Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
90 registered members (97prizm, Bailes1992, ARCOgraphite, avi1777, 240_Ed, 2010Civic, 8 invisible), 1,711 guests, and 61 spiders.
Topics286,387
Posts4,907,349
Members67,614
Most Online2,967
Mar 10th, 2019
Oil leak 2012 Chevy Cruze 1.4 turbo #4685798
03/05/18 11:59 PM
03/05/18 11:59 PM
Northern Kentucky
901Memphis Offline OP
Northern Kentucky
So my first issue popped up with the new cruze already. It's not huge but it's something I noticed. There's a damp spot on an oil line next to the oil fill cap. It's not dripping or anything but it's wet all around and when I tried to fuss with the metal clip that looked loose it made it lose a drop of oil so I'm guessing the clip is all the way in. Any thoughts on how to proceed?
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4685804
03/06/18 12:08 AM
03/06/18 12:08 AM
Washington
Dylan1303 Offline
Dylan1303  Offline
Washington
If i remember thats the coolant line that has a really common leak. Check out cruzetalk they have all the info you would need and then some.
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4685806
03/06/18 12:12 AM
03/06/18 12:12 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4685809
03/06/18 12:23 AM
03/06/18 12:23 AM
Northern Kentucky
Northern Kentucky
I have posted a thread already on the cruze talk but didn't get any replies yet, so I thought I'd try here as well and compare the responses.
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4685810
03/06/18 12:24 AM
03/06/18 12:24 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
The one part I've had to replace on my '13 with 110K is the coolant outlet which is rght below that - and I replaced that hose (which is coolant, BTW) at the same time. I hope you educated yourself on the maintenance needs and common failures of the turbo Cruze before buying one. I love mine but they will not tolerate the neglect most vehicles see from the average owner.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4685815
03/06/18 12:32 AM
03/06/18 12:32 AM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
That's the coolant outlet/water neck.
Buy a new overflow hose and outlet. I usually keep 3 of each in stock. People who just buy one always come back for the other. The new outlet comes with seal, bolts, and sensor. It's not that expensive, but I can't remember the current price off the top of my head. The whole job should be less than $100 in parts and coolant though.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 227K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 201K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 247K miles
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: Alex_V] #4685840
03/06/18 01:35 AM
03/06/18 01:35 AM
Northern Kentucky
Northern Kentucky
No I didn't do enough research before I bought it, I just saw that they needed transmission service regularly as well as good motor oil. Do you have any tips?
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4685843
03/06/18 02:11 AM
03/06/18 02:11 AM
CA
The Critic Offline
The Critic  Offline
CA
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4560504/2012_Cruze_1.4T_Turbo_Replacem
Common weak points include:
- Water pump (common, but covered under a warranty extension)
- Various cooling system hoses and components
- Turbo (less common, but not uncommon)
- Check valve inside the intake manifold (requires new manifold with injectors)
- Valve cover diaphragm failure which results in a lean condition. Usually caused by a failed check valve inside the manifold.
- Front Crank Seal failure and Lower Oil Pan leakage.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 01rangerxl] #4685846
03/06/18 02:16 AM
03/06/18 02:16 AM
Northern Kentucky
Northern Kentucky
I don't see any of those parts at Rockauto. You said coolant? I thought it looks like an oil line, I seen oil or some dark fluid come out of it when I messed with it.
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4685855
03/06/18 02:44 AM
03/06/18 02:44 AM
Northern Kentucky
Northern Kentucky
I guess it's a good thing I got the dealer extended power train warranty, 4 years 48k miles, with a $200 deductible.
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4685878
03/06/18 04:56 AM
03/06/18 04:56 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Pull it apart to identify the worn/damaged component.
Replace worn/damaged component with upgraded part.
Cable ties should hold it
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: The Critic] #4686137
03/06/18 11:55 AM
03/06/18 11:55 AM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
The gen 1 Chevy Volt, which does not have a turbo, has the same valve cover, but I have not heard of any failures on the Volt.
If the check valve inside the manifold on the Cruze fails, does it allow the crankcase to get pressurized when the intake manifold pressure is in boost?
If so that could contribute to:
I ran across a mod for the Cruze which uses an external check valve. The internal check valve in the manifold is plugged, and the external check valve is plumbed between the throttle body and the intake manifold.
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4686157
03/06/18 12:09 PM
03/06/18 12:09 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Yes, that part is a coolant outlet. They don't sell the plastic fitting the hose connects to by itself, even though you can remove it from the outlet. The current GM part # for the outlet is 25193922 and list is $44.11. It has changed numbers a bunch of times.
It is listed on Rock Auto under "Thermostat Housing/Water Outlet"...
http://www.rockauto.com/en/moreinfo.php?pk=6755172&cc=1501801&jsn=438
The outlet doesn't house the thermostat, that's on the other side of the engine on the water pump, it's just listed in the same section of the catalog.
For whatever reason Rock Auto doesn't list the hose, but the part number on it is 13251447. GM list is $19.94.
Pretty much any Chevy dealer should have both in stock.
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4686796
03/06/18 09:30 PM
03/06/18 09:30 PM
Northern Kentucky
Northern Kentucky
Other people are reporting they just replaced the hose not the housing... I wonder if that would work?
Re: Oil leak 2012 Chevy Cruze 1.4 turbo [Re: 901Memphis] #4686899
03/06/18 10:44 PM
03/06/18 10:44 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
You can try, just be prepared to replace both. A lot of times the nipple on the hose breaks off inside of the fitting that is part of the outlet. You may or may not be able to dig it out.
