silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
72 registered members (69Torino, Ablebody, andyd, A310, AMC, alphadog, 12 invisible), 1,312 guests, and 35 spiders.
Topics290,738
Posts4,849,390
Members66,033
Most Online3,590
Jan 24th, 2017
Mazda CX-5 67,000 mile ATF analysis #4684522
03/04/18 08:50 PM
03/04/18 08:50 PM
Utah
Themiker Offline OP
Themiker  Offline OP
Utah
After researching whether I should drain and fill the ATF on my car, it was clear there was absolutely no consensus for this model, Mazda only says it's "life time" fluid, and I couldn't find any ATF analysis for a moderate or high mileage CX-5. So I figured I needed good data to make a decision based on so I drained and filled mine at 66,900 miles and paid for a Blackstone analysis because I was just so curious with Mazda saying you never need to replace the fluid and others saying 30-40,000 miles.
I did buy the vehicle at about 65,000 miles but the previous owner said he didn't remember draining the ATF and wouldn't have done it unless it was part of the scheduled maintenance, which it isn't so I believe this is the original fluid. Blackstone says the fluid is all good and they'd try 75,000 miles but I don't know what the actual numbers mean so comments are welcome! For what it's worth, this is a 2014 Touring.
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684536
03/04/18 09:01 PM
03/04/18 09:01 PM
Soviet State of Washington
PimTac Offline
PimTac  Offline
From what I understand, there are two trains of thought. One is to leave the fluid unchanged. Mazda says it is a lifetime fluid but many including myself pause at that thought. The other is to change it every 30k. That also gives you the opportunity to change the filter at the 60k mark. Did you drop the pan?
This Mazda SkyActiv transmission is very good but compact. As long as you stick with the Mazda oem fluid you should be fine. I would also change the differential and awd system fluid as well.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684555
03/04/18 09:23 PM
03/04/18 09:23 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
WHat kind of ATF did you fill it with? Maxlife is very popular on here, and Castrol makes an awesome synthetic ATF that goes on sale sometimes smile
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684588
03/04/18 09:56 PM
03/04/18 09:56 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
VERY interesting additive package! (Lots of anti-wear stuff)
Thanks for posting!
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684589
03/04/18 09:56 PM
03/04/18 09:56 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Does anyone know where all the silicon comes from?
Re: Mazda CX-5 67,000 mile ATF analysis [Re: slacktide_bitog] #4684609
03/04/18 10:05 PM
03/04/18 10:05 PM
PimTac Offline
PimTac  Offline
Hopefully he used the Mazda fluid. This is not your every day variety automatic transmission.
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684634
03/04/18 10:28 PM
03/04/18 10:28 PM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
It tells me the Mazda engineers are right....absolutely no reason this fluid should be changed. Nevt time go 150k miles....
Re: Mazda CX-5 67,000 mile ATF analysis [Re: PimTac] #4684661
03/04/18 10:53 PM
03/04/18 10:53 PM
Utah
Themiker Offline OP
Themiker  Offline OP
Utah
I didn't drop the pan. It has a drain plug which I used as the purpose was mostly to test the oil. I did use Mazda fluid since their motor oil is so unique, I thought maybe the ATF would also be unique compared to the other brands. My car is just front wheel drive but I do have the differential fluid on my list - I'm just waiting until the weather is nicer.
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684672
03/04/18 11:01 PM
03/04/18 11:01 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
While transmission internals are becoming more robust, I don't believe in Lifetime fluids or Fills, because the chemistry is just not up to the task at this point in time, regardless of what the beancounters and Marketing groups try to convince us.
The new fluid will be cleaning and dispersing the old crud left behind so you might want to change fluid in another 30k or less.
Reading is fundamental; understanding is not a given ability.
Re: Mazda CX-5 67,000 mile ATF analysis [Re: philipp10] #4684697
03/04/18 11:27 PM
03/04/18 11:27 PM
Utah
Themiker Offline OP
Themiker  Offline OP
Utah
That's what I concluded but I don't know what the actual numbers mean so I thought I'd seek opinions. The insolubles are low and the actual fluid seems like it's in good condition. I think I'll do a drain and fill every 60K miles since you only get 46% of the fluid out. This schedule would mean I'd have 29% of the original fluid at 120K miles and 15% at 180K miles.
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684704
03/04/18 11:56 PM
03/04/18 11:56 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
It is interesting that they are using a small amount of Bariom (most likely Barium Sulfonate) which is a corrosion inhibitor.
Yes, but what about the condition of the friction modifiers due to oxidation? You cannot determine from a $28 basic analysis, and friction modifier chemistry does change over time.
Which brings up another topic and that is shearing. Is this is a low viscosity ATF or a nominal 7.5 [email protected] viscosity fluid? We cannot determine how much shearing occurred unless a VOA is done.
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684729
03/05/18 12:50 AM
03/05/18 12:50 AM
PimTac Offline
PimTac  Offline
Re: Mazda CX-5 67,000 mile ATF analysis [Re: Themiker] #4684878
03/05/18 08:58 AM
03/05/18 08:58 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
I didn't see any technical specifications in the link, but I suspect it is a LV ATF (approx. 5.9 to 6.2 cSt) formulated for this specific transmission.
