Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
120 registered members (2015_PSD, 87sammy, 2010Civic, 3311, 01rangerxl, 7 invisible), 1,794 guests, and 55 spiders.
Topics286,088
Posts4,902,367
Members67,560
Most Online2,967
Mar 10th, 2019
Roofing/Siding Question - Is this Fascia? #4684332
03/04/18 06:21 PM
03/04/18 06:21 PM
MURICA
maverickfhs Offline OP
MURICA
In the picture below, what's this siding trim piece called, fascia or something else??
I have a brick front and siding for a townhouse and this piece seems to be getting loose.
Does it a need compressor for nails or can be done with a hammer and nails?
Also, after this windstorm around here, 2 shingle pieces are missing from the roof. How soon they should be replaced? Since, we are expecting some rain later part of this week.
Thanks for the help thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684373
03/04/18 06:50 PM
03/04/18 06:50 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Fascia is the part behind your gutters. It's hard to tell what I'm looking at from this angle. May want to take another pic.
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684428
03/04/18 07:23 PM
03/04/18 07:23 PM
MURICA
MURICA
Here's another pict:
It's the part, right next to drain pipe(wooden trim)
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684470
03/04/18 07:59 PM
03/04/18 07:59 PM
Canada
expat Offline
expat  Offline
Canada
As Warstud says, facia is behind the gutters.
The second pic is the same as the first. Can you take a pic from the side so we can see what that wood trim is?
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684477
03/04/18 08:02 PM
03/04/18 08:02 PM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
Corner Board, Edge Board, Corner Trim, Corner Post...
Is it attached to studs, furring strips, or brick?
I'd try to screw it back into place, it was probably nailed to begin with.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Roofing/Siding Question - Is this Fascia? [Re: tom slick] #4684480
03/04/18 08:08 PM
03/04/18 08:08 PM
MURICA
MURICA
Thanks, it seems to be on the brick and was told, need brick nails for it.
Is it correct? Thank you.
Re: Roofing/Siding Question - Is this Fascia? [Re: expat] #4684483
03/04/18 08:10 PM
03/04/18 08:10 PM
MURICA
MURICA
This pict might help. Thank you.
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684531
03/04/18 08:56 PM
03/04/18 08:56 PM
MURICA
MURICA
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684543
03/04/18 09:14 PM
03/04/18 09:14 PM
PimTac Offline
PimTac  Offline
Brick nails? I’m thinking there would be a high chance of cracking the brick. How about drilling with a masonry bit and use a anchor and screw the board to the brick?
Cannot see signatures any longer so it doesn’t matter.
Re: Roofing/Siding Question - Is this Fascia? [Re: PimTac] #4684545
03/04/18 09:15 PM
03/04/18 09:15 PM
MURICA
MURICA
SO it'll be more of a masonry screw, means can be drilled and then screwed into the board, correct?
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684638
03/04/18 10:31 PM
03/04/18 10:31 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
It looks like the channel that the siding goes into
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: Roofing/Siding Question - Is this Fascia? [Re: Brybo86] #4684643
03/04/18 10:34 PM
03/04/18 10:34 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
I'm thinking the same. Looks like a J-channel.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684668
03/04/18 10:58 PM
03/04/18 10:58 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
Glue it back on with polyurethane construction adhesive.
Re: Roofing/Siding Question - Is this Fascia? [Re: maverickfhs] #4684669
03/04/18 10:59 PM
03/04/18 10:59 PM
PimTac Offline
PimTac  Offline
I am not a expert but I would think you need a anchor in the brick just like using anchors in drywall. There are soft metal ones that would be suitable.
Perhaps someone with more knowledge of brick will chime in.
