WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
18 registered members (Buzzsaw, deoxy4, BoiseBound, Bailes1992, Bman90, 2 invisible), 723 guests, and 35 spiders.
Topics290,810
Posts4,850,758
Members66,036
Most Online3,590
Jan 24th, 2017
Mismatched orange/blue/red coolant #4682461
03/02/18 05:08 PM
03/02/18 05:08 PM
Illinois
onetwoothreee Offline OP
Illinois
I own a 2004 Honda Civic with 140,000 miles. I have a bubbler for the radiator, a repair manual and a gallon of blue 50/50. The problem is that the person who owned it before me has put something else in it!
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682465
03/02/18 05:11 PM
03/02/18 05:11 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
There's a relatively easy fix for this:
Drain the entire system, flush a couple times, and then refill with the correct coolant at a 50/50 mix.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 262,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 57,000mi
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682467
03/02/18 05:11 PM
03/02/18 05:11 PM
Illinois
Illinois
No idea how to do that.
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682468
03/02/18 05:14 PM
03/02/18 05:14 PM
Illinois
Illinois
My plan was to drain the radiator, cap it back off and fill with the no-spill funnel. Let it run and get rid of all the bubbles.
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682471
03/02/18 05:19 PM
03/02/18 05:19 PM
Oklahoma
CELICA_XX Offline
CELICA_XX  Offline
Oklahoma
The coolant system extends beyond the capacity of the radiator.
You would want to flush the whole system out.
15 Toyota Prius - M1 EP 0w20
02 Toyota ECHO - Valv MaxLife Full Syn 5w30
97 Lexus LX450 - M1 0w40
93 Lexus LS400 - Valv MaxLife Full Syn 5w30
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682475
03/02/18 05:27 PM
03/02/18 05:27 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Check this video out
https://www.youtube.com/watch?v=s--5ft5YiHg&sns=em
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682478
03/02/18 05:27 PM
03/02/18 05:27 PM
Illinois
Illinois
I doubt that's going to happen unless I'm paying someone to do it. The stock coolant is blue. The car has been in a front-end (previous owner), and the coolant is now orange (which is the wrong spec for this car). I've got a tank full of straight orange.
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682480
03/02/18 05:32 PM
03/02/18 05:32 PM
Illinois
Illinois
Let me rephrase. Which is better in my application: having a 100% concentration of Dex-Cool, or a 50/50, 75/25, 90/10 (etc) concentration of orange and blue (or red)?
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682488
03/02/18 05:37 PM
03/02/18 05:37 PM
Illinois
Illinois
Right now, I'm most likely to take the blue 50/50 back for a gallon of the red 50/50 (same as I understand) and stick with my previous plan.
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682495
03/02/18 05:41 PM
03/02/18 05:41 PM
VA
Gebo Offline
Gebo  Offline
VA
I don't think it will be too hard. On my Toyota's, I drain coolant from radiator and from an engine block drain. I make sure the heater it turned to highest heat setting. That's the only way you will empty what's in the heater core. I empty my coolant reservoir. Close everything back up and add Toyota Coolant
In your situation, I would drain all the coolant (I am assuming the civic has a block drain) and then add distilled water to fill up the system. I'd drive it with heater on full heat until it warms up good. Then I'd drain all of the distilled water and refill it again. Run it til it gets hot and then drain it all out. Then I would add the Honda blue coolant. In other words, I would do 2 rinses with distilled water.
If that seems more than you want to do, find a good mechanic who could flush the system for you.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Amsoil in all engines, transmissions and differentials
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682523
03/02/18 06:09 PM
03/02/18 06:09 PM
Illinois
Illinois
I have 3 neighbors with lifts
Re: Mismatched orange/blue/red coolant [Re: Gebo] #4682535
03/02/18 06:21 PM
03/02/18 06:21 PM
Illinois
Illinois
The distilled water is not going to happen. Yes, it has an engine block drain; it's right next to the oil filter...
Re: Mismatched orange/blue/red coolant [Re: SirTanon] #4682555
03/02/18 06:35 PM
03/02/18 06:35 PM
Illinois
Illinois
Dealer wants $139 and my neighbor doesn't want to mess with it. Looks like I'm buying 2 gallons of 50/50. Looks like the owner of this car didn't know what they were doing.
Re: Mismatched orange/blue/red coolant [Re: JC1] #4682591
03/02/18 07:22 PM
03/02/18 07:22 PM
Illinois
Illinois
It has orange coolant in it and it's not supposed to. I took it back.
https://www.youtube.com/watch?v=97y5k31VhAA
Re: Mismatched orange/blue/red coolant [Re: onetwoothreee] #4682710
03/02/18 09:21 PM
03/02/18 09:21 PM
Illinois
Illinois
Possibility it's Peak Global. Why would they not?
