Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
139 registered members (4WD, 92saturnsl2, 77GrandPrix, 01rangerxl, 1foxracing, 2015_PSD, 11 invisible), 2,018 guests, and 51 spiders.
Topics286,086
Posts4,902,290
Members67,560
Most Online2,967
Mar 10th, 2019
2018 Toyota 4Runner Drive Shaft Grease Choice #4682501
03/02/18 05:49 PM
03/02/18 05:49 PM
Bucks, PA
zfasts03 Offline OP
zfasts03  Offline OP
Bucks, PA
Owners manual states:
Spider Lithium base chassis grease, NLGI No.2
Slide yoke
Molybdenum-disulfide lithium base chassis
grease, NLGI No.2 or lithium base
I was thinking Shaeffers 238 for the slip yoke, but what Shaeffers grease is preferred for U-Joints without moly?
Also no Shaeffers grease is Lithium based, I am guessing their bases/products are superior to Lithium based?
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4682513
03/02/18 05:55 PM
03/02/18 05:55 PM
VA
Gebo Offline
Gebo  Offline
VA
I had the exact same question. My Shaeffer's rep told me to use 221 in my 2002 4Runner. They are aluminum based.
Salesrep on this forum will know. He's the Schaeffer's forum rep.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4682516
03/02/18 05:57 PM
03/02/18 05:57 PM
wv
krismoriah72 Offline
wv
Slide yoke
The spider i dont think anybody does..i think you have to drop the driveshaft to do the spider and the yokes.
I would go with Mystik JT-6 on everything that has a zerk.
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4682546
03/02/18 06:29 PM
03/02/18 06:29 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Why not aluminium based grease? Its superior towards lithium based grease.... It has better characteristic against water washout
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4682586
03/02/18 07:17 PM
03/02/18 07:17 PM
VA
Gebo Offline
Gebo  Offline
VA
I grease everything on my 2002. You don't have to drop the drive shaft. I have this cool little pointy extension.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: Kamele0N] #4682672
03/02/18 08:45 PM
03/02/18 08:45 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
Yes
High quality Specialized Lubricants pay for themselves!
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4682674
03/02/18 08:49 PM
03/02/18 08:49 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
Schaeffers 221,274,238,229 ALL will perform excellently here!
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: salesrep] #4682764
03/02/18 10:19 PM
03/02/18 10:19 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Shouldnt the u joint be moly free? Thanks
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4682773
03/02/18 10:26 PM
03/02/18 10:26 PM
VA
Gebo Offline
Gebo  Offline
VA
I have the same question.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4682809
03/02/18 11:12 PM
03/02/18 11:12 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
The answer is the standard Bitog response. It the owners manual says user lithium based grease , then use anything except lithium based grease. If it says use moly lithium based grease, use anything except moly lithium based grease,
LOL
If you want the job done right......do it yourself.
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4682853
03/03/18 12:29 AM
03/03/18 12:29 AM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
Why would you not want a grease with moly in the u-joint?
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 208K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: salesrep] #4682858
03/03/18 12:46 AM
03/03/18 12:46 AM
FL
stoan Offline
stoan  Offline
FL
Yes
Schaeffer's 238 #2
Water Washout Test (ASTM D-1264)
% Loss 175F/79C 5.6%
Mystik JT-6 Hi-Temp #2
Water Washout, ASTM D1264, % loss 2.5 at 175F
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: john_pifer] #4689301
03/09/18 04:36 AM
03/09/18 04:36 AM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
Ask a failure analysis engineer
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: Kamele0N] #4689622
03/09/18 02:30 PM
03/09/18 02:30 PM
California
nthach Offline
nthach  Offline
California
Compatibility - some grease bases don't play nice with each other. We don't know what Toyota used at the factory, but unless it's a sealed bearing assembly or something that can't be easily disassembled for service, I think pumping in fresh grease until it runs out should do a decent job purging the old stuff.
https://www.thelubricantstore.com/grease-compatibility-chart
Re: 2018 Toyota 4Runner Drive Shaft Grease Choice [Re: zfasts03] #4689637
03/09/18 02:45 PM
03/09/18 02:45 PM
USA
DrRoughneck Offline
DrRoughneck  Offline
USA
U joint is made by Spicer who states in the spec sheet that only Mystik JT6 is approved for their U joint. It's cheap and approved. Why would you use anything else?
