Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
98 registered members (28oz, 97prizm, 1WildPig, 5azzmonkey, 2K2AcuraTL, 11 invisible), 2,176 guests, and 43 spiders.
Topics295,224
Posts4,930,452
Members66,716
Most Online2,553
Oct 27th, 2018
2005 Neon atf change #4685823
03/05/18 11:55 PM
03/05/18 11:55 PM
Ontario, Canada
heyleescomet Offline OP
Ontario, Canada
Want to do a drop and fill, along with the filter. Fluid is brownish colour, pungent smell not sure how to describe it, although im not sure what smell is good or bad. Unknown history. Car has 160,000km. Shifts good, only under light throttle does it slightly shudder on the 1-2 shift. Have Valvoline ATF+4 ready to go.
Just thought Id get your guys' insight before I do it in the near future.
2003 F-150 4.6L, 5 speed, PP 5w30
1962 Mercury Comet 200ci, Shell 15w40
Re: 2005 Neon atf change [Re: heyleescomet] #4685869
03/06/18 03:06 AM
03/06/18 03:06 AM
T-County, Ohio
AnthemBassMan Offline
T-County, Ohio
We had an '05 Neon for 10 years and 178k miles until last March when I bought my Wife a new car and we donated the Neon to a family in bad need. It had the same shift shudder from the day in we bought it in '07 with 19k on it. Never got better, never got worse. Just part of the Neon personality. You're right around the mileage for changing the ATF, if I remember correctly. ATF+4 does have a stronger odor than Dexron ATF, so that's normal.
L8R,
Matt
2010 Chrysler Sebring Touring 173.8k
Valvoline MaxLife 5w30/Fram Ultra filter
2017 Hyundai Elantra SE 21.8k
Pennzoil Platinum 5w30/Fram Ultra filter
Re: 2005 Neon atf change [Re: heyleescomet] #4685894
03/06/18 04:31 AM
03/06/18 04:31 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Yeah, it's a good idea to change it. Havoline or any ATF+4 is good and most likely made under license anyway.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 2005 Neon atf change [Re: heyleescomet] #4685898
03/06/18 04:58 AM
03/06/18 04:58 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Sounds like a plan. I would do a second change after a couple months.
The "thinking" man's friend.
Re: 2005 Neon atf change [Re: heyleescomet] #4686695
03/06/18 07:24 PM
03/06/18 07:24 PM
USA
slacktide_bitog Offline
USA
Nothing wrong with Valvoline ATF+4 or any other licensed ATF+4, but the best fluid for ATF+4 applications is Redline C+ which uses the same add pack as licensed ATF+4 but with a group V ester base stock instead of the group III required by Chrysler (which is why they won't give it a license)
I would also suggest getting the Dorman transmission pan, which has a drain plug.
Redline C+ and the Dorman pan are all you need for success smile
Re: 2005 Neon atf change [Re: slacktide_bitog] #4722207
04/09/18 08:43 PM
04/09/18 08:43 PM
Ontario, Canada
Ontario, Canada
Did the spill and fill 2 weeks ago, everything went fine. New filter and 4 quarts of atf+4 added. Total capacity is around 8.5-9 quarts.
Planning on doing it again in 2k when the oil change is due. After that, will more than likely do it once a year
Was wondering if I should change the filter again? I might since its only $10 and comes with the pan gasket.
Didnt get an oil pan with a drain plug. The pan on these are on probably a 30* angle, so loosening it and draining is mess free and you dont have to do a balancing act with a full pan of atf
Re: 2005 Neon atf change [Re: heyleescomet] #4722580
04/10/18 09:14 AM
04/10/18 09:14 AM
Heart of Dixie
riklyn Offline
riklyn  Offline
Heart of Dixie
have owned several neons. very good luck with them and many hubdreds of thousands of miles. I did keep the timing belts changed every 100,000 miles or so. that seems to be the biggest weak link.
2016 Dodge Ram 5.7 Hemi
2004 Wrangler TJ (Unlimited) 4.0
