Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
15 Grand Caravan
by zrxkawboy. 12/16/18 02:18 PM
Pennzoil Platinum 5w30 at walmart.com
by Irishman. 12/16/18 11:08 AM
pcv cleaning
by macdole99. 12/16/18 10:39 AM
Solar lights that last all night
by Snagglefoot. 12/16/18 09:20 AM
Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
No collision totaled vehicle
by madRiver. 12/16/18 06:32 AM
Brightest backup light for my daughters car?
by BobsArmory. 12/16/18 06:26 AM
Landngroove, DanielH, Cpcz9382, PPWarrior, Robwashere4oil
66698 Registered Users
83 registered members (53' Stude, Balrog006, bfleeman, BeerCan, Astro14, bdcardinal, 12 invisible), 2,147 guests, and 41 spiders.
Topics295,156
Posts4,928,799
Members66,698
Most Online2,553
Oct 27th, 2018
Help wanted with a thermosat to prevent freezing. #4684460
03/04/18 06:54 PM
03/04/18 06:54 PM
Canada
expat Offline OP
expat  Offline OP
Canada
I want a thermostat switch to turn on a small 5v 2amp current to prevent a small device freezing.
I an confused. I see NO (Normally Open) 0c (32f) thermostats, but does that meen the circut closes at that temp and ABOVE, or closes when the temp DROPS to 0c and lower?
Re: Help wanted with a thermosat to prevent freezing. [Re: expat] #4684471
03/04/18 06:59 PM
03/04/18 06:59 PM
MIchigan
Warstud Online content
Warstud  Online Content
MIchigan
What is this small device ?
Re: Help wanted with a thermosat to prevent freezing. [Re: Warstud] #4684564
03/04/18 08:28 PM
03/04/18 08:28 PM
Canada
expat Offline OP
expat  Offline OP
Canada
A small warming eliment that can be attatched to a Hummingbird feeder.
Re: Help wanted with a thermosat to prevent freezing. [Re: expat] #4684579
03/04/18 08:44 PM
03/04/18 08:44 PM
ME
eljefino Online content
eljefino  Online Content
ME
Re: Help wanted with a thermosat to prevent freezing. [Re: expat] #4684903
03/05/18 08:23 AM
03/05/18 08:23 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Expat, aren't the hummers in Costa Rica this time of yr? grin2
Thick oil is better grin2
Re: Help wanted with a thermosat to prevent freezing. [Re: andyd] #4685095
03/05/18 11:19 AM
03/05/18 11:19 AM
Canada
expat Offline OP
expat  Offline OP
Canada
No, the Anna hummers stay all winter, but sometimes it will get cold enough for even sugar water in the feeders to freeze. Which means they can't feed at a time they probably most need it.
At the moment the heating element is on 24/7 but I would like to add a thermostatic switch like the simple 'Buttons'available.
These are available in NO (normally open) and NC (normally closed) and a temp setting.
I just need to know what is 'normally' so it switches with a falling temp not a rising temp.
Our power sorce is inside the house, so the thermostat in the link will not work.
Re: Help wanted with a thermosat to prevent freezing. [Re: expat] #4685126
03/05/18 11:56 AM
03/05/18 11:56 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Get a GFCI pigtail, and move the power source outside. Maybe use a low temp sensor from a security system wired in some how ? First is quick and dirty, 2nd is what you envision. grin2
Re: Help wanted with a thermosat to prevent freezing. [Re: expat] #4686110
03/06/18 10:33 AM
03/06/18 10:33 AM
Canada
expat Offline OP
expat  Offline OP
Canada
I do not want to complicate things, what I have works well and is safe.
I just want to add a suitable thermostat but I am confused as to the type I need
Re: Help wanted with a thermosat to prevent freezing. [Re: expat] #4686124
03/06/18 10:46 AM
03/06/18 10:46 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
They have thermostatic controllers that just plug into an outlet or extension cord. I have one for 0F but hey make them for 32F too.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Help wanted with a thermosat to prevent freezing. [Re: expat] #4686142
03/06/18 11:01 AM
03/06/18 11:01 AM
Canada
expat Offline OP
expat  Offline OP
Canada
OK I have found what I need to know:
"Bimetal disc thermostat. NC (Normal Close)
NC means that the circuit is closed when below the item marked temperature,
when above the item marked temperature, the circuit is open.
Automatic reset.
10A 250VAC"
So I need a NC.
What I have can be powered from a USB wall wart or if need be a 12v battery. Of course with a battery a thermostat would be a big advantage.
