Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
31 registered members (avi1777, Black_Thunder, Bailes1992, BlakeB, 4 invisible), 568 guests, and 53 spiders.
Topics286,171
Posts4,903,546
Members67,572
Most Online2,967
Mar 10th, 2019
Chevy 4.3 Mobil 1 5w-30 #4684561
03/04/18 09:27 PM
03/04/18 09:27 PM
appalachia va
troutfisher Offline OP
appalachia va
I have 2005 chevy 1500 with the 6 cylinder 4.3
Hae always used mobil 1 syn 5w-30 5 quart jug
Questions
Is the a good oil for this motor?
On a cold start it is perfect,but about 3-4 mins running after it has a slight lifter tick,but once it fully warms up and the tick goes away,is this a oil issue or just normal?
Thanks
Re: Chevy 4.3 Mobil 1 5w-30 [Re: troutfisher] #4684582
03/04/18 09:48 PM
03/04/18 09:48 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
That's the old iron version, not the new one, right?
I have a 98 S-10, old iron 4.3, have run lots of oils through it though not due to age, due to time.
Ive found that the filter can cause a tick at startup. Now, not sure how the full size is set up - on mine, it's a remote mount on its side (pf52 type).
I found that fram orange and the old ST filters caused it in the cold. FU, purolator pure one, wix, don't.
So it may entirely be oil filter related. I can't really see how the use of M1 vs any other oil could be the cause, unless something is really dirty or really worn. But even then I'd think it would be at startup.
Id start with the filter. Don't even change the oil. Go from there.
Re: Chevy 4.3 Mobil 1 5w-30 [Re: troutfisher] #4684618
03/04/18 10:10 PM
03/04/18 10:10 PM
The land of USA-made Subies!
SubieRubyRoo Offline
The old 4.3 is 75% 350. It will take any oil, 30 weight or up. They shed alot of iron, so stick to reasonable OCIs. IMHO I wouldn't put a synthetic in it; you can toss PYB in it forever and it will run forever. It's a simple engine that just runs.
If you have clearance for the length, WIX makes a 2qt filter that fits 350s that should fit your filter mount. I forget the number of the filter but it shouldn't be too tough to find.
Re: Chevy 4.3 Mobil 1 5w-30 [Re: troutfisher] #4684629
03/04/18 10:23 PM
03/04/18 10:23 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Given the age of the engine, if the filter idea doesnt help, you might want to try 10-30 oil in case Its caused by worn lifters. How many miles on the engine?
If you want the job done right......do it yourself.
Re: Chevy 4.3 Mobil 1 5w-30 [Re: Snagglefoot] #4684688
03/04/18 11:17 PM
03/04/18 11:17 PM
appalachia va
appalachia va
Truck has 145k on it.Truck is driven on alot steep mountain grades
I use wix original filters from o reilys
Would 10w-30 help with the lifter noise?
Re: Chevy 4.3 Mobil 1 5w-30 [Re: troutfisher] #4684698
03/04/18 11:29 PM
03/04/18 11:29 PM
socal
barkingspider Offline
socal
10w30 may help w the tick . Try it w an AC delco filter and see if that works
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Chevy 4.3 Mobil 1 5w-30 [Re: troutfisher] #4684752
03/05/18 02:43 AM
03/05/18 02:43 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Those engines were notorious for piston slap. That could be what you are hearing, instead of "lifter tap"
The pistons expand when they warm up and stop slapping. When they are cold they slap around the bore. Not a big deal.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Chevy 4.3 Mobil 1 5w-30 [Re: bubbatime] #4684759
03/05/18 03:23 AM
03/05/18 03:23 AM
Arizona, USA
DesertDually Offline
Arizona, USA
I've never heard this in my life, and I've owned 4.3 V6 GM's for over 25 yrs continuously! Since the 4.3 is basically a 350 with 2 cylinders lopped off & a balance shaft fitted (in later years); how would the 4.3 be any more prone to piston slap than the venerable small block chevy V8?
'07 Ram 3500 5.9 CTD
'02 Benz CLK 430
'03 Kawasaki KLX400,'00 Kawasaki ZX12R
'94 GMC S-15 4.3
'85 Benz 300 SD
'78 Benz 300 CD
'70 Case 580 CK
Re: Chevy 4.3 Mobil 1 5w-30 [Re: troutfisher] #4684768
03/05/18 04:09 AM
03/05/18 04:09 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Questions
Thanks
Make sure your filters have the red silicone ADBV. None of the AC Delcos (PF52 or 47) do anymore. I often used Fram Tough Guards, built differently than Wix.
2019 Hyundai SantaFe 2.4 factory fill QS 5w20 / Factory OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Chevy 4.3 Mobil 1 5w-30 [Re: troutfisher] #4684865
03/05/18 08:38 AM
03/05/18 08:38 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
Another agreement on trying a different filter. Go with a Fram Ultra once -- you can use that filter for multiple OCIs up to 20,000 miles the new ones are rated for. When ever I used a Super Tech or Purolator Classic on my neighbors truck -- 2000 Dodge 5.2L -- it had a couple second tick from start -- warm or cold out. When we switched to the Fram Ultra -- the tick went away immediately -- warm or cold out.
Dale
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
QSHM 5W30 & FU (100K)
2000 Ram 4X4 5.9L (93K) PYB 10W30 & FU
Re: Chevy 4.3 Mobil 1 5w-30 [Re: DesertDually] #4685006
03/05/18 10:54 AM
03/05/18 10:54 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
You've NEVER heard of hypereutectic piston slap in a small block chevy/GM 4.3L? Never? maybe different years were more prevalent than others, but its definitely a common complaint.
Re: Chevy 4.3 Mobil 1 5w-30 [Re: bubbatime] #4685045
03/05/18 11:26 AM
03/05/18 11:26 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
I've owned like half a dozen 5.0/5.7L SBC trucks/SUVs and NEVER heard piston slap, even with a bunch of miles, questionable maintainance from however many previous owners, etc. I was under the impression this was a common issue on the 4.8/5.3/6.0 LS engines but not really ever something common on the older engines.
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
