02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
06/23/18 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
06/23/18 09:34 AM
Anger on BITOG
by Gebo
06/23/18 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
06/23/18 08:45 AM
Surprising oil filter service interval.
by jakewells
06/23/18 08:12 AM
World Population
by CourierDriver
06/23/18 08:11 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
70 registered (93cruiser, Atesz792, 2015_PSD, 1998CamryCE, AP9, AZjeff, 6 invisible), 1649 Guests and 43 Spiders online.
65303 Members
67 Forums
285857 Topics
#4682010 - 03/02/18 07:08 AM How often should a car be started?
Spetz Offline
Loc: Australia
Hi everyone,
I use a car on a race track and hence have no need to start it often.
Just wondering am I better off starting it weekly, or whenever I need it (could be 1-3 months apart)?
And, is it a good idea to disable the fuel pump and crank it for a while to build oil pressure before starting it if it is only started rarely?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 150,000 miles. Shell Helix Ultra 5W40 at 6k OCI
#4682012 - 03/02/18 07:14 AM Re: How often should a car be started? [Re: Spetz]
supton Offline
Loc: NH
How much of a race motor is it? What is your ambient humidity like?
If it's a wild motor I'd get a prelube setup, or prime the motor by spinning the oil pump (if possible). How long would it need to sit before I would do that? dunno, maybe six months, unless if it was trivial to spin the oil pump & I thought the bearings really "needed" it. I have a tough time thinking it couldn't go a year between starts.
I'm not sure if cranking w/o spark is going to get "lots" of oil pressure, and quickly. I'd be more apt to pull spark plugs and crank if I were to do that--it'll crank up to speed much faster, and get pressure that much faster.
Now if it humidity was a concern I'd fog the cylinders with some spray lube before storing; and then pull the plugs and crank (as above) when taking out of storage. Make sure to seal off intake&exhaust before storing.
2011 Toyota Camry, base, 2.5L/6MT, 162k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 143k, ours
1999 Toyota Camry LE, 2.2L/4AT, 183k, his
#4682021 - 03/02/18 07:37 AM Re: How often should a car be started? [Re: Spetz]
Spetz Offline
Loc: Australia
Humidity is low.
The engine is a 6A12 Mitsubishi with bolt on modifications.
I can (and have)removed the plugs to prime it before but I need to take the intake manifold off (it's a V6) to get to the back cylinders.
I like this as there is no load on the bearings and the motor would spin fast enough to build oil pressure but it is quite labor intensive unfortunately.
It gets started about once a month at least but over summer as it's too hot to race it may go 3 months without being started (but I can obviously start it if needed).
#4682026 - 03/02/18 07:44 AM Re: How often should a car be started? [Re: Spetz]
demarpaint Offline
Loc: NY
Originally Posted By: Spetz
Humidity is low.
I've let engines sit longer than that w/o issues. I think you'll be fine. Over the years I have installed pre-lubers in vehicles that would occasionally sit more than 3 months at a time. That might be something worth looking into. As I mentioned I think you'll be fine just the way you are.
God Bless Our Troops
#4682032 - 03/02/18 07:58 AM Re: How often should a car be started? [Re: Spetz]
Chris142 Offline
Loc: Deplorable in apple valley, ca
How are you priming the main ,rod bearings and camshaft through the plug holes?
Edited by Chris142 (03/02/18 07:58 AM)
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4682035 - 03/02/18 08:04 AM Re: How often should a car be started? [Re: Chris142]
supton Offline
Loc: NH
You're not. Fog with a light oil before storage, reinstall plugs, to prevent cylinder wall rust. When taking out of storage, remove plugs and spin the motor to remove said oil. Cranking the motor over w/o plugs should get pressure up pretty quickly.
#4682039 - 03/02/18 08:16 AM Re: How often should a car be started? [Re: Spetz]
hpb Offline
Loc: Tasmania, Australia
Just start it as and when needed. Seriously, you're not going to remove the inlet manifold to get the rear bank spark plugs out and fog those cylinders, are you? In our temperatures, nothing inside the engine is going to rust. If you're wanting to be super cautious, pull the fuel pump relay and crank it a bit before firing, but honestly, it'll build oil pressure much quicker if you just start it right up smile
MY16 Mitsubishi Outlander 2.2 diesel, 47,000km - Castrol 5w30
2006 Ford Falcon 4.0, 132,000km - Penrite Vantage 15w40, Ryco filter
#4682065 - 03/02/18 08:49 AM Re: How often should a car be started? [Re: Spetz]
mightymousetech Offline
Loc: Ontario, Canada
Do not start it unless you plan on getting it up to full operating temp.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4682067 - 03/02/18 08:52 AM Re: How often should a car be started? [Re: mightymousetech]
propuckstopper Offline
Loc: MB, Canada
^^^^This.
1965 Pontiac GTO Tri-Power 4-Speed Hardtop (Montero Red)
1968 Pontiac GTO Covertible 400 H.O./Auto (Solar Red)
2000 Lexus ES300
2003 Honda Element AWD
#4682073 - 03/02/18 08:55 AM Re: How often should a car be started? [Re: mightymousetech]
SteveSRT8 Online   content
Loc: Sunny Florida
Times a million! For years I worked for a guy with a substantial collection of cars. One rule for all was never start them unless you can drive it for at least 20 minutes.
Even if you let it get up to full temp at idle it is not heated the same as driving. Plus other components have issues with long spells of inactivity.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#4682187 - 03/02/18 10:58 AM Re: How often should a car be started? [Re: SteveSRT8]
JHZR2 Offline
Loc: New Jersey
Agree 100% getting to temp is key.
Since OP likely does not have AC in that vehicle, I see no reason to run it. Keeping AC system lubed, oil barriers in the hoses, etc. is one of the only real drivers I see to having to run a vehicle more often... And even then, the hot rule applies!
#4682275 - 03/02/18 12:37 PM Re: How often should a car be started? [Re: SteveSRT8]
Gimpy1 Offline
Loc: Displaced Texan in Mexico City
This!!!
What about the fuel in the tank and lines are you completely draining the system I'd be concerned about fuel evaporation leaving nasty gunk on the injectors and such . Also if its a wild built uber motor, building or purchasing a oil accumulator might be a wise investment. Check out Accusump for examples.
Edited by Gimpy1 (03/02/18 12:40 PM)
Edit Reason: added info
#4682358 - 03/02/18 01:54 PM Re: How often should a car be started? [Re: Spetz]
Nick1994 Online   content
Loc: Phoenix, AZ
Unless you need to move it or use it, leave it alone.
My Camry has been sitting for a year. Every once in a while I need to move it, it's parked on the street out front of my house. I pulled it in the driveway in December overnight to charge the battery, next morning back on the street. I think that's the last time I touched it. Battery is in the garage now.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
