Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
80 registered members (allgm59, Alfred_B, andyd, 2010Civic, Ama0787, ABCarr, 8 invisible), 1,468 guests, and 62 spiders.
Topics286,215
Posts4,904,416
Members67,579
Most Online2,967
Mar 10th, 2019
Interesting issue, easy fix #4685232
03/05/18 02:47 PM
03/05/18 02:47 PM
Colorado
DenverGP Offline OP
DenverGP  Offline OP
Colorado
Daughter in law called with her 2013 Hyundai Elantra making a strange buzzing noise. Opened the hood, started it up, and buzzing sound coming from the fuse panel. Opened it up and it was the coolant fan relay. Fan seemed to be turning, but relay was buzzing a lot.
Swapped relays with another position, but the coolant fan relay kept buzzing. Pulled the relay out, and the two coil pins on the relay socket (85 and 86) had 12v and approx 4volts on them. The approx 4 volts was fluctuating between 3-5v.
Grabbed my OBD scanner, and found 2 pending codes: P2101 throttle control motor circuit range and P0620 generator control circuit.
Seemed in my mind that all 3 of these issues (2 codes plus the relay issue) were tied back to the PCM.
Removed the connectors on the the PCM, and sure enough, found water inside one of the connectors. Used an air compressor to blow out any moisture from the connector and the PCM pin socket. Reconnected and all symptoms resolved.
I put some extra dielectric grease around the connector boot/seal to hopefully prevent any future issues.
Can anyone recommend anything I can spray on the connector pins to prevent or stop any corrosion? Should I try for a bit of dielectric grease right on the PCM pins?
Re: Interesting issue, easy fix [Re: DenverGP] #4685243
03/05/18 02:55 PM
03/05/18 02:55 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
One would think that connector would be environmentally sealed. Is it damaged somehow? Maybe missing the rubber/silicone gasket seal?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Interesting issue, easy fix [Re: DenverGP] #4685254
03/05/18 03:03 PM
03/05/18 03:03 PM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
There is a product called DeoxIT that is made for this exact purpose, rejuvenates the electrical connectors.
Find out why the water got to the connector, then treat.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Interesting issue, easy fix [Re: DenverGP] #4685256
03/05/18 03:03 PM
03/05/18 03:03 PM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
CRC makes several electronic component cleaners. You might want to check their site to find what product best suits your needs. Kinda strange that the PCM would be located in a place where water would easily get to it. I would also check to see if there is a TSB on this particular issue or maybe check some of the Hyundai forums to see if this is a known issue.
Re: Interesting issue, easy fix [Re: DenverGP] #4685272
03/05/18 03:36 PM
03/05/18 03:36 PM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
us navy has had submarines sink from water getting into electric panels.
did an over eager person clean under the hood?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Interesting issue, easy fix [Re: DenverGP] #4685418
03/05/18 06:19 PM
03/05/18 06:19 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Good trouble shooting OP
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Interesting issue, easy fix [Re: DenverGP] #4685440
03/05/18 06:41 PM
03/05/18 06:41 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
You can put grease on the pins but if youve gotten it dried well it should be ok. Id figure out where the water got in and fix that.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Interesting issue, easy fix [Re: DenverGP] #4685471
03/05/18 07:10 PM
03/05/18 07:10 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
About a month ago my PCM (I looked it up) started making a high pitched whining noise.
Turned out I had a mosquito in my ear,
Re: Interesting issue, easy fix [Re: KGMtech] #4685555
03/05/18 08:34 PM
03/05/18 08:34 PM
KY
MCompact Offline
MCompact  Offline
KY
^^^ This.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: Interesting issue, easy fix [Re: KGMtech] #4685654
03/05/18 09:25 PM
03/05/18 09:25 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
+1
Root cause first, clean, then seal with a bit of dielectric as needed.
Re: Interesting issue, easy fix [Re: DenverGP] #4685669
03/05/18 09:43 PM
03/05/18 09:43 PM
california
wrcsixeight Offline
wrcsixeight  Offline
california
Caig DeOxit has a lineup of products.
The d5 spray is a cleaner, but there is a d100 liquid which has more cleaning power.
They have a gold product made for lightly oxidized contacts that use dissimilar metals
They have a shield product that does no cleaning, but it does protect and enhances contact conductivity.
I've had 3 cans of d5 spray. The first can left a reddish hue on Qtips and paper towels and seemed to clean much better than my last two cans that have no redish/pinkish hue.
I have had old crusty dielectric grease come ot of old connectors acting like someone stuffed scotch tape in the connector. I used crc QD cleaner to flush this old grease out and declared the connectr pristine, but then some DeOxit and some precision Qtips turned black as the contacts went from looking like 320 grit sandpaper to oiled chrome.
goto your pharmacy in teh dental care section. They have these micro bottle brushes for getting between teeth.
den tek bottle brushes
Also get some of these:
tamiya+precision+swabs
The amount of oxidtion I removed from all my sensor and computer connection contacts with these tools and Deoxit d5 and d100 was astounding.
After they are cleaned, I spray them with the Deoxit Shield S5 spray, then reseat them, then use Dielectric grease and try and force it into the closed connection to seal it from moisture. I will not fill connections with dielectric grease and force them together anymore. not after seeing it fall out of an older connection like Scotch tape layers.
LA 318 Roller Cam
Pennzoil Platinum 10w-30 SN Plus
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
Re: Interesting issue, easy fix [Re: DenverGP] #4686381
03/06/18 03:33 PM
03/06/18 03:33 PM
Colorado
DenverGP Offline OP
DenverGP  Offline OP
Colorado
I've got a can of the DeOxit D5 stuff on the way. Should be enough, doesn't look like the moisture had been there long, so not bad corrosion. I'm going to examine the rubber connector boot/seal to see if there are any rips/tears.
