Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
72 registered members (Anduril, badduxx, bmwpowere36m3, ARCOgraphite, biodiesel, bbslider001, 8 invisible), 1,775 guests, and 55 spiders.
Topics296,775
Posts4,958,671
Members66,969
Most Online2,577
Jan 14th, 2019
Battery backup sump pumps are a must! #4684287
03/04/18 04:35 PM
03/04/18 04:35 PM
Massachusetts
VeryNoisyPoet Offline OP
Massachusetts
With the storm that just hit the northeast, my street lost power as usual for an intense storm. Rain caused unusually high water tables and the lack of electricity disabled sump pumps. My house was thankfully spared, but a neighbor who "never gets water" discovered a wading pool in their basement. At peak it was only a few inches above the floor as seen by the water line in the picture, but it ruined some rugs and made a huge mess of their stored belongings. In addition, it partially submerged the motor of their pedestal sump pump, creating a major shock hazard if power came back.
I like to scavenge devices to tinker with, so when another neighbor replaced their sump pumps, I grabbed the old units. After a little wiring adjustment, I rigged a 12 volt pump to an old but functional car battery. Took a few cycles of charging with their car and then pumping, but that little pump emptied their basement in a few hours.
Even houses like this without a water "problem" can suffer inconvenient and damaging floods during a blackout, or due to failure of their main pump system. An inch more water and the finished part of their basement would have flooded as well. A simple system of charger, deep cycle marine/RV battery, secondary float switch, and a 12 volt backup pump similar to what I used to (excuse the pun) bail them out could have saved them a ton of hassle. Such a system could be assembled from discrete parts, or bought quite cheaply as a kit and quickly installed piggyback style onto the main sump pump. Kits often come with an alarm that sounds to warn that the main pump is not operating and that water has risen enough to trigger the backup system.
If you have a sump pump at home, wait for a heavy rain and observe how often the pump cycles. If you unplug the pump, does water start to rise above floor level? If so, a backup system could save you thousands in damage. Unless you have multiple main pumps and an automatically starting generator or other emergency power system that will take over without human intervention, a battery operated secondary pump is a must.
1998 V70 GLT / 195k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Battery backup sump pumps are a must! [Re: VeryNoisyPoet] #4684322
03/04/18 05:06 PM
03/04/18 05:06 PM
Central NY
rsylvstr Offline
rsylvstr  Offline
Central NY
We have a double sump pump, one higher than the other.
And battery backup with a switch on her.
Life saver. As long as these [censored] pumps don’t Keep stop working.
Like clockwork I take one out and take back to Lowe’s for free replacement.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: Battery backup sump pumps are a must! [Re: VeryNoisyPoet] #4684367
03/04/18 05:49 PM
03/04/18 05:49 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I've had one as well for about 15 yrs with a battery tender(maintainer). Keep an eye on the acid level of the battery(even more than your vehicles) as they do tend to evaporate, causing early battery failure.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Battery backup sump pumps are a must! [Re: VeryNoisyPoet] #4684399
03/04/18 06:04 PM
03/04/18 06:04 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
We just have to worry about water coming into our house here, no basements to worry about.
But I agree, if I had a basement, I would probably be replacing my car batteries more often and using the "old" ones for something like this.
2018 Hyundai Santa Fe: Dealer oil, Mahle filter, 5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: Battery backup sump pumps are a must! [Re: VeryNoisyPoet] #4684432
03/04/18 06:28 PM
03/04/18 06:28 PM
One Step Beyond
MasterSolenoid Online content
MasterSolenoid  Online Content
One Step Beyond
Good advise. Thanks for posting.
My current Sump Pump is 15 years old and I will replace this Summer.
I have:
1) Extra Pumps ready to go.
2) Hand Pump discharges into Wash Tubs next to Sump Pump.
3) Sump Pump Alarm I made out of a Pressure Switch.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Battery backup sump pumps are a must! [Re: VeryNoisyPoet] #4684447
03/04/18 06:43 PM
03/04/18 06:43 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Yikes, I can't imagine having a living setup where such a sump pump arrangement was necessary.
We have a sump pump, in the hurricanes the sump never filled enough to make it turn on.
If it was worse than that due to water table, I wouldn't want anything lower than a few feet up!
Re: Battery backup sump pumps are a must! [Re: blupupher] #4684451
03/04/18 06:46 PM
03/04/18 06:46 PM
Central NY
rsylvstr Offline
rsylvstr  Offline
Central NY
I thought the same but was advised to stick with deepmchcle
Re: Battery backup sump pumps are a must! [Re: VeryNoisyPoet] #4684556
03/04/18 08:23 PM
03/04/18 08:23 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
My parents are experts in this field.
The backups to their sump pumps have back-ups to the back-ups, LOL!
They have a HUGE deep-cycle battery set-up - the 12v sump pump can run for many days on just batteries if need be
Re: Battery backup sump pumps are a must! [Re: VeryNoisyPoet] #4684644
03/04/18 09:34 PM
03/04/18 09:34 PM
Nowthen, MN
KD0AXS Offline
KD0AXS  Offline
Nowthen, MN
When we had our drainage system redone, we had one of these installed. It has two AC powered pumps and a battery backup pump. It also has its own charging system that keeps the battery ready to go and and a water level alarm.
https://www.basementsystems.com/sump-pump/triplesafe.html
Re: Battery backup sump pumps are a must! [Re: VeryNoisyPoet] #4684901
03/05/18 08:22 AM
03/05/18 08:22 AM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
There are pumps that run on city water pressure (no battery required) siphon-style.
I think the ratio is 2 gallons of of city water per 1 gallon evacuated.
This old house had 2 episodes where they mentioned and made demonstrations with these.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Battery backup sump pumps are a must! [Re: JHZR2] #4685462
03/05/18 06:04 PM
03/05/18 06:04 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
It's more a matter of how the tiles around the foundation, into which the gutter downspouts drain, are drained.
In an area with deep sewers and a house old enough that running storm water into the sewers was allowed when built, you can do just fine without a sump pump. How the house is situated will make a difference. If the house is located on a rise relative to surrounding terrain, then no sump pump will be needed. Rainfall averages and local area drainage also matter.
Water table isn't really the issue since areas with very shallow water tables have houses without basements.
The house I grew up in neither had nor needed a sump well and pump. The house we live in now needs the well and the pump.
During a heavy rain event, the sump pump will run quite a bit, often cycling more or less continuously.
This is why a spare is always nice to have on hand and also the reason that a battery backup might be a great thing in areas prone to prolonged power outages.
Of course, a generator would be a must-have in these areas as well and the genset would provide AC to run the sump pump.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
