Originally Posted By: AZjeff
Can you explain for the rest of us before this turns p*litical and disappears?
edit: Oh, AR-Mag-Lock... got it.
https://www.armaglock2.com/
Unfortunately your assessments were accurate, and I had to lock this down for a bit to remove a bunch of commentary that was either political, "legal advice" that could turn people into felons, etc.
The question was simple, the answers should relate to that in the context of the solution only.
Nobody (from Cali) has answered OP's question. What other options do you have?
Exactly. Moving away, hiding in an attic, ignoring laws are all things that are not within the context here, and BITOG is not a place for firearms related legal advice or advisement on actions that could have people violating laws.
I am reopening this thread to allow the appropriate discussion of this and other solutions. As I understand it, this device turns an AR into a system that must break the action, causing it to be opened up like an o/u or sxs shotgun to drop the magazine. This is apparently compliant with the current requirements, and per the maglock site, they say that some vendors are using this to assure CA compliance. They also weasel word about if it truly is. Consulting your own lawyer is the only basis for such advice.
Upon first glance, it doesn't look like the most inconvenient way to go, since the mag can still be dropped - it's not like it's permanently bolted in or something. It still requires the action to be opened, which seems to align to CA law. If it truly removes that "evil feature", it may allow others to be retained, like flash hiders, adjustable stocks, etc. since this itself can be removed/reverted without rendering the firearm inoperable, time will tell if it passes a sniff test.
