Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
89 registered members (ARCOgraphite, andyd, 2010Civic, Astro14, 13 invisible), 1,718 guests, and 64 spiders.
Topics286,446
Posts4,908,443
Members67,626
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Replaced battery today #4685709
03/05/18 10:30 PM
03/05/18 10:30 PM
Crawfordville FL
SilverFusion2010 Offline OP
Crawfordville FL
The Bosch branded 96r gave up in 3 years of driving. Car almost didnít start this morning, went to OíRileys on lunch and put in a Super Start battery. (Iím told they are made by east penn). It is nice and fresh also, sticker says 2/18. Engine turns over with authority now.
This was the second Bosch battery that has died in 3 years. Made by Johnson Controls. Junk
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Replaced battery today [Re: SilverFusion2010] #4685723
03/05/18 10:40 PM
03/05/18 10:40 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
How long do your batteries usually last down in Florida? I figured 3-4 years was normal down south?
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Replaced battery today [Re: SilverFusion2010] #4685728
03/05/18 10:45 PM
03/05/18 10:45 PM
Crawfordville FL
Crawfordville FL
I used to get 5 years out of a battery. The first Bosch that died lived its life in North Georgia before I moved back to the panhandle.
I hooked up the batteryMINDer when I got home for an overnight topping charge. Iíll be topping it up at least once a month I think.
Re: Replaced battery today [Re: SilverFusion2010] #4685744
03/05/18 10:57 PM
03/05/18 10:57 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Not long at all... frown
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: Replaced battery today [Re: SilverFusion2010] #4685746
03/05/18 10:58 PM
03/05/18 10:58 PM
GA
miden851 Offline
miden851  Offline
GA
mine normally lasts about 3 years, i had all major brands in past 9 years
2008 Mazda6i GT; @215K miles
2016 Honda CR-V EX-L; @40K miles
Re: Replaced battery today [Re: SilverFusion2010] #4685761
03/05/18 11:09 PM
03/05/18 11:09 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Mine seem to last about 3 weeks longer than the warranty. My brother has been a mechanic for about 20 years now and in his opinion the 96R is one of the worst; none of the manufacturers seem to make a ďbetterĒ 96R. IMHO buy the cheapest one since youíll be replacing it in short order.
Re: Replaced battery today [Re: SilverFusion2010] #4685765
03/05/18 11:14 PM
03/05/18 11:14 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
3 years is the average lifetime for a battery that lives under the hood in the engine compartment. I get 12 years out of my Bosch batteries.
Re: Replaced battery today [Re: SilverFusion2010] #4685766
03/05/18 11:17 PM
03/05/18 11:17 PM
california
wrcsixeight Offline
wrcsixeight  Offline
california
The average temperature of the battery, followed by its average state of charge through its lifespan, will have much more effect on battery life than the sticker on the casing.
Since it takes a long time to charge from 80% to 100%, but can be drained from 100% to 80% quickly, the voltage allowed by the vehicle's voltage regulator will play a huge part in how quickly and closely it is returned to the ideal 100% state of charge, which in a vehicle, is basically never.
So it is likely the battery is junk. Most starting batteries are. Most are designed to last only the warranty period and a day, and battery manufacturers are doing their best to cheapen them to this ideal max profit point and spending part of that profit on marketing.
A wise person wanting to make the battery last far longer than the warranty period, would protect it from engine heat as best as possible, and use a grid powered charger to top it off every so often, and asap after any significant discharge of it.
Average state of charge, and average battery temperature. Both of these can be influenced by the vehicle owner to some degree.
Re: Replaced battery today [Re: SilverFusion2010] #4685841
03/06/18 01:54 AM
03/06/18 01:54 AM
Romania
Andy636 Offline
Andy636  Offline
Romania
Sorry about your misfortune.
I'm not familiar with the coding in the US, but on this side of the pound Bosch batteries are coded S3, S4 and S5.
Got two S5 running in two diesel vehicles like a clock for about 5 years each and that is quite good since we have hot summers and pretty could winters (100 to -5)
Re: Replaced battery today [Re: SilverFusion2010] #4685842
03/06/18 02:03 AM
03/06/18 02:03 AM
Connecticut 06033
oilmutt Offline
oilmutt  Offline
Connecticut 06033
Next time consider buying a interstate battery from Costco they all come with a 42 month free replacement! Plus their $15 TO $25 cheaper than any place else.
'05 Chevy Malibu 6cyl,119k, Syn. Oil (owned)
'16 Toyota Camry,4cyl 25k Syn oil (leased)
'92 Ford Tempo ,4cly 26k Conv oil (managed)
Re: Replaced battery today [Re: SilverFusion2010] #4685859
03/06/18 03:05 AM
03/06/18 03:05 AM
Under the hood
Carmudgeon Offline
Carmudgeon  Offline
Under the hood
Bosch switched their US battery supplier to Exide in 2008, so any examples bought within the last decade or so would be Exide-, not JCI-made junk.
Re: Replaced battery today [Re: SilverFusion2010] #4685867
03/06/18 04:01 AM
03/06/18 04:01 AM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
Avg age of the batteries I've replaced last year was 3 years (5+2+2+3). Heck it was a record year for me seeing car batteries dropping a cell which luckily some were under warranty.
Heck I've periodically used a pulse shooter battery tester to check for battery strength but they can't predict when a cell is gonna die. I've always carried jumper cables for that reason.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Replaced battery today [Re: SilverFusion2010] #4685906
03/06/18 06:39 AM
03/06/18 06:39 AM
Crawfordville FL
Crawfordville FL
Yeah I keep a set of cables with me.
This new battery has a slightly different design, no removable vent caps. Iím hoping that means it has a slightly higher internal pressure so gases recombine. It has a bit better amp ratings vs the Bosch it replaced.
Itís wait and see now.
Re: Replaced battery today [Re: SilverFusion2010] #4685907
03/06/18 06:41 AM
03/06/18 06:41 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I suspect batteries will continue to be an issue for most drivers. Companies trying to be competitive in their offerings, production being moved off shore, the companies selling under their own label like Walmart negotiating to save the last penny.
I guess it's best to fully test the battery spring and fall and replace if it does not test well.
At least batteries are well recycled so replacing a little early does not consume more of the Earth's resources.
2015 Ford F250 w/Powerstroke
Re: Replaced battery today [Re: SilverFusion2010] #4685978
03/06/18 08:48 AM
03/06/18 08:48 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Its impossible to compare batteries in a forum nationwide. Spent most of my life up in NY until 10 years ago.
Im in shock how quickly batteries get killed by the heat down here ...
I used to think cold kills batteries, NO cold doesnt kill batteries, not like heat does and the South Carolina/Georgia area away from the coast gets far hotter on many days then Florida in the summer. (no ocean nearby)
Anyway, Walmart down here has 3 year replacement and I think Sams club too. We have received many free batteries for all our vehicles so far. Just got lucky and had them die right before warranty ended and then sometimes not so lucky and right after.
I now realize, heat kills batteries, never much thought about it till moving south..
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Page 1 of 3 1 2 3
