sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
85 registered members (antonmnster, 53' Stude, amblerman, A310, 69GTX, 7 invisible), 1,905 guests, and 38 spiders.
Topics295,101
Posts4,927,813
Members66,684
Most Online2,553
Oct 27th, 2018
Testing premixed coolant with tester often shows.. #4684632
03/04/18 09:25 PM
03/04/18 09:25 PM
NY
TurboTravis Offline OP
NY
That it is mixed stronger than 50/50 (which should test -34F), anyone else ever seen this? I have some premixed in the garage now, I will test it here in a bit and post the exact number that I get.
Re: Testing premixed coolant with tester often shows.. [Re: TurboTravis] #4684639
03/04/18 09:32 PM
03/04/18 09:32 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
The long life coolants show -70F on my refractometer when mixed 50/50.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Testing premixed coolant with tester often shows.. [Re: TurboTravis] #4684655
03/04/18 09:45 PM
03/04/18 09:45 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Are you sure your using the right tester? Theres certain testers for certain antifreeze.
Re: Testing premixed coolant with tester often shows.. [Re: Warstud] #4684736
03/05/18 12:03 AM
03/05/18 12:03 AM
NY
NY
Yes.
Re: Testing premixed coolant with tester often shows.. [Re: TurboTravis] #4684737
03/05/18 12:04 AM
03/05/18 12:04 AM
NY
NY
Valvoline Asian 50/50 premix shows -45F on my tester.
Re: Testing premixed coolant with tester often shows.. [Re: TurboTravis] #4684942
03/05/18 08:59 AM
03/05/18 08:59 AM
Ada county Idaho
MRtv Offline
MRtv  Offline
Ada county Idaho
I have a 30 year old Prestone tester. I tested my G05 coolant mixed at somewhere near 50/50 in my F150. Tested at -34. Tested my Pentosin in the Versa Note which is a 50/50 mix from the bottle. Tests at just around -34 also. The tester works with a large needle indicator pointing to the temperature.
2014 Nissan Versa Note 1.6 liter engine. 1997 Ford F150 4x4 4.6 liter engine.
Re: Testing premixed coolant with tester often shows.. [Re: TurboTravis] #4684944
03/05/18 09:02 AM
03/05/18 09:02 AM
North Carolina
Urshurak776 Offline
Urshurak776  Offline
North Carolina
I have the Prestone tester. Picked it up at Walmart. You got me curious so i tested some 50/50 O'Reilleys Universal i have. Tested to -34.
2012 Hyundai Santa Fe, 130,000 miles, Havoline Pro DS Full Syn 5W-20, Auto7 Filter.
2014 Kia Rio, 80,000 miles, Havoline Pro DS Syn 5W-30, WIX Filter
Re: Testing premixed coolant with tester often shows.. [Re: TurboTravis] #4684955
03/05/18 09:10 AM
03/05/18 09:10 AM
Ada county Idaho
MRtv Offline
MRtv  Offline
Ada county Idaho
I have used my Prestone tester over the years and have had various mixes in various vehicles. It has read anywhere from 0 to -40. With where I live anything from -34 to -24 is fine with me.
