Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
27 registered members (BigShug681, bmod305, 08z06, A1O, 53' Stude, billt460, 3 invisible), 529 guests, and 51 spiders.
Topics286,220
Posts4,904,513
Members67,579
Most Online2,967
Mar 10th, 2019
Which Dexron synthetic ATF for my 97 Toyota? #4684179
03/04/18 03:36 PM
03/04/18 03:36 PM
USA
Bob69 Offline OP
Bob69  Offline OP
USA
Quick question, I have a 1997 Toyota SUV which originally came with Dexron II/III ATF best that I can determine. In the past, like 15 years ago, I used Mobil 1 Synthetic ATF in another Toyota with good results. However I noticed the current Mobil 1 says MultiVehicle Formula on it. So the question is, will the current version of Mobil 1 Synthetic ATF be acceptable or is there another preferred synthetic ATF for a mid-90's Toyota automatic transmission? I thought that I could not use Dexron VI, but just read a GM paper that Dexron VI can be used in the older Dexron III transmissions?? Anyone have experience with the Mobil 1 ATF?
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684183
03/04/18 03:40 PM
03/04/18 03:40 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Mobil1 ATF is fine, so is the Valvoline Maxlife ATF.
Mobil1 oils are good.
Old Toyota is never too picky with ATF.
  • 2017 Toyota Sienna
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684197
03/04/18 04:00 PM
03/04/18 04:00 PM
Pa, USA
NH73 Offline
NH73  Offline
Pa, USA
Here is a link to your ATF in question: https://mobiloil.com/en/automatic-transmission-fluid/synthetic-atf. Dexron VI is not listed.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684207
03/04/18 04:11 PM
03/04/18 04:11 PM
USA
slacktide_bitog Offline
USA
Any quality synthetic ATF will be fine smile
WHile the M1 ATF doesn't meet the latest Dexron VI standards, that's ok in your case because your car only called for Dexron III which was the contemporary spec back then.
However, my choice would be Maxlife ATF, or Castrol Full Synthetic (when it goes on sale for $5/qt at the parts stores)
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684214
03/04/18 04:28 PM
03/04/18 04:28 PM
USA
Bob69 Offline OP
Bob69  Offline OP
USA
while waiting for replies I found the same link to Mobil 1 and did some more reading;
looks like the Mobil 1 synthetic ATF will work well. What confused me was the "Multivehicle" term, but apparently GM, which owns the Dexron name, no longer wants anyone to use or refer to the old Dexron classifications which GM considers obsolete. So now the ATF manufacturers use the term "pre-2006" which is code for Dexron II/III compatible.
Thanks
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684219
03/04/18 04:33 PM
03/04/18 04:33 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I used the Mobil 1 ATF in my Sienna for most if its life, but lately I've been using Maxlife because it's a lot less expensive. I've not noticed any difference.
I also use Supertech Dexron VI in my old BMW which calls for Dex III. It works well with no issues. I might try it in my Sienna assuming it is still running next time around wink
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684235
03/04/18 04:53 PM
03/04/18 04:53 PM
Long Island, N.Y.
incognito_2u Offline
Long Island, N.Y.
Quick question, I have a 1997 Toyota SUV which originally came with Dexron II/III ATF best that I can determine......
I don't have that much experience with the Mobil One transmission Fluid, but the Transmission fluid of the 1999 Corolla in my sig was "Flushed" and replaced with the "Valvoline Maxlife Full Synthetic ATF" fluid and would be a perfect match for your Toyota SUV.
The Corolla was also originally spec'd for Dextron II/III fluid.
Here's the Product Information Sheet:
Valvoline Multi-Vehicle Synthetic ATF
2006 Jeep Commander 3.7 V6 -112k (PUP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -81k (PPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -82k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -64k (PUP5W30/XG4386)
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684239
03/04/18 04:57 PM
03/04/18 04:57 PM
USA
Bob69 Offline OP
Bob69  Offline OP
USA
Found this page that lists all the different ATF fluids over the years, interesting read:
https://www.cartechbooks.com/techtips/autotransfluid/
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684258
03/04/18 05:17 PM
03/04/18 05:17 PM
socal
barkingspider Offline
socal
Any dex/merc will be plenty good. I like ST and Castrol
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684265
03/04/18 05:21 PM
03/04/18 05:21 PM
NH
supton Offline
supton  Offline
NH
Not sure what Aisin does differently, model to model, but Maxlife ATF seems to work just fine for many. That is what I have in my '99 Camry and my '10 Tundra.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 147k, ours
1999 Toyota Camry LE, 2.2L/4AT, 203k, his
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: supton] #4684321
03/04/18 06:06 PM
03/04/18 06:06 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Any Mercon V, especially Ford approved ones (ST, Castrol, Ford) should work fine too. The SuperTech Mercon V is cheap.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684388
03/04/18 06:57 PM
03/04/18 06:57 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Mobil 1 is what I've always used in any tranny calling for DexII/III/Mercon. I have also used MaxLife ATF with good success.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Which Dexron synthetic ATF for my 97 Toyota? [Re: Bob69] #4684535
03/04/18 09:00 PM
03/04/18 09:00 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
+1 for Maxlife; I use it in my friend's 2002 Tundra; comes in gallons @ a really reasonable price
Her vehicle takes 12 qts, i just do a D+F every two years or so, swapping out about 4 qts each time.
Also good for doing a suck and replenish of the PS reservoir
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
