125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
23 registered members (dogememe, ctechbob, 4D56, Bailes1992, bernau, csandste, 2 invisible), 772 guests, and 35 spiders.
Topics290,617
Posts4,847,568
Members66,011
Most Online3,590
Jan 24th, 2017
2017 Equinox PP 5500 mile interval - First UOA. #4682617
03/02/18 07:44 PM
03/02/18 07:44 PM
Colorado
DenverGP Offline OP
DenverGP  Offline OP
Colorado
Sample from a 2017 equinox, 5,500 mile interval, 26,000 miles total. Ran Mobil 1 for the first 15k miles, then switched over to Penzoil platinum for the last 2 oil changes.
The iron / aluminum levels looked a little high to me, but I guess they are close enough to averages not to be an issue?
Calcium is a bit over averages, and silicon seemed a little high to me as well, but as above, i guess it's in normal ranges.
I don't expect to push the intervals, pretty much just following the oil life monitor, which seems to go further than the old 5000 mile rule.
Refilled the vehicle with Penzoil Ultra Platinum which I got on sale+rebate.
Re: 2017 Equinox PP 5500 mile interval - First UOA. [Re: DenverGP] #4682666
03/02/18 08:38 PM
03/02/18 08:38 PM
Leesport, PA
MedicRxDoc Offline
MedicRxDoc  Offline
Leesport, PA
Oil did well.
Re: 2017 Equinox PP 5500 mile interval - First UOA. [Re: DenverGP] #4683033
03/03/18 09:46 AM
03/03/18 09:46 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I would say good metal wear rates, and the used oil is serviceable.
Edit: Agree with BStone on 7500 miles.
Re: 2017 Equinox PP 5500 mile interval - First UOA. [Re: DenverGP] #4683135
03/03/18 11:53 AM
03/03/18 11:53 AM
Canada
addyguy Offline
addyguy  Offline
Canada
For that engine, at that mileage, results are great.
2010 Kia Soul 2U - 2.0L I-4, auto; 132k miles.
M1 EP 10W-30; OEM Kia filter.
Re: 2017 Equinox PP 5500 mile interval - First UOA. [Re: DenverGP] #4683239
03/03/18 02:43 PM
03/03/18 02:43 PM
Colorado
DenverGP Offline OP
DenverGP  Offline OP
Colorado
Thanks for the replies. So on the metal numbers, is that just standard for this motor? I had seen other reports where it seemed like something around 1ppm iron per 1000 miles was considered a "good" number.
Is the silicon number high enough to suggest I need a better air filter? I'm using a purolator pure one air filter replaced right around 20k miles. (early, but decided to do it and the cabin filter at the same time)
Not sure I'll get to 7500 miles on the next change, but I'll let the oil life monitor go all the way down before changing it if I'm under the 7500 mile mark. I think this change was probably just under 10%.
Re: 2017 Equinox PP 5500 mile interval - First UOA. [Re: DenverGP] #4683247
03/03/18 02:53 PM
03/03/18 02:53 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
The silicon reading is fine and under the average. I'd be very happy with that. I had a uoa done on the Camry at 60k miles and the silicon reading was 24 after 40k miles on the air filter. From 20k-60k which is when I changed it. Iron reading was only 5 ppm so didn't affect wear metals. All other wear metals were below universal averages.
Re: 2017 Equinox PP 5500 mile interval - First UOA. [Re: DenverGP] #4683327
03/03/18 04:55 PM
03/03/18 04:55 PM
Oakville, Ontario
Patman Offline
Patman  Offline
Oakville, Ontario
The silicon number already looks good, but based on this VOA below of PP 5w30, it already contains 6ppm of silicon in it's virgin state, so that makes the number of 10 look even better knowing that not a lot of extra dirt is getting into this engine.
https://www.bobistheoilguy.com/forums/ub...1G2#Post4573299
One way of knowing if the silicon level is alarmingly high would be if you also saw high levels of chromium as that would indicate excessive wearing of the piston rings. So anytime you see a UOA report with high silicon but the chromium is very low, that indicates it's not silicon in the abrasive form of dirt.
2018 Corvette (M1 5w30 ESP Formula & Fram Ultra)
2006 Civic EX Coupe (PUP 5w20 & Fram Ultra)
2010 BMW 328i X-Drive (GC 0w40 & Fram Ultra)
Re: 2017 Equinox PP 5500 mile interval - First UOA. [Re: DenverGP] #4683331
03/03/18 05:00 PM
03/03/18 05:00 PM
Colorado
DenverGP Offline OP
DenverGP  Offline OP
Colorado
ty guys very much.
