flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
Any apple experts here?
by maverickfhs
06/18/18 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
06/18/18 02:34 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
85 registered (4WD, 69Torino, 87sammy, 2004tdigls, 2strokeNorthstar, 10 invisible), 1448 Guests and 36 Spiders online.
65265 Members
67 Forums
285568 Topics
Page 1 of 3 1 2 3 >
#4684665 - 03/04/18 09:56 PM Best synthetic oil for 2017 Ford F250 6.7L Diesel
trod30 Offline
Loc: Roseville, CA
Also 5w40 vs 15w40 opinions. I realize this topic has probably been covered many times, but I want the latest and greatest opinions and minds to base my decision off of. Also does anyone know what the Factory Fill might be on this truck? Why is Amsoil not on Fords approved oil list? I tow 8500lbs-9000lbs 5-6 times a year. temperature here is 32-105 degrees. June through September are typically over 90 degrees.
#4684676 - 03/04/18 10:06 PM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
2015_PSD Offline
Loc: SE Texas
Factory fill is 10W-30. You will, undoubtedly, receive many opinions on this. I run 5W-40 because the justification on Ford's part for severe duty is not much and for the cost difference, for me, it is easier to use 5W-40.
2018 MB AMG GLC43 3.0L Coupe - M1 0W-40/OEM
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 5W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
#4684678 - 03/04/18 10:10 PM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
NH73 Offline
Loc: Pa, USA
Amsoil never is usually on nobodies list. Its not even on GM's DEXOS list. Just use Rotella T6 5w40 and call it a day. If you want to use 15w40 or 10w30, than you a lot more options.
Edited by NH73 (03/04/18 10:11 PM)
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
#4684682 - 03/04/18 10:13 PM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
4WD Online   confused
Loc: Texas
One of our managers put his on Delvac 1 5w40 on the first change a year ago. Pulls equipment too.
Service manager barked a little but the technician had already told him several folks were unhappy with Fordís attempts to push Motorcraft Ö
Edited by 4WD (03/04/18 10:15 PM)
#4684690 - 03/04/18 10:18 PM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
Linctex Offline
Loc: Waco, TX
Same here.
That's child's play compared to what we put our F550's through.... 20,000 lbs trailer loads every week for hundreds of miles.
#4684695 - 03/04/18 10:24 PM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
Snagglefoot Online   content
Loc: Alberta
From your owners manual the reccomended oil is 5W-40 CJ4 and is the oil recommended for severe service.
The 15W-40 is old school and is no longer recommended by Ford for this engine. Ford recognizes that wear also occurs during starts and a 5 weight is much better than a 15 weight for this.
Edited by Snagglefoot (03/04/18 10:25 PM)
#4684696 - 03/04/18 10:27 PM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
Loc: Alberta
Hereís an option. Donít pay attention to the cost. Itís the marked up Canadian cost that they never sell it at.
Edited by Snagglefoot (03/04/18 10:48 PM)
#4684917 - 03/05/18 08:36 AM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
beanoil Offline
Loc: Midwest, Illinois
OP asked about 5w40, so either Rotella or Valvoline Premium Blue are readily available. It's a wash, neither is better than the other.
I don't agree that 15w40 is old school, and it is still specifically in the owners manual and on Fords approved list.
Factory fill is 10w30, and what Ford recommends unless severe service, which basically amounts to towing over 1000 miles, or cold temperatures.
All that being said....
In the temperature range mentioned, and the OP's towing (9k, you won't even know it's back there with this truck) you can run pretty much whatever you want (and call it a day).
My opinion, Valvoline Premium Blue Syn Blend 10w30, and a Donaldson P502503 filter. Boring VOA, excellent UOA, follow the change minder, and drive.
beanoil: Tough under heat, real dirty afterwards.
#4684919 - 03/05/18 08:39 AM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
Donald Offline
Loc: Upstate NY
Rotella T6 or Delo 5W40. It should meet the Ford spec. Some of the initial blends of CK-4 did not meet the Ford spec and people stocked up on CJ-4 which did.
Amsoil will be fine but others are just as good.
A bypass filter will be a good addition, I have one on my F250.
2015 Ford F250 w/Powerstroke
#4684947 - 03/05/18 09:06 AM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: Donald]
beanoil Offline
Delo is not on Ford's blessed list. And won't be until Ford get's their act together.
Here is the link again. Henry's Nice List
I agree (in theory) that bypass is nice, but the best way to keep oil clean is regular changes. Of course, campground bragging is worth something.
Edited by beanoil (03/05/18 09:06 AM)
#4684958 - 03/05/18 09:12 AM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: beanoil]
Loc: Alberta
Directly from the 2017 owners manual ď For severe duty service use SAE 5W-40 API CK-4 ď And yes, you can run whatever the heck you want.
Edited by Snagglefoot (03/05/18 09:14 AM)
#4685009 - 03/05/18 09:54 AM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
Donald Offline
Loc: Upstate NY
#4685072 - 03/05/18 10:52 AM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
Loc: Alberta
If anyone is wondering when Ford started recommending 5W-40 for severe service instead of 15W-40 it was 2011, when the 6.7 Powerstroke was introduced. Thatís 7 years ago. I wonít argue if this is retroactive to prior engines.
#4685083 - 03/05/18 11:04 AM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: Snagglefoot]
beanoil Offline
I stand by what I said. 15w40 is in the recommended list, and yes you pretty much can run what ever you want.
5w40 may be great for temperature extremes, but the wider spread can shear more readily than a 10w30.
Severe duty is defined as towing over 1000 miles, or extreme hot or cold operation. The OP isn't freezing his rear off, or melting in desert heat. A 10w30 would be just fine. But again, you can run almost anything as long as it has 1000PPM of P and Z, the
WSS-M2C171-E spec.
From the Diesel Supplement....
Specifications
Materials Specification Name WSS-M2C171-E
Recommended motor oil (U.S.):
Motorcraft SAE 10W-30 Super Duty Diesel Motor Oil* XO-10W30-QSD WSS-M2C171-E
Recommended motor oil (Canada):
Motorcraft SAE 10W-30 Super Duty Diesel Motor Oil* CXO-10W30-LSD12 WSS-M2C171-E
Motorcraft SAE 15W-40 Super Duty Diesel Motor Oil* XO-15W40-QSD WSS-M2C171-E
Motorcraft SAE 15W-40 Super Duty Diesel Motor Oil *CXO-15W40-LSD12 WSS-M2C171-E
Motorcraft SAE 5W-40 Full Synthetic Diesel Motor Oil *XO-5W40-5QSD WSS-M2C171-E
Motorcraft SAE 0W-40 Full Synthetic Diesel Motor Oil *XO-0W40-DAS
#4685117 - 03/05/18 11:48 AM Re: Best synthetic oil for 2017 Ford F250 6.7L Diesel [Re: trod30]
Loc: Alberta
Comments on the wider spread shearing more readily are from the old days and Ford knows that.
Page 1 of 3 1 2 3 >
