Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
captobvious, pgrkcs, 4Doors4Life, 780Ari, kayumb
66677 Registered Users
73 registered members (4WD, 2009Edge, aquariuscsm, Astro_Guy, bfleeman, 9 invisible), 990 guests, and 46 spiders.
Topics295,047
Posts4,926,827
Members66,677
Most Online2,553
Oct 27th, 2018
G-05 in a 2000 Saturn #4684799
03/05/18 05:41 AM
03/05/18 05:41 AM
Tennessee, United States
ZraHamilton Offline OP
I have a 2000 saturn sl1 with 165k miles. The coolant in it now is the generic green and it's been in there for at least 4 years. I'm going to do a flush and refill. The recommended coolant is dexcool, but I was going to use Zerex G-05 instead. Are there any problems with doing this?
Also, has dexcool cleaned up its act since the sludge issues 10-15 years ago?
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4684818
03/05/18 06:15 AM
03/05/18 06:15 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
There are years of opinions concerning Dexcool if you Google it. The only issue I would be worried about is the green coolant you've been using most likely had silicates and so will G-05. Did GM design the water pump shaft seal to be reliable with silicate containing coolants or just Dexcool which is silicate free?
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4684854
03/05/18 07:13 AM
03/05/18 07:13 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I'm sure after 18 yrs the wp has been changed.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4684980
03/05/18 09:34 AM
03/05/18 09:34 AM
I think it is original. I have noticed black specs in the reservoir which could be from the water pump gasket.
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4685039
03/05/18 10:22 AM
03/05/18 10:22 AM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
Sealing material incompatibility with Dex-Cool was never a Saturn S-Series problem. Neglectful owners could cause a few issues, primarily -
1. Mix OAT (Dex-Cool) with conventional green, causing "sludge".
2. Let OAT (Dex-Cool) run low in iron engines, causing internal rust. Your engine is all aluminium, so not applicable.
Do not listen to anyone who tells you there's an issue with this coolant formulation in these cars; I own a '01 SW2.
Could you run G-05? Sure. I don't know why you would though.
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4685128
03/05/18 12:00 PM
03/05/18 12:00 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
If the engine specs Dex-cool, then why not use a simple Dex-clone such as Prestone AMAM, or even WalMart's brand of Dex-clone. Cheap, easy to come by, and essentially what your car specs.
Don't get me wrong, G-05 is great stuff, but why use it if the less-expensive and more commonly-available AMAM products are closer chemically to what your engine 'wants'?
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 266,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 60,000mi
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4685257
03/05/18 02:03 PM
03/05/18 02:03 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
G05 works great in most any car, just get all the old stuff out first with lots of water. I converted my 2002 Century to G05 when i bought it from the previous owner and it was pretty nasty before, but now its pristine as i recently did the water pump on it. G05 is a great coolant.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4686427
03/06/18 03:16 PM
03/06/18 03:16 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Can anyone point me to any semi modern cooling system that would have the water pump shaft lubricated by coolant i.e. sleeve instead of a ball bearing?
2015 Dodge Grand Caravan-27k miles.
2006 Mazda 3-163k miles
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4686612
03/06/18 06:30 PM
03/06/18 06:30 PM
California
nthach Offline
nthach  Offline
California
Why not stick to Dex-Cool or Prestone/SuperTech/house brand all makes all models/universal coolant? A Saturn's engine was pretty modern by GM standards alongside the Northstar V8 of the 1990s.
Dex-Sludge affected GM's all-iron engines that also had "open" cooling systems and in the case of the 1996-2000 truck/van engines and the 3.1/3.4/3.8L car engines the intake manifold gaskets softened up upon exposure to Dex-Cool as the main corrosion inhibitors are known plasticizers - GM used a nylon gasket with silicone sealing beads that was updated to fluoropolymer molded onto a stainless steel carrier.
Re: G-05 in a 2000 Saturn [Re: ZraHamilton] #4686725
03/06/18 07:41 PM
03/06/18 07:41 PM
pa
benjy Offline
benjy  Offline
pa
get full strength dexcool @ wally's cheap + 88 cent gallons of distilled water, flush with distilled water NOT tap water!!
