Self defense
by Camprunner
35 minutes 36 seconds ago
Any apple experts here?
by maverickfhs
58 minutes 45 seconds ago
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
Today at 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
Today at 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
Today at 01:52 PM
Sell me on a SSD drive...........
by ZZman
Today at 01:07 PM
need some ideas on my issue
by matrass
Today at 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
Today at 12:36 PM
BMW V8 Oil Consumption Fix
by doc540
Today at 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
Today at 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
Today at 10:34 AM
Oil sample extraction
by Tikka
Today at 10:30 AM
Re-using building materials esp nails
by andyd
Today at 08:57 AM
Central A/C [censored] out
by TOMJ
Today at 08:43 AM
08 Scion tC under valve cover pics
by Highboy
Today at 08:39 AM
Storing extension ladded in garage?
by maverickfhs
Today at 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
Today at 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
Today at 02:36 AM
E4OD fluid ?
by Exhaustgases
Today at 02:23 AM
Update password ?
by meadows
Yesterday at 11:59 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
84 registered (379KITTY, 2015_PSD, 555, 2strokeNorthstar, 7 invisible), 1817 Guests and 35 Spiders online.
65262 Members
67 Forums
285527 Topics
Page 1 of 3 1 2 3 >
#4684266 - 03/04/18 04:21 PM Waterpump as PM?
ford46guy Offline
Loc: Albany, NY
I went to Lexus to get some touchup paint. I started talking to a tech, he told me at 100K if you DIY the coolant, change the WP. Said you can get the Aisin one online for $75. He has an IS350 and just did his at 100k. He told me Toyota pumps like to leak.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
#4684279 - 03/04/18 04:28 PM Re: Waterpump as PM? [Re: ford46guy]
supton Online   content
Loc: NH
Toyota seems to have an issue of late. But IMO unless if your model is known to absolutely eat WP's every 100k I'd just wait for it to go. I mean, they like to weep for a while--it's not like they blow apart all of a sudden, they give indication for a good while.
How hard is it to replace? If it's a 5 minute job, ok fine, no biggie. A couple hours? that's something else.
If it's buried behind the timing belt then I'd replace at TB time, sure. This motor, it's not a TB, right?
2011 Toyota Camry, base, 2.5L/6MT, 160k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 143k, ours
1999 Toyota Camry LE, 2.2L/4AT, 181k, his
#4684283 - 03/04/18 04:31 PM Re: Waterpump as PM? [Re: ford46guy]
nthach Offline
Loc: California
Toyota pumps on the newer cars tend to leak, I'm guessing the newer pink SLLC coolant doesn't play nice with the seals. They were replaced as PM on the older cars with timing belts.
Now, with Zerex's Asian formula using benzoate instead of sebacate for the OAT portion of its inhibitor package, I wonder if the pump can live a longer life before it springs a leak.
#4684289 - 03/04/18 04:36 PM Re: Waterpump as PM? [Re: supton]
ford46guy Offline
Loc: Albany, NY
No TB, maybe 1-2hrs. Lots of bolts.
#4684296 - 03/04/18 04:41 PM Re: Waterpump as PM? [Re: ford46guy]
spasm3 Offline
Loc: North Carolina
I'm going to replace my avalanche water pump as a pm. Lots of 3rd gear towing at 2700-3k. I'd rather replace it than have problems on a towing trip.
13 elantra 68k 5w30 QSUD
03 chevy avalanche76k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 3900 miles m1 0w20/0w40 mix
#4684299 - 03/04/18 04:43 PM Re: Waterpump as PM? [Re: ford46guy]
michaelluscher Online   content
Loc: Staten Island, NY
I remember seeing those new design pumps failing quite early
Think 3.5 2GR V6 or 2.4 2AZ I4
Some of them leaked off the truck, no fix in sight
Toyota's procedure was to hose it down with brake cleaner
If you spin some of these pumps dry by hand, when you take it out of the box (like we all do because spinny thing?) Apparently it can shorten it's life
It has these special carbon ceramic mechanical seals
Not just a rubber or Viton seal anymore
Unless you drive it real hard, or in a hot climate, I don't see the need to change preventatively
Especially as your on a timing chain, not a periodically serviced timing belt
I'd keep an eye out for any pink crusties, or weeping from the weep hole, then change it
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
#4684301 - 03/04/18 04:45 PM Re: Waterpump as PM? [Re: ford46guy]
rooflessVW Offline
Loc: North Carolina
If you have direct access to a water pump and it has over 50k, change it.
"Zed's dead baby, Zed's dead."
#4684306 - 03/04/18 04:53 PM Re: Waterpump as PM? [Re: ford46guy]
Warstud Offline
Loc: MIchigan
If it's a known problem for certain vehicles then YES. But I have almost 300k on my Blazer and it still has the original WP.
#4684348 - 03/04/18 05:37 PM Re: Waterpump as PM? [Re: ford46guy]
Trav Offline
Loc: MA, Mittelfranken.de
Is yours leaking? If not it sounds like you have a good one, I would be tempted to push it out a bit. The one on my MIL car started leaking at 23K so even if you replace it you might be in the same boat soon anyway. Toss a coin.
#4684376 - 03/04/18 05:52 PM Re: Waterpump as PM? [Re: Trav]
Snagglefoot Offline
Loc: Alberta
Trouble is, if you wait for the water pump to go, it will go just as you approach the off ramp to the worst hood in town, or perhaps on the way to the airport for your flight to Orlando to see Mickey, or both. smile
Edited by Snagglefoot (03/04/18 05:54 PM)
#4684381 - 03/04/18 05:54 PM Re: Waterpump as PM? [Re: Snagglefoot]
Trav Offline
Pumps usually give a warning time not just let go dumping coolant all over the place.
#4684386 - 03/04/18 05:57 PM Re: Waterpump as PM? [Re: Warstud]
Snagglefoot Offline
Loc: Alberta
ďNever confuse good luck with good judgement.Ē I donít think GM water pumps are known to go 300K. smile
Edited by Snagglefoot (03/04/18 05:58 PM)
#4684390 - 03/04/18 05:58 PM Re: Waterpump as PM? [Re: Trav]
rooflessVW Offline
Loc: North Carolina
Unless it's a VW or BMW, lol.
#4684393 - 03/04/18 05:59 PM Re: Waterpump as PM? [Re: Trav]
spasm3 Offline
Loc: North Carolina
I've always had them weep a bit or slowly leak. I'm replacing the avalanche one as i have noticed that my temp gauge on a hot day stays about the same place towing at 2500 or so. But if i get over 2700 rpm the heat gauge rises a good bit, not in the danger zone, but just more than i used to see it move years ago.
I'm thinking more about the impeller being worn, so i just feel better on a 15yo tow vehicle, changing it with the hoses and belts.
Edited by spasm3 (03/04/18 06:00 PM)
#4684409 - 03/04/18 06:11 PM Re: Waterpump as PM? [Re: spasm3]
Snagglefoot Offline
Loc: Alberta
Ditto with my Chev 3/4 ton. Itís true they weep first but it can turn to a stream. . Had one do that just before a family trip. I never had time to do it myself so now it turned into a nice repair shop bill.
Page 1 of 3 1 2 3 >
