Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
2012 Accord,QSUD 5W20,WIX 57356 filter,3K miles
by aquariuscsm. 12/11/18 07:05 PM
Check out this awsome work!
by Chris142. 12/11/18 06:47 PM
200,000 miles
by Marco620. 12/11/18 06:29 PM
tcoffin014, Schm1d, EagleC, Dinka, MechanicGuy
66654 Registered Users
19 registered members (billt460, ctechbob, CleverUserName, BigShug681, David1, 2 invisible), 800 guests, and 35 spiders.
Topics294,961
Posts4,924,864
Members66,654
Most Online2,553
Oct 27th, 2018
valve cover removed #4684465
03/04/18 06:57 PM
03/04/18 06:57 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
while I am waiting for the right mount on my car I decided to tackle valve cover gasket today that was sipping on its back; I replaced it about 3 years ago with Felpro, so little to short IMO. Once I removed the gasket from its groves it snapped open circuit, talking about quality. Also I've noticed a small crack like a hair on the cover along the grove. This time is Felpro again from Amazon that I had stashed away not long ago; if it leaks again sometime down the road, ill go at lilaclocar Mazda and get the new valve cover and gaskets.
the oil used was conventional 5w-20 of any prominent brands majority of its life, changed at 3k normally with use of a basic filter with 95% efficiency
Enjoy
2008 Mazda6i GT; @208K miles
2016 Honda CR-V EX-L; @36K miles
Re: valve cover removed [Re: miden851] #4684475
03/04/18 07:00 PM
03/04/18 07:00 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
Re: valve cover removed [Re: miden851] #4684476
03/04/18 07:01 PM
03/04/18 07:01 PM
CT USA
MajorCavalry Offline
CT USA
Looks great!
Steve
2015 Lexus GS 350 CPO
12K miles
Just purchased.
2016 Lexus IS 300 AWD (gone, just too small)
16K miles
Castrol Edge 0W-20
Toyota filter
Re: valve cover removed [Re: miden851] #4684478
03/04/18 07:03 PM
03/04/18 07:03 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Pics look great, thanks for posting.
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Re: valve cover removed [Re: miden851] #4684482
03/04/18 07:10 PM
03/04/18 07:10 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Nothing to see here folks... Looks great.
But of course its always fun to look under the VCs!
smile
Re: valve cover removed [Re: miden851] #4684499
03/04/18 07:29 PM
03/04/18 07:29 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Looks like a high quality gasket. Silicone rubber? Usually those don't leak. You mentioned the cover is cracked? That's likely your leak source.
Otherwise, everything looks quite good.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: valve cover removed [Re: miden851] #4684571
03/04/18 08:35 PM
03/04/18 08:35 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
187K @ 3K OCIs is 62 oil changes, or 6 a year. Seems like a bunch but it sure is clean in there.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: valve cover removed [Re: miden851] #4684578
03/04/18 08:44 PM
03/04/18 08:44 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
187,000 miles... everything looks fantastic!
Now, start going 10,000 OCI, I doubt you'll see any additional or excessive accumulation
Re: valve cover removed [Re: miden851] #4684584
03/04/18 08:51 PM
03/04/18 08:51 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Very shiny, but a bit complicated, notably the gasket in question. I usually make my own, but that'd be a challenge with that one.
Rocker cover appears to be plastic. Eeuw!
Re: valve cover removed [Re: OVERKILL] #4684587
03/04/18 08:54 PM
03/04/18 08:54 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
You mean apart from being broken? (6th picture down).
Not clear from OP's description but it might have happened during removal.
Re: valve cover removed [Re: Ducked] #4684608
03/04/18 09:05 PM
03/04/18 09:05 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Yes, obviously, LOL. It looks to be a nice silicone rubber gasket, those are usually lifetime units.
Re: valve cover removed [Re: miden851] #4684647
03/04/18 09:37 PM
03/04/18 09:37 PM
GA
miden851 Offline OP
miden851  Offline OP
GA
I thank you guys! Regarding the OC extending interval I'm a bit resented; I'm thinking the engine will start to leak if I use the synthetic oil for example
The new gasket certainly looks good and has good reviews on Amazon, it snapped just like that; I was baffled by that. It stayed attached to the engine block when I removed the valve cover. But once I got it in my hands it was already snapped. And yes there is a hair-like crack on the cover, around timing chain area; however it located is on the outside of the valve cover groove behind the gasket
thats the gasket I used and again
https://www.amazon.com/Felpro-VS50639R1-...over+gasket+set
Re: valve cover removed [Re: miden851] #4684700
03/04/18 10:33 PM
03/04/18 10:33 PM
socal
barkingspider Offline
socal
Looks clean. Thanks for the pics
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: valve cover removed [Re: miden851] #4684710
03/04/18 11:06 PM
03/04/18 11:06 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
I can't speak for Mazda. But, Mitsu uses metal gaskets (OEM) vs paper gaskets (aftermarket). Of course the prices are triple most times! Very nice and clean! Thanks for posting.
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: valve cover removed [Re: miden851] #4684794
03/05/18 05:17 AM
03/05/18 05:17 AM
NY
demarpaint Offline
demarpaint  Offline
NY
It doesn't get any cleaner than that.
God Bless Our Troops
