Hi! I have been trying to figure out how to run a line from my T On the oil pressure sending unit to a remote filter setup.I see no 1/8 inner diameter oil lines out there. I have found many stainless lines for a turbo.bUt they use AN lines and I am not sure they will fit my filter mount that has 1/2 inch NPT. I do have npt fittings that fit the remote mount and provide a 1/8 barb for a line.I do admit to being a bit confused. The T on the oil pressure sending unit has 1/4 inch hole that another barb fitting fits onto.I will use an adapter to make it so an Amsoil bp 90 will fit on. If I can find a line I can have my bypass setup for around a hundred bucks.
I do think the AN fitting would be the best.I just don't get the size and fitting needed. sorry to babble on.Ideas?
