Nissan MTF 75w-85 GL4
Perpetual Winter USA
I wanted to ask if anyone has done a VOI on this fluid, and also offer to pay to have one done if not. I would love to bolster the great list of MTL's by viscosity you have going.
I have just received 3 qts to change the manual transmission fluid on my 2007 Sentra. This is Nissan part number 999MP-MTF00NP.
The owners manual calls for "ELF XT4447 M+ 75W-80 or API GL-4, Viscosity SAE 75W-80" however I have noticed later models of the same 6 speed transmission call for the Nissan MTF 75w-85 fluid. The dealer doesn't even stock the other grade anymore so I think this fluid essentially replaced the other one. If anyone has any info otherwise please let me know!
If you want 75w85 gl4 ask any Kia/Hyundai dealer
Or... http://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-mtf-1-sae-75w-85.html
I know that there are many options out there that would work. I was considering going with Syncromesh as I have had great results with it in the past in various "lightweight" applications. Also considered Redline either regular MTL or the new MT-85 as Marco mentioned. The Ravenol fluid says GL-5 as well so I'd be leery of that.
At the end of the day I haven't been having much in the way of drivability issues (except the first few shifts in extreme cold), the car has 175k on it and I figure I will just stick with what I think is in the tranny now.
I am curious about this fluid any how it might compare to the other options though, hence the question about a VOI if anyone is interested.
Also I do see that the company ELF does make MTL (75w-80) for Renault cars and I wonder if that was the original fill and spec for the Nissan.
http://catalog.elf.com/en/products/nq7/TRANSELF-NFJ-75W-80
I am presently using Ravenol MTF-2 75W-80 GL-4 oil in my Nissan Frontier transmission. The specified viscosity is 75W-85 but the transmission shifts horribly when cold so I am trying the lower viscosity fluid just as an attempt at improved shift quality.
I will run this out to 50,000 miles and then either refill with the same or possibly try Redline MT-85.
This is another instance of there isn't such a thing as 'correct' viscoisty grade for a certain components like a specific manual trans or differentials as often misleadingly advocated in this forum.
I find your basis of being leery of this Ravenol 75W85 GL5 (and GL4) having ASTM D130 of 1b as unfounded and irrational ..
.... as the now obsolete GL4 specification for ASTM D 130 was a far more inferior 3a/3b?
I stand corrected... I was not aware of this copper strip test. The Ravenol MTF-1 looks like a pretty good fluid. And the MTF-2 formulation is rated 1a and lower viscosity 75w-80 as FowVay mentioned.
How is the MTF-2 fluid so far? Any idea what the cSt is at @ 100C?
The Ravenol fluid says GL-5 as well so I'd be leery of that....
The only thing misleading and irrational in this Forum/thread are your responses.
You don't seem to have a clue wrt the relation of gearbox internals and their lubricant requirements.
I did read something about the GL-4 spec being antiquated and that there are plenty of GL-5 fluid that will not eat soft medals, so I understand where a copper strip test might be useful in that regard.
I agree though that viscosity ratings do matter quite a bit.
True, while the GL-4 spec is considered obsolete, there are still tests that we can do on gear lubricants to see if they qualify to an equivalent GL-4 load and wear rating such as the tests listed here:
http://www.intertek.com/automotive/lri-gear-oil/
and that's what additive suppliers do to qualify their additives with a specified set of base oils.
MTFs must provide:
Synchronizer friction material compatibility
Corrosion protection (Rust and Metal Inhibitors)
High thermal stability
Shear stability
Anti-Wear chemistry as described below.
As far as copper alloys such as brass and bronze synchronizer components, the new MT additive formulations do not contain EP additives as they did in days of yore. But GL-5/MT1 differential lubes do contain high levels of EP additives because differentials carry high loads at various gear angles.
Today's dedicated MT formulations contain additive packages with an Anti-Wear (AW) additive chemistry consisting of a Multi-functional phosphite component, with a small amount of ZDDP.
This Ravenol MTF-2 75W80 would have typically similar KV@40*C of 47 cSt and KV@100*C of 8.5 cSt in an Elf Tranself NFJ 75W80 linked by you,
...... which are generally thinner than a Ravenol MTF-1 75W85.
A typical 75W85 from Castrol Syntrans has a thicker KV@40*C of 64.6 cSt and KV@100*C of 11.9 cSt,and hence higher MOFT across full range of operating temperatures,
There isn't such a thing as 'correct' viscosity grade oil, but an oil with a higher MOFT at operating temperatures would offer you higher margin of safety in terms of components protection, other things like add pack being equal.
Pl abstain from being judgemental on other's 'cluelessness' of whatever ......and getting personal ....
which is uncalled for, and let's get back to the science of this thread!
Yes, the post#1 has demonstrated beyong doubt, there is no such thing as a 'correct' viscosity oil grade.
..Pl abstain from being judgemental on other's 'cluelessness' of whatever ......and getting personal ....
This thread has shown no such thing. Again, your comments consistently show you are clueless (how about "uneducated and uninformed") regarding the mechanics of gearing and transmissions, and their associated lubrication requirements.
My "tell-it-like-it-is" comments are based on the science of formulating lubricants for the last 30 years, so I think I am qualified to point out errors, misinformation, and downright incorrect information.
Just so you know, I'd personally overhauled with my pair of eyes and hands hundreds, yes hundreds of units of gear trains ......from 5 hp to 400 hp capacities..... automotive gear trains included .......
..and your flawed assessment on my capability on commenting on gear trains and its associated lubrication requirements is down right off the mark.
Let's get back to science in this thread!
Edit:Thousand apologies to OP.
...Let's get back to science in this thread!
I am still waiting for you to say something that deals with real lubrication science.
Let's just say I know [censored] when I see it.
As far as the OP, I think he see's it too.
This is another instance of there isn't such a thing as 'correct' viscoisty grade for a certain components like a specific manual trans or differentials as often misleadingly advocated in this forum...
...I find your basis of being leery of this Ravenol 75W85 GL5 (and GL4) having ASTM D130 of 1b as unfounded and irrational...
Obviously, you have not engineered or worked with engineers on gear systems and lubrication science or you wouldn't be making such ridiculous and uniformed statements.
So tell me Dr.Zeng, how would you specify and formulate an MT oil for a 5-speed MT coupled to a 750Hp engine in which the transmission had mostly helical cut gears for a temp of -25F to 275F with common gear and differential ratios? The engine produces 530 lb.ft. of torque at 7500 RPM.
i have + am still using Redline MT-90 in my traded jetta with the O2J 5 spd known for poor shifting + now my TT with the O6M, both performed flawsley, + the afore mentioned O2J barely shifted at 90,xxx miles but changing to the Redline brew turned it around until i ripped the teeth off 5th while boosting 25 lb passing on a hill!!!
I was all set to use the new Nissan MTF until I read more and more on this site. Then I was going to go with Redline regular MTL, because it really does seem to be a better fit spec wise and the new factory stuff is unknown. Now I'v come across an actual document that makes me want to go find the ELF fluid since it really does seem to be the factory fill.
http://www.370zcoupe.com/TSB/1RC37.pdf
I'll try to procure the ELF fluid and I'll run a VOI on the stuff too. If not I'll fall back to Redline.
