Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
76 registered members (Alfred_B, andyd, 2010Civic, Ama0787, ABCarr, BHopkins, 8 invisible), 1,494 guests, and 61 spiders.
Topics286,215
Posts4,904,411
Members67,579
Most Online2,967
Mar 10th, 2019
Tacoma 4.0L V6 -- Condenser Line Leak? #4685099
03/05/18 12:24 PM
03/05/18 12:24 PM
Alabama
CrackyWainwright Offline OP
Alabama
On my 2013 Tacoma V6 4x4 there is a line that runs from the driver's side of the condenser to the AC compressor. Half of this line is aluminum, half is rubber, and the two parts are joined with a crimped coupling. Something neon GREEN and oily is leaking at the joint or coupling of this line. What am in for here in terms of difficulty and cost?
Re: Tacoma 4.0L V6 -- Condenser Line Leak? [Re: CrackyWainwright] #4685102
03/05/18 12:32 PM
03/05/18 12:32 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Yeah, it's leaking. What you see is tracer dye in the refrigerant oil.
You'd need a vacuum pump at a minimum to do it yourself, plus the receiver/dryer should be replaced whenever the system is opened. If you take it in you will have the cost of a new line, the receiver/dryer and a recharge. I have 609 certification and I do my own work, so I don't know what it costs to take it in. You might look up that line and the receiver/dryer on Rock Auto to get an idea of the cost, and call around for what an evacuation and recharge costs in your area. If both ends of the line are easy to reach the labor cost shouldn't be more than an hour.
5 years is pretty quick for the line to start leaking though. Too bad it isn't still under warranty.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Tacoma 4.0L V6 -- Condenser Line Leak? [Re: CrackyWainwright] #4685116
03/05/18 12:48 PM
03/05/18 12:48 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
Do they put dye in at the factory or has it been serviced before?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Tacoma 4.0L V6 -- Condenser Line Leak? [Re: CrackyWainwright] #4685120
03/05/18 12:51 PM
03/05/18 12:51 PM
Lake County, Ohio
ls973800 Offline
ls973800  Offline
Lake County, Ohio
I know that GM has been using green dye for several years now in many of their vehicles from the factory. I imagine that Toyota and other manufacturers are also doing the same thing.
Re: Tacoma 4.0L V6 -- Condenser Line Leak? [Re: CrackyWainwright] #4685201
03/05/18 02:07 PM
03/05/18 02:07 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
None of my cars had dye in the system from the factory, but that was a minimum of 18 years ago. Things may have changed since then.
1994 BMW 530i, 241K
Re: Tacoma 4.0L V6 -- Condenser Line Leak? [Re: kschachn] #4685219
03/05/18 02:25 PM
03/05/18 02:25 PM
Florida
artificialist Offline
Florida
Did any of them use R-134a? Back when R12 was used, the refrigerant oil was different.
2010 Lancer Ralliart Sportback
Re: Tacoma 4.0L V6 -- Condenser Line Leak? [Re: artificialist] #4685239
03/05/18 02:53 PM
03/05/18 02:53 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Yeah they all are 134a from the factory believe it or not. I think the major transition came around 1992.
1994 BMW 530i, 241K
