Originally Posted By: Shannow
You haven't read the linked papers, nor watched the video, have you ?
I saved the paper and I scanned the video... but I have a growing aviation
library so what do you want to know about the NB36???
And per the "shielding", they stated that they couldn't shield the reactors in the traditional method, as that would have been too heavy to get off the ground...they shielded the occupants from the radiation, not the reactors from the world.
NB36 ASTR reactor featured 60,000 pounds of reactor shielding and
37,000 pounds of crew shielding. The reactor shield was 60 feet long
and 12 feet in diameter... additional side shielding around the
reactor was provided by a 2.5 thick layer of polyethylene sandwich
between two sheets of aluminum, one which was the exterior skin...
This shielding system lowered the exposure rate from the 1 Roentgen
per hour down to 0.25 Roentgen per hour... so technically speaking the
USAF went to great expense to protect the world... after all we are
the good guys...
If you were the squiring enemy sweating our bombers your 1st line of
defense would be radar... follow up by visual contrails and droning
sound... by time it would take you sniff out 0.25 Roentgens worth of a
radioactive signature you could be pharting Peacekeeper's bombs...
