
1994 BMW 530i, 228K
Re: A/C leak repair tools/supplies list [Re: topsy] #4686156
03/06/18 12:09 PM
03/06/18 12:09 PM
USA
mk378 Online content
mk378  Online Content
USA
Many cars are charged with dye at the factory. Take one of the service caps off and see if there is dye. A "blacklight" CFL bulb can be used to make dye leaks easier to find.
Re: A/C leak repair tools/supplies list [Re: mk378] #4686180
03/06/18 12:25 PM
03/06/18 12:25 PM
Georgia !
topsy Offline OP
topsy  Offline OP
Georgia !
In
Interesting, I'm going to investigate this
Re: A/C leak repair tools/supplies list [Re: topsy] #4686196
03/06/18 12:44 PM
03/06/18 12:44 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
Get a good blacklight. Most cars I have seen do come with dye from the factory.
Good luck finding the leak! I've always found it to be extremely difficult to find any A/C leaks. No oil, no dye, noting on the detector!
Re: A/C leak repair tools/supplies list [Re: zzyzzx] #4686250
03/06/18 01:32 PM
03/06/18 01:32 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
My Rav4 has an A/C leak. I've used dye, special flash light, yellow glasses and can't find it. Maybe the OP will get lucky but I've had no luck with it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: A/C leak repair tools/supplies list [Re: topsy] #4686315
03/06/18 02:38 PM
03/06/18 02:38 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
That truck has dye from the factory. Remove the 8mm bolt that holds the front hub on and look there for dye. Also the high pressure hose for wetness.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: A/C leak repair tools/supplies list [Re: topsy] #4686546
03/06/18 06:24 PM
03/06/18 06:24 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I replaced the schreader valves and the fill caps, when I did mine. I used the Slime brand tool to remove them. You will also need vacuum pump oil. I got a loaner vacuum pump from autozone that was brand new. You will also need a can tap and a digital kitchen scale to weigh your refrigerant cans.
