Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
71 registered members (bmwpowere36m3, Anduril, 240_Ed, badduxx, ARCOgraphite, biodiesel, 8 invisible), 1,844 guests, and 54 spiders.
Topics296,775
Posts4,958,671
Members66,969
Most Online2,577
Jan 14th, 2019
Opinions on used spark plugs #4683507
03/03/18 06:52 PM
03/03/18 06:52 PM
Va
FFeng7 Offline OP
FFeng7  Offline OP
Va
I finally changed the spark plugs in my Dodge. I have no idea of the mileage on these. At least 65-70K because that's how long I've owned the truck. Still ran great on the old sparkplugs and runs the same on the new ones. Replaced with NGK V Power. Also replaced the wires, cap and rotor. What's you guys opinion on the old ones??
2002 Dakota Quad Cab 4x4-Delo XLE 10w30-Fram PH16 Filter
2007 Cobalt LT-Supertech High Mileage Synthetic 5w30-Parts Plus Filter
Re: Opinions on used spark plugs [Re: FFeng7] #4683510
03/03/18 06:54 PM
03/03/18 06:54 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
They look pretty goo on the cylinder side. The outside looks like poo...
Re: Opinions on used spark plugs [Re: FFeng7] #4683521
03/03/18 07:01 PM
03/03/18 07:01 PM
USA
mk378 Offline
mk378  Offline
USA
Those are worn out. Conventional plugs should have a sharp edge on the center electrode.
Re: Opinions on used spark plugs [Re: FFeng7] #4683522
03/03/18 07:03 PM
03/03/18 07:03 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Valve cover gasket leaking on one side? The first one looks off a bit, check the wire to that plug and the terminal inside the cap.
Re: Opinions on used spark plugs [Re: FFeng7] #4683633
03/03/18 08:45 PM
03/03/18 08:45 PM
USA
oldhp Offline
oldhp  Offline
USA
Those are Autolite Platinums. That's why the center electrode is shaped the way it is. Cylinders look to be firing very clean.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Opinions on used spark plugs [Re: FFeng7] #4683645
03/03/18 08:59 PM
03/03/18 08:59 PM
New England
gathermewool Offline
New England
How far off from spec are they on gap?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Opinions on used spark plugs [Re: FFeng7] #4683685
03/03/18 10:02 PM
03/03/18 10:02 PM
Va
FFeng7 Offline OP
FFeng7  Offline OP
Va
The gap on these were not that bad. I didn't actually gap the old ones but compared to the correct gap on the new ones they looked reasonably close. I think the spec was supposed to be .040.
Re: Opinions on used spark plugs [Re: FFeng7] #4683743
03/03/18 11:57 PM
03/03/18 11:57 PM
Tennessee
SWS Offline
SWS  Offline
Tennessee
IMO, good preventative maintenance, and you were able to do it yourself - good for you!
You could not have known their condition otherwise.
What time s the total mileage on the vehicle?
Many years ago, I had 2 issues ( different cars, small-block Chevy, and VW Rabbit) in which the internal resistor messed up somehow. Plugs were not that old as I recall, but combustion side turned black from occasional missing. I could read greatly different resistance on the bad ones. Changed the plugs and restored perfect operation. Years later, changed those plugs and they were all perfect light brown.
Similar experience on common Briggs & Stratton lawnmower - changing last yearís perfect-looking plug with correct gap changes a non-start into first-time start. One variable!
Re: Opinions on used spark plugs [Re: FFeng7] #4683796
03/04/18 06:14 AM
03/04/18 06:14 AM
Frogland / Brittany / Canada
Popsy Offline
Popsy  Offline
Inside part : Look pretty clean, gap seems fairly consistent cheers
Outside part : not so good smile I don't often see rusty plugs on the outside like that...well all my car have their plugs hidden under one million stuff, that could explain !
Well, if they had 65-70K, I still think you did good changing them (especially since you did it yourself), just to prevent some later removing issues, if the rust had gone worse.
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 0W40 | Colt Ralliart, 300V 0W40
Re: Opinions on used spark plugs [Re: FFeng7] #4683815
03/04/18 07:20 AM
03/04/18 07:20 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
The two plugs that have some oil/residue on them -- where they the back two on either side closest to the cab of the truck? Asking that because, I changed the plugs on my neighbors truck -- 2000 Dodge Ram 5.2L -- and his back two plugs on opposite sides looked like yours. I replaced with OEM Champion Coppers.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
QSHM 5W30 & FU (96K)
2000 Ram 4X4 5.9L (93K) PYB 10W30 & FU
Re: Opinions on used spark plugs [Re: FFeng7] #4683871
03/04/18 08:36 AM
03/04/18 08:36 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
In aviation, Sparks plugs are never changed until needed.
Those donít look bad at all.
I think a lot of plugs get tossed for no really good reason.
Re: Opinions on used spark plugs [Re: BAJA_05] #4683875
03/04/18 08:39 AM
03/04/18 08:39 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I assume in the photos they are 1-6 left to right and top to bottom.
So which ones had oil deposits?
Looks more like a penetrant was shot on before removal.
I agree with Popsy on the rust. Preventative maintenance is rarely a wasted effort.
I also agree with Linctex in that many a plug is replaced too soon.
My car's plugs were 10K overdue when I got it. Of course there was no change in operation. No sweat there.
It gave me a chance to look things over--just like looking around during an oil change. Get off on the view!
Also, someone could've installed cheap/incorrect ones. This goes for any vehicle.
A friend had an S-10. We changed plugs only a bit early. There was an improvement so that was good.
Re: Opinions on used spark plugs [Re: FFeng7] #4683887
03/04/18 08:51 AM
03/04/18 08:51 AM
N.H, U.S.A.
ARCOgraphite Online content
ARCOgraphite  Online Content
N.H, U.S.A.
One cyl looks to have higher than average deposits possibly a valve/seal guide worn passing oil into CC. Of the Plug in that one was way out of index. causing a higher misfire rate.
Nothing Horrendous.
That gap looks WAY bigger than 1.1MM more at 0.07"
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Opinions on used spark plugs [Re: ARCOgraphite] #4683908
03/04/18 09:14 AM
03/04/18 09:14 AM
Trav Offline
Trav  Offline
Indexing usually isn't an issue and it looks to be running a bit richer than the others not oil fouled. Having cap and wires it could be from a terminal or cable causing a slightly higher misfire count (not high enough to set a CEL) or an injector causing a bit of trouble. Checking the wire Ohms and cleaning the terminal cost nothing.
These engines use a Deka injector that are known to have some issues at this age, not a lot but more than I usually see. The ones with issues I see usually have a very slight drip, like one drop every 5-10 seconds.
They are not repairable and should be replace once the issue is confirmed.
Re: Opinions on used spark plugs [Re: FFeng7] #4683912
03/04/18 09:21 AM
03/04/18 09:21 AM
New York
pbm Online content
pbm  Online Content
New York
My opinion is that the car is running well according to the look of the plugs....but I would have changed them and probably used the same model plug.
'Journalism is Dead'
