2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
suprise
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
Bad cylinder 3 misfire.
by Hemispheres. 12/14/18 02:49 PM
Small leak at toilet base - bad wax ring?
by Oro_O. 12/14/18 02:38 PM
Ok I take it back about Keurig
by StevieC. 12/14/18 02:29 PM
Edge 5W-30 7.9k miles '13 F150 5.0
by dustyroads. 12/14/18 02:11 PM
Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
77 registered members (AngryScientist, 69GTX, 86lxjunker, 10ecfarmer, atikovi, 2strokeNorthstar, 10 invisible), 1,671 guests, and 38 spiders.
Topics295,083
Posts4,927,432
Members66,682
Most Online2,553
Oct 27th, 2018
2009 Hemi valvecover removed! #4684503
03/04/18 07:31 PM
03/04/18 07:31 PM
The land of USA-made Subies!
SubieRubyRoo Offline OP
2009 Ram Laramie Hemi with 140k. Was helping my stepson replace all 16 flippin spark plugs due to a miss. Pulled the 2nd coil only to find the holes essentially filled to the brim with 5W20. A quick trip to AZ got the correct gasket set, and returned to the garage until well after midnight to get it operational again. Boy, how I miss the days of when it was so easy to pull a VC on my 5.0s....
Anyways, I was actually really impressed with how clean the Hemi was. He got the truck around 130k, so unknown oil and OCI prior to this. I suggested he go to a 5W30 HM oil to give a little more protection and hopefully keep those gaskets pliable. Thankfully, the much more difficult driver's side was all dry at this point. Enjoy!
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4684538
03/04/18 08:05 PM
03/04/18 08:05 PM
PimTac Offline
PimTac  Offline
Looks pretty good. Just some slight varnish but for the miles thats normal.
Cannot see signatures any longer so it doesn’t matter.
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4684563
03/04/18 08:27 PM
03/04/18 08:27 PM
Georgia
AVB Offline
AVB  Offline
Georgia
You should have replaced the grommets on the bolts while you had it off. Those grommets get hard too and don't keep enough pressure on the valve cover.
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4684646
03/04/18 09:37 PM
03/04/18 09:37 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Looks good!
Coming together is a beginning; keeping together is progress; working together is success.
Henry Ford
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4684802
03/05/18 05:45 AM
03/05/18 05:45 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Looks good thanks for the post.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: 2009 Hemi valvecover removed! [Re: JC1] #4684833
03/05/18 06:44 AM
03/05/18 06:44 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
2 sparky-poos per cylinder? That's an aircraft engine!
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4685195
03/05/18 01:03 PM
03/05/18 01:03 PM
Yeah Kira, they do not get my vote. The driver's side took over an hour just to change plugs because everything is packed in under the brake booster. I'd hate to see what's required to actually pull the driver's VC... that would definitely rank as a "pay somebody else to do it" job... PITA
Re: 2009 Hemi valvecover removed! [Re: Kira] #4685226
03/05/18 01:32 PM
03/05/18 01:32 PM
Florida
artificialist Offline
Florida
Not exactly. These engines didn't have 2 plugs per cylinder as a form of backup. Instead, they were used to get cleaner combustion.
2010 Lancer Ralliart Sportback
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4685345
03/05/18 03:57 PM
03/05/18 03:57 PM
I don't know if it's cleaner with two plugs... they all had some deposits, some more than others. Much more than my Fusion at 99k miles, and per displacement, they make about the same power (within 4HP adjusted for engine size). And when I found Dodge expects them to be replaced every 30k, well, holy dung beetles. No thanks!
To paraphrase: "That thing got a Hemi?" "'Shore do! :)" "I'll pass, thanks!"
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4685525
03/05/18 07:01 PM
03/05/18 07:01 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
When you have a large bore and a chamber that doesn't do low-speed swirl well, dual-ignition is an effective aide. If it wasn't, they wouldn't have gone to the trouble of fitting it.
The 2009 should be the 390HP variant of the venerable 5.7L, which is roughly 68.5HP/L, a figure that is quite decent for a truck engine, it also makes 407lb/ft of torque. My 6.4L is roughly 74.5HP/L. Considering the 3V 5.4L Modular of the same vintage made 320HP, or ~59.5HP/L comparing truck to car engines is a bit misleading.
I agree on the change schedule though, that was ridiculous but I believe no longer the case across the board, as my interval is like 3x that.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4685781
03/05/18 10:32 PM
03/05/18 10:32 PM
2009 Hemi =5.7L / 395HP
2011 Fusion = 2.5L / 175HP
Fusion 2.5 extrapolated to 5.7L = 399HP
Nothing earth-shattering since my 2001 Forester made 165HP from 2.5 as well, so 10 years plus DOHC only gained 10HP. Of all 3 engines the Fusion is by far the easiest to change plugs on smile
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4685783
03/05/18 10:35 PM
03/05/18 10:35 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Yeah, that's pretty close actually, LOL!
I hear ya on the ease of plug changing. The ones on the Expedition were NOT fun with the rear heater and A/C lines running over top of the. Extensions and universals came in handy there. I think the easiest ones were on our Focus. They were just "right there". Out they came, in went the new ones, it was like an 80's snowmobile, LOL
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4685989
03/06/18 08:04 AM
03/06/18 08:04 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Looks great
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 2009 Hemi valvecover removed! [Re: SubieRubyRoo] #4686041
03/06/18 09:07 AM
03/06/18 09:07 AM
KY
MCompact Offline
MCompact  Offline
KY
Looks good!
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i
Son's
2009 328i
Buy what makes you smile...
