Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
37 registered members (bullwinkle, 97K15004WD, CC1981, 69Torino, bbhero, 5 invisible), 960 guests, and 39 spiders.
Topics295,207
Posts4,929,904
Members66,711
Most Online2,553
Oct 27th, 2018
Transmission flush 1997 Explorer #4685369
03/05/18 04:30 PM
03/05/18 04:30 PM
Raleigh-Durham NC
racer44 Offline OP
racer44  Offline OP
Raleigh-Durham NC
I have 191,000 miles on my Explorer have flush the transmission every 30,000 miles. I do it myself thru the transmission cooler pumping 2 quarts out pouring 2 quarts in. Has been a Great SUV! Will I benefit using Mercon V over regular Mercon?
Re: Transmission flush 1997 Explorer [Re: racer44] #4685374
03/05/18 04:32 PM
03/05/18 04:32 PM
Wisconsin
wallyuwl Offline
wallyuwl  Offline
Wisconsin
Why only two quarts? You could do the whole amount using that method pretty easily and only have to do it every 50k, at the most. Upgrading the a newer version of fluid won't hurt anything and may help the transmission run cooler.
Re: Transmission flush 1997 Explorer [Re: racer44] #4685386
03/05/18 04:48 PM
03/05/18 04:48 PM
USA
slacktide_bitog Offline
USA
Does your transmission have a drain plug? If not, Dorman might make an aftermarket pan that has one, making future ATF changes much easier smile
There is nothing wrong with using Mercon V over regular Mercon, but you may wish to consider using a full synthetic ATF like the popular Maxlife
Re: Transmission flush 1997 Explorer [Re: racer44] #4685396
03/05/18 04:56 PM
03/05/18 04:56 PM
Raleigh-Durham NC
racer44 Offline OP
racer44  Offline OP
Raleigh-Durham NC
When I do the transmission flush I run 14 quarts thru the system and move the gear selector thru all the gears while doing the flush.
Re: Transmission flush 1997 Explorer [Re: racer44] #4685423
03/05/18 05:24 PM
03/05/18 05:24 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Did a drain & fill on friend'sExplorer, '04 V-6 @ 57K. The 5 qt which drained wasn't too bad.
Used Mercon V. The family also had a '97 F-150 and the Mercon spec was superseded to Mercon V.
Rigged a pressurized bottle to fill through "that thing" mounted in the oil pan.
What's that fitting called?
Re: Transmission flush 1997 Explorer [Re: racer44] #4685554
03/05/18 07:33 PM
03/05/18 07:33 PM
US
JLTD Offline
JLTD  Offline
US
I'd stick with what you are doing, it's working!
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 41k, OE 5w30/Wix
Re: Transmission flush 1997 Explorer [Re: racer44] #4685711
03/05/18 09:32 PM
03/05/18 09:32 PM
Maricopa, Arizona
dave1251 Offline
dave1251  Offline
Maricopa, Arizona
I had a 2002 Explorer. I just used regular Pennzoil DEX III. Flushed about every 40K.
don't use.
Re: Transmission flush 1997 Explorer [Re: racer44] #4685712
03/05/18 09:33 PM
03/05/18 09:33 PM
Albany, NY
ford46guy Offline
ford46guy  Offline
Albany, NY
Only Mercon V for these transmissions. If you have the v6 w/ 5R44E, These transmissions have a temperature valve, so you aren't flushing the converter unless you are at operating temperature.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Transmission flush 1997 Explorer [Re: racer44] #4685797
03/05/18 10:59 PM
03/05/18 10:59 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
The Mercon V is an improvement over the Mercon. Besides being a synthetic blend it likely has a stronger add package than most conventional Mercons. Merc V shears at about half the rate of Mercon. So your fluid will last longer. By around 2003 Ford was recommending Mercon V in most of its formerly Mercon transmissions. With cheap SuperTech Mercon V at $4.25/qt (it meets Ford approvals), no reason not to use it or a similar specced fluid. After 30K miles the Mercon would probably shear down from 7.4 to 4.0-4.5 cSt. While the Merc V might still be around 5.0-6.0. A full synthetic like Mobil 1 ATF would probably end up around 6.5-6.8. The Mercon V would maintain its transmission hydraulic characteristics longer than the Mercon...which would benefit better shifting and less wear & tear.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Transmission flush 1997 Explorer [Re: racer44] #4685807
03/05/18 11:14 PM
03/05/18 11:14 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
I wouldn't say there is a benefit, but Mercon V will work fine.
These transmissions aren't that picky...they just like clean fluid.
A friend recently bought a '96 with a 4R55E and 127K miles...we filled with Maxlife after a pan drop.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 224K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 200K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 246K miles
Re: Transmission flush 1997 Explorer [Re: slacktide_bitog] #4686027
03/06/18 08:52 AM
03/06/18 08:52 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
No drain plug on the factory pan, but Dorman does make a pan with a plug.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
