How much is too much?
by Sealbilly
4 minutes 11 seconds ago
Correct oil filter for a Vovlo S60, 2003
by earthworm
21 minutes 23 seconds ago
Prestone coolant $3.50 Target YMMV
by pda1122
24 minutes 53 seconds ago
Need Windows 7 Pro ISO
by MONKEYMAN
Today at 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
Today at 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
Today at 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
Today at 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
Today at 06:13 PM
2011 Chevy equinox overheating
by hardcore302
Today at 06:00 PM
Are my rotors warped?
by Dylan1303
Today at 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
Today at 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
Today at 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
Today at 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
Today at 04:28 PM
Same grade with differing low start temps
by mjoekingz28
Today at 04:24 PM
Self defense
by Camprunner
Today at 03:13 PM
Any apple experts here?
by maverickfhs
Today at 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
Today at 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
Today at 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
Today at 01:52 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
92 registered (69Torino, andyd, 87sammy, 2strokeNorthstar, 1998CamryCE, 4WD, 10 invisible), 1571 Guests and 42 Spiders online.
65265 Members
67 Forums
285546 Topics
Page 1 of 2 1 2 >
#4682086 - 03/02/18 09:19 AM Lexus ES 350 oil change recommendations
HampsHump Offline
Loc: TX, USA
Hey Guys,
Newbie here. My 2011 ES is up for an oil change and I want to go full synthetic.
This would be the very first change over to synthetic.
Mileage: 58K
Engine model: 2GR-FE
Recommended viscosity: SAE 5W-30 (if unavailable, SAE 10W-30 maybe used)
Please give your expert recommendations on the synthetic oil type/brands I should consider including filters.
I plan on buying the oil/filters and getting the change done at Walmart or a good local lube shop.
Can I go directly to a synthetic or do I need to step through a blend?
Online/local store to buy oil/filters etc.
Thanks in advance.
#4682096 - 03/02/18 09:33 AM Re: Lexus ES 350 oil change recommendations [Re: HampsHump]
rooflessVW Offline
Loc: North Carolina
M1 5W-30 and a Fram TG9972.
"Zed's dead baby, Zed's dead."
#4682100 - 03/02/18 09:35 AM Re: Lexus ES 350 oil change recommendations [Re: HampsHump]
BAJA_05 Offline
Loc: Berks County/Pa.
Pennzoil Platinum Pure Plus High Mileage 5W30 and a Fram Ultra!!! You can use the $10.00 rebate for Pennzoil synthetics also. wink
Dale
Edited by BAJA_05 (03/02/18 09:37 AM)
2017 VW Jetta SE TSI 1.4L Turbo
PP Euro 0W40 & FU
2008 Acura TL 3.2L QSHM 5W20 & FU
2005 Subaru Baja AWD 2.5L N/A 5spd.
Rotella T6 5W30 & ST
#4682103 - 03/02/18 09:38 AM Re: Lexus ES 350 oil change recommendations [Re: HampsHump]
tig1 Offline
Loc: Illinois
M1 5-30.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4682105 - 03/02/18 09:38 AM Re: Lexus ES 350 oil change recommendations [Re: BAJA_05]
knerml Offline
Loc: NE Ohio
Originally Posted By: BAJA_05
Pennzoil Platinum High Mileage 5W30 and a Fram Ultra!!! You can use the $10.00 rebate for Pennzoil synthetics also. wink
Not a high mileage vehicle. You might want to avoid high mileage oils until you see leaking or an oil consumption problem.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T GDI Castrol Edge 5W40 & OEM/Mann W811/80 Filter
#4682108 - 03/02/18 09:41 AM Re: Lexus ES 350 oil change recommendations [Re: knerml]
JohnnyJohnson Online   content
Loc: Wet side WA
The HM oils many times are the ones on sale. But you'd be smart to avoid them because they will cause what specific damage to your car?
2004 Toyota Corolla 121598
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74016
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4682113 - 03/02/18 09:46 AM Re: Lexus ES 350 oil change recommendations [Re: HampsHump]
JLTD Offline
Loc: US
Depends....What are your driving habits? All city, go cheap and change more frequently. All highway, do extended drains with an oil designed for it (M1 EP, Amsoil)
His: 2015 4Runner SR5 1GR-FE 37k, Amsoil OE 5w20/Wix
Testing vs Amsoil OE 5w30...then longer OCI on SS
Hers: 2008 Jeep Liberty 134k, Amsoil SS 5w30/Amsoil, minimum 10k oci
#4682125 - 03/02/18 09:58 AM Re: Lexus ES 350 oil change recommendations [Re: HampsHump]
PimTac Online   content
Loc: Soviet State of Washington
Any major brand that meets the specs for your Lexus will do. How long do you plan to go between oil changes?
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4682135 - 03/02/18 10:09 AM Re: Lexus ES 350 oil change recommendations [Re: JohnnyJohnson]
knerml Offline
Loc: NE Ohio
The additive used to treat oil seals cause them to swell and take a new set. If you then stop using HM oil, the oil leaks may return and may become worse.
#4682149 - 03/02/18 10:21 AM Re: Lexus ES 350 oil change recommendations [Re: JLTD]
HampsHump Offline
Loc: TX, USA
City and some highway, easy driving, 70-80 mph on highway.
preferred change- 6-7K.
Thanks
#4682157 - 03/02/18 10:33 AM Re: Lexus ES 350 oil change recommendations [Re: JohnnyJohnson]
HampsHump Offline
Loc: TX, USA
What impact will the high mileage 5W30 have over the non..?
#4682164 - 03/02/18 10:36 AM Re: Lexus ES 350 oil change recommendations [Re: HampsHump]
High mileage oils are for engines that have a weep or seeping issue or for some oil burning issues. If you have neither of those you donít need it.
#4682185 - 03/02/18 10:57 AM Re: Lexus ES 350 oil change recommendations [Re: HampsHump]
raytseng Offline
Loc: CA
I like pp or pup.
But most importantly just go with what's on sale.
For filter I suggest you just buy a 5pack of toyota oem filters with drain crush washers. There are various toyota and lexus dealer parts depts who put up amazon or ebay storefronts that will sell you a discounted 5packs. You can also access the low price dealer that uses the trademotion network via parts.com.
If you think ahead you should also buy other oem maintenance items like wipers or engine air filters at the same time to amortize shipping
If youre buying an oil and filter bundled special from an autoparts store oil change deal, I'd run the bundled bosch or fram or purolator whatever filter is in the bundle without hesitation.
For pup set up an alert for amazon when it goes on sale and use the pennzoil rebate.
Edited by raytseng (03/02/18 11:00 AM)
#4682205 - 03/02/18 11:21 AM Re: Lexus ES 350 oil change recommendations [Re: raytseng]
HampsHump Offline
Loc: TX, USA
Thanks for the heads up. I was able to find 6 quart M1 5w30 at Sam's Club for $27.78 before tax.
I now need to buy
- air conditioner filter
- engine air filter
Sorry. What is pp and pup?
#4682206 - 03/02/18 11:23 AM Re: Lexus ES 350 oil change recommendations [Re: HampsHump]
CELICA_XX Offline
Loc: Oklahoma
I would skip the High Mileage oils as well.
Any major brand of synthetic would do fine. You don't need to go to a blend first.
Fram Ultra filters
15 Toyota Prius - M1 EP 0w20
02 Toyota ECHO - Valv MaxLife Full Syn 5w30
97 Lexus LX450 - M1 0w40
93 Lexus LS400 - Valv MaxLife Full Syn 5w30
Page 1 of 2 1 2 >
