25 registered members (Aero540T, berlinbai, Bert_c, 4WD, BLND1, clinebarger, 5 invisible),
769
guests, and 27
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,667
Posts5,140,083
Members70,115
Most Online3,589 Nov 2nd, 2019
PQIA Toyota 0w20 results are something!!
#4682772
03/02/18 09:26 PM
bbhero
OP
OP
Posts: 7,214 |
PQIA just tested Toyota 0w20... And it is quite impressive.
10+ TBN 787 ppm of molybdenum Viscosity index of 227 !! Boron almost 200 ppm NOACK is 12.7 And CCS of just a bit over 4100.
Of course Mobil is making their OEM oil here in the US. This is quite an interesting and impressive 0w20 made by M1.
Nissan Altima 3.5 Coupe Napa full synthetic 5w30 Wix 57356 Oil filter "Treat your family like your friends and treat your friends like your family."
Re: PQIA Toyota 0w20 results are something!!
[Re: bbhero]
#4682775
03/02/18 09:29 PM
wemay
Posts: 11,538 |
Here you go my friend... You're right, that is some VOA! TGMO 0W20 http://pqiadata.org/Toyota_0W20.html
2018 KIA Sportage LX AWD Shell RGT 5W20, STP S2808
2013 Hyundai Santa Fe Sport 2.0T M1AP 5W30, M1-104
[Re: bbhero]
#4682779
03/02/18 09:35 PM
PimTac
Posts: 11,769 |
That’s the second stout analysis we’ve seen today.
Is this better than M1? ;-))
2017 Mazda CX5 Havoline Pro DS 0w20 Roki OEM filter.
[Re: bbhero]
#4682784
03/02/18 09:41 PM
daves87rs
Posts: 17,698 |
2019 Chevrolet Equinox LS 2006 Chevrolet Cobalt LS
[Re: PimTac]
#4682786
03/02/18 09:43 PM
bbhero
OP
OP
Posts: 7,214 |
Hmmmm... I really doubt it. But.. this special "sauce" for Toyotas looks quite good. It's obvious they have gone to a very high molybdenum formulation to help with any boundary layer oil circumstances. I'd run this Toyota 0w20, Valvoline Advanced Synthetic 0w20 or Mobil 1 Extended Performance if I had to run a 0w20.
[Re: bbhero]
#4682790
03/02/18 09:46 PM
PimTac
Posts: 11,769 |
[Re: bbhero]
#4682796
03/02/18 09:52 PM
VolkswagenFox21
Posts: 57 |
Is this is a reformulation, or does Canada get a different TGMO? I sent off a sample for a VOA about a year ago and it's quite different.
2009 VW Jetta City, 2.Slow - 5MT 2016 Scion FR-S - 6MT
[Re: bbhero]
#4682803
03/02/18 09:57 PM
Danno
Posts: 2,919 |
http://pqiadata.org/OEM_PCMO_322018.htmlThat Toyota oil looks pretty unique vs other OEM oils. Calcium is down vs the others, perhaps moly was upped to account for lower calcium? Boron isn't much different from the others.
2019 Jeep Grand Cherokee Summit 5.7L Hemi 2019 RAV4 Limited Hybrid 2016 Sorento SX V6 AWD 2010 Mazda 3 2.0L
[Re: bbhero]
#4682824
03/02/18 10:27 PM
bulwnkl
Posts: 1,967 |
The lower Ca is likely because of the Mg. That's the strategy XOM uses in M1 products as well.
I'd love to see PQIA evaluate theTGMO 0W16.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
[Re: bbhero]
#4682836
03/02/18 10:41 PM
Snagglefoot
Posts: 5,310 |
Just did a quick check on a half dozen other virgin analysis on this website. Has anyone seen a moly concentration as high as 787 ppm? I appreciate the test, but either the oil was completely re formulated or the lab made a mistake.
If you want the job done right......do it yourself.
[Re: Snagglefoot]
#4682840
03/02/18 10:46 PM
PimTac
Posts: 11,769 |
The Mazda Moly oil by Idemitsu has well over 800 ppm.
[Re: VolkswagenFox21]
#4682848
03/02/18 11:06 PM
daves87rs
Posts: 17,698 |
Is this is a reformulation, or does Canada get a different TGMO? I sent off a sample for a VOA about a year ago and it's quite different. Maybe ready for the "plus" part?
[Re: bbhero]
#4682862
03/02/18 11:54 PM
CR94
Posts: 2,481 |
The highish volatility is predictable, given the high viscosity index and low CCS numbers. It may not be such a great plan for engines notorious for carbon-clogged rings.
2011 Toyota Prius now at 107K 1981 Mazda GLC (323) retired at 606K 1972 Subaru DL retired at 190K 1954 Chevrolet retired at 121K
[Re: bbhero]
#4682897
03/03/18 02:29 AM
SR5
Posts: 5,026 |
I'm not a 0W20 guy, but that oil looks impressive to me. Zinc ~ 880 ppm (healthy) Moly ~ 790 ppm (massive) Boron ~ 200 ppm (generous) TBN ~ 10.3 (long life)
And the Noack is still reasonable at 12.9 %, with a KV100 of 8.36 cSt.
Mix it 50:50 with a HDEO 15W40 mineral, to make something like a 10W30 semi-synthetic, and I would definitely give it a run.
--------------------------------------------------------------------------------- Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
[Re: bbhero]
#4682908
03/03/18 03:50 AM
Kamele0N
Posts: 3,065 |
Why mixing...when he can buy HDEO 10w30 with greater zddp levels & same TBN...ok he will miss only Moly then...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507 1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
