Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
52 registered (4WD, alphadog, bbhero, cb4017, boulderdentist, 3 invisible), 1054 Guests and 35 Spiders online.
65303 Members
67 Forums
285886 Topics
#4685561 - 03/05/18 07:37 PM LCA : Replace bushing or the entire unit
MaximaGuy Offline
Loc: Austin, TX
Took in my Highlander for my struts to be replaced with OEM struts and the tech mentioned the LCA bushings are worn.
What is the general recommendation - replace entire unit (OEM is $200/unit) or replace the bushings with Moog/BA units.
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
#4685573 - 03/05/18 07:43 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
Trav Offline
Loc: MA, Mittelfranken.de
Rust shouldn't be an issue where you are, use OE bushings if available, no aftermarket arm will be as good as OE.
Don't let anyone talk to into using poly bushings.
#4685597 - 03/05/18 07:55 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
HoosierJeeper Offline
Loc: WI
Sometimes all aftermarket arms are the same as OEM...for example on my Liberty only one manufacturer makes the control arms. But then anyone can throw bushings into it and that's where the quality differences happen. But the metal is all the same. No idea if the Highlander is like that.
I'd call/email BA and ask where they were made. If it's the same as the OEM ones, get that. I have BA ones on my LR3 and they were identical to the factory ones (made in UK). Moog I'd use if you can get the K series (no R or RK) and if the price is right.
I'm inclined to think it's less expensive to buy new ones instead of getting new bushings put in the old ones. Figure 3 bushings each at $40, so $120 per arm or $240 overall. Add ball joints too if those are in the arm. Plus way more labor and more potential for something to go wrong. Either way it's probably near a $600 job. Ask the shop for their labor estimates.
Edited by HoosierJeeper (03/05/18 07:56 PM)
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4685615 - 03/05/18 08:05 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
Trav Offline
I just looked at the bushings, Moog does have a superior bushing for this application, it will last many time longer than the rubber only. That's what I use on GM arms that are always popping the front bushing, great part.
http://www.rockauto.com/en/moreinfo.php?pk=6820840&cc=1432848&jsn=376
#4685680 - 03/05/18 08:53 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
MaximaGuy Offline
Loc: Austin, TX
I believe the main LCA bushing is the only bushing on the unit that is pressed. the LBJ is a separate piece which is quite neat when it comes up for replacement.
I will call BA tomorrow and also my installer (he already told me it is cheaper to replace the entire unit in one piece, wonder why when there is only ONE pressed in bushing).
If I do go down the bushing path I will buy the ones that have some play and stay away from the non-play polyurethane ones.
2018 MB GLE350
2011 Lexus ES350
#4685784 - 03/05/18 10:41 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
Trav Offline
Did you check out the bushing I posted a link to? That is not a rubber bushing but a sealed metal ball joint. I would prefer that over any other solution.
Aftermarket arms can be trouble, I have had more than one off so much the front end couldn't be aligned and a few that were on the edge.
#4686237 - 03/06/18 12:17 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
MaximaGuy Offline
Loc: Austin, TX
Tech quoted my 11 hrs labor based on the Mitchell manual. Something is wrong here..
There is this stupid transmission mount on top of the LCA bolt but other than that, loosening the motor mounts, removing the left transmission mount, raising the engine and getting the LCAs out.
Something is amiss here.
2018 MB GLE350
2011 Lexus ES350
#4686360 - 03/06/18 02:12 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
Trav Offline
I am showing 9.8 hours for both sides so realistically 11 hrs is about right. It seems a little long but you never know. Can you do this yourself?
Its not the first time the book has been wrong but if that is correct you want to keep the OE arms or replace with OE or use the best bushings you can get. You don't fiddle around with el cheapo parts when that much labor is involved.
Edited by Trav (03/06/18 02:15 PM)
#4686382 - 03/06/18 02:33 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
MaximaGuy Offline
Loc: Austin, TX
Honestly I wouldn't even venture to tackle this job - there is a video on the web (4 part video) with plenty of profanity
https://www.youtube.com/watch?v=djdejCyvc2g
where its done in 2+ hrs.
My tech told me to get the OEM LCA and he wouldn't push the bushings in as they can get destroyed.
2018 MB GLE350
2011 Lexus ES350
#4686474 - 03/06/18 04:05 PM Re: LCA : Replace bushing or the entire unit [Re: MaximaGuy]
Trav Offline
I haven't done one so I don't know how fast it could be done if you knew all the ins and outs of it. From the look of it 2.5 hrs per side seems to be doable but I wouldn't price it based on that. Sorry I couldn't be more helpful.
