Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
68 registered members (69Torino, avi1777, 2015_PSD, 87sammy, 97K15004WD, ArrestMeRedZ, 5 invisible), 777 guests, and 53 spiders.
Topics286,105
Posts4,902,665
Members67,563
Most Online2,967
Mar 10th, 2019
Most accurate tire inflator #4685883
03/06/18 05:14 AM
03/06/18 05:14 AM
Greece
inquirer Offline OP
inquirer  Offline OP
Greece
I currently have a Longacre Magnum™ 3 ˝” Tire Gauge for checking my car's tires' inflation pressure.
Problem is that it's the version with the ball chuck and sometimes it doesn't make perfect contact with the tire's valve resulting in higher deflation than the intending one.
Anyway, I was thinking of buying a digital tire inflator, so which is the most accurate one? (I had chosen the Longacre gauge for its accuracy and I'm planning to buy an inflator with a similar one.)
Re: Most accurate tire inflator [Re: inquirer] #4685908
03/06/18 06:46 AM
03/06/18 06:46 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
I dislike tire gauges that are finicky and need a perfect seat. I buy the type that has a deep well at the contact point so it aligns itself with little effort. Once you get past that then you can pick a digital feature. Sorry I don’t have a brand name for you. Mine are analog.
If you want the job done right......do it yourself.
Re: Most accurate tire inflator [Re: inquirer] #4685925
03/06/18 07:30 AM
03/06/18 07:30 AM
Valencia, CA
Richie Offline
Richie  Offline
Valencia, CA
Re: Most accurate tire inflator [Re: Snagglefoot] #4685934
03/06/18 07:48 AM
03/06/18 07:48 AM
Greece
inquirer Offline OP
inquirer  Offline OP
Greece
Unfortunately, I didn't know that the ball type would require extra effort in order to seat properly. I just bought the cheaper one available on ebay and it happened to be the one with the ball chuck.
Originally Posted By: Richie
This time I'm not looking for a gauge. I'm looking for an inflator (with an air compressor). When I bought the Longacre I bought it with accuracy in mind and I'm again looking for an inflator which has great accuracy, so I don't need an extra gauge for deflation.
Re: Most accurate tire inflator [Re: inquirer] #4685952
03/06/18 08:24 AM
03/06/18 08:24 AM
Valencia, CA
Richie Offline
Richie  Offline
Valencia, CA
Intercomp has a gauge/inflator on their website
Re: Most accurate tire inflator [Re: Richie] #4685974
03/06/18 08:46 AM
03/06/18 08:46 AM
Greece
inquirer Offline OP
inquirer  Offline OP
Greece
I wasn't able to find it. Anyway, I was thinking about something like RING RAC640, but I'm not sure if this kind of machines are accurate and durable.
Re: Most accurate tire inflator [Re: inquirer] #4686053
03/06/18 10:18 AM
03/06/18 10:18 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Never trust the gauge that comes on a compressor.
I also try not to use portable compressors. They do not have a drier in them, so you are putting wet air in your tires. Dried shop air is much, much better.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Most accurate tire inflator [Re: mightymousetech] #4686115
03/06/18 11:42 AM
03/06/18 11:42 AM
Greece
inquirer Offline OP
inquirer  Offline OP
Greece
Well, do all air compressors at gas stations have dryers? Are they standard? Furthermore, does dry air have any significant advantage? For example, filling the tires with nitrogen doesn't make a major difference, at least not for everyday driving.
Anyway, accuracy maybe is an issue for some inflators, but maybe not for others. It would be great if there was a review comparing their accuracy with the reading of a professional gauge.
Gauges show different reading though too: https://www.youtube.com/watch?v=U51cMyTsL_Y. If you watch the video there is a 2 psi difference between different analog gauges. If the uploader didn't bleed air unintentionally while using the gauges then 2 psi would be a major difference, if these gauges claim that they are spot on.
Re: Most accurate tire inflator [Re: inquirer] #4686259
03/06/18 01:38 PM
03/06/18 01:38 PM
Lost in the Garden State
Carbuff Offline
Carbuff  Offline
Why do you need to be such sticklers for accurate PSI? It can vary from day to day.
One or two PSI either way ain't gonna hurt a lot. But, don't be afraid to compensate. (EG, if I see that the tires are wearing on the edges, I'll run 2 PSI more.)
PS: For 30 years I've used a Black & Decker Air Station to fill up tires. No drier, of course. No issues either. Yeah, the gauge isn't too accurate anymore (reads 11 PSI 'high') but I can adjust in my mind. I always double-check with a gauge...
Atwell Haines
NJ
Re: Most accurate tire inflator [Re: Carbuff] #4686316
03/06/18 02:39 PM
03/06/18 02:39 PM
Greece
inquirer Offline OP
inquirer  Offline OP
Greece
It certainly doesn't hurt to be precise.
If the gauge overestimates the pressure by 2-3 PSI, the owner has neglected to check the pressure for a relatively long time (maybe that has caused another 1-2 psi pressure decrease) and a cold wave has hit, then the combination can lead to a big difference.
Personally, during winter I wait for a cold wave and when it comes I adjust the pressure early in the morning.
Re: Most accurate tire inflator [Re: Carbuff] #4686344
03/06/18 03:01 PM
03/06/18 03:01 PM
Ontario, Canada
Ontario, Canada
A drier is only really important on high performance vehicles. If you have water in a tire that gets hotter than the boiling point of water, there is significant increase in pressure, which can cause disastrous results.
Instead of a compressor, I have a small air pig I fill at the shop with dry air. Also much quicker for adjusting pressures.
Mighty Mouse Tech
Re: Most accurate tire inflator [Re: inquirer] #4689465
03/09/18 11:00 AM
03/09/18 11:00 AM
Valencia, CA
Richie Offline
Richie  Offline
Valencia, CA
I was wrong. They have a inflator/gauge but is not digital.
https://www.intercompracing.com/pressure-gauges-fill-bleed-read-pressure-gauges-c-35_36_39-l-en.html
Re: Most accurate tire inflator [Re: inquirer] #4689492
03/09/18 11:29 AM
03/09/18 11:29 AM
Ontario, Canada
Ontario, Canada
Just picked up this one for use in the shop.
On sale for $140 CDN.
Supposed to be better than 1% accuracy.
https://store.snapon.com/Inflators-Digital-Inflator-with-Coated-Hose-P892712.aspx
Quote:
• Reads in 0.1 PSI increments, range of 5–150 PSI
• Vinyl-coated, braided stainless steel hose for increased strength, flexibility and protection from scratching
• Back-lit display, with PSI, kPa, bar and kg/m˛
• Includes dual-foot and clip-on chucks
• 1/4" NPT hose ends for easy use with any open chuck
• Three-position trigger allows users to quickly read, inflate and bleed-off tire pressure with one hand
• Rubber body prevents damage when dropped
Mighty Mouse Tech
Re: Most accurate tire inflator [Re: inquirer] #4691517
03/11/18 01:44 PM
03/11/18 01:44 PM
Michigan
NO2 Offline
NO2  Offline
Michigan
I use a bicycle pump.
Re: Most accurate tire inflator [Re: inquirer] #4691660
03/11/18 04:02 PM
03/11/18 04:02 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Since most cars have a TPMS now.... having a tire gauge that doesn't match the monitoring system makes it pointless IMO.
